Samsung le40c550j1w
  • Jimmy1979
    • Apr 2015
    • 120
    • holland
    Samsung le40c550j1w
    Hi
    I Have a samsung lcd tv with only standby.
    No response On off
    Remote no response either.
    backlight is working when mainboard not connected
    Problem is the mainBoard.
    Can i try something with the Mainboard maybe eeprom flash?
    Need some help.
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Samsung le40c550j1w
    You need to check your voltages on the power supply connector as shown in the attached photo.
    • Jimmy1979
      • Apr 2015
      • 120
      • holland
      With the connector connected to mainboard or not?
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        Initially connected, yes.
        • Jimmy1979
          • Apr 2015
          • 120
          • holland
          2 =0,2. 1=0,3 >13,2
          4= 0. 3=0,3 >13,2
          6=0>4,92. 5=0,3>13,2
          8=0>4,57. 7=0
          10=0. 9=0
          12=0. 11=0>5,2
          14=0>5,2. 13=0>5,2
          16=5,2. 15=0>13,1
          18=0>3,9. 17=0>13,1
          Power supply try's to start
          *And voltages pulsating from 0 to >13,2
          Example
          • dick_barton
            • Aug 2015
            • 6643
            • Wales
            Disconnect the main board and connect pin 16 to 18 using a 1K resistor then test all the voltages at the connector again with mainboard still disconnected.
            • dskall
              • Oct 2016
              • 2905
              • usa
              Would also help if you put pin description so don't have to go back and forth between posts
              • Andrew F. Ali
                • Jan 2014
                • 2450
                • Trinidad & Tobago
                With the Main Bd disconnected the Backlights came On. Then there is definite a working PSU and faulty Main Bd. It could either be a problem with the BGA chip or a non-working Regulator Chip not sending the PWR-ON signal to the PSU to start it up.
                • Jimmy1979
                  • Apr 2015
                  • 120
                  • holland
                  you need to check your voltages on the power supply connector as shown in the attached photo.
                  2=5,2. 1=13,1
                  4=2,1. 3=13
                  6=4,83. 5=13
                  8=0. 7=0
                  10=0. 9=0
                  12=0. 11=5,3
                  14=5,3. 13=5,3
                  16=5,3. 15=13
                  18=5,3. 17=13
                  • dick_barton
                    • Aug 2015
                    • 6643
                    • Wales
                    As Andrew F Ali has just pointed towards, it looks as though there is a main board fault with it trying to power on the set (Pin 18) but failing and retrying which is why your voltages are swinging up and down.
                    • dick_barton
                      • Aug 2015
                      • 6643
                      • Wales
                      It appears as though there's a common fault with the main board as discussed in the following thread.
                      https://www.badcaps.net/forum/showthread.php?t=36322
                      http://www.ohmsupplies.co.uk/epages/...s/E2P095-CP274
                      • Jimmy1979
                        • Apr 2015
                        • 120
                        • holland
                        I searched the web and i found this tread before
                        I saw on youtube people did an eeprom flash with usb.
                        I ordered this tool too but is it possible to read the old and flash to the new one?
                        Or does someone have the file to flash or link?
                        • dick_barton
                          • Aug 2015
                          • 6643
                          • Wales
                          A flash file was included in the threads although i didn't read all the way though to know if its also suitable for your set.
                          If the EEPROM on your mainboard is corrupt then reading it and writing it back may not cure the fault.
                          You could try freezing the eeprom and then switch on the set and see if it powers up correctly. If it does then you could remove it, freeze it and then read it and save it to file and write it back to the same EEPROM or to a new one.
                          • Jimmy1979
                            • Apr 2015
                            • 120
                            • holland
                            I will try and see if i got luck.
                            I wanted to try en write the file on a new eeprom chip not old one.
                            But i have to wait untill i get the usb flash programmer
                            • maxvalutech
                              • 804
                              • australia
                              Am I right in thinking for these sets that a new blank eeprom when fitted will gather required program itself by switching on and letting it cycle itself three times?
                              • dick_barton
                                • Aug 2015
                                • 6643
                                • Wales
                                You may well be correct.
                                https://wiki.samygo.tv/index.php/UnB...y_EEPROM_Reset
                                • Jimmy1979
                                  • Apr 2015
                                  • 120
                                  • holland
                                  I have changed the eeprom with a new empty one first.
                                  No standby and no power on after 30 seconds.
                                  So i read the old one and programmed the file on the new one.
                                  Then power led burning just like the old one but when powering on the standby light dims and no reaction after that just like the new old one.
                                  Does someone has the right bin file.
                                  Maybe mine is corrupt or there is an other issue with the mainboard.
                                  Thanx
                                  • dick_barton
                                    • Aug 2015
                                    • 6643
                                    • Wales
                                    So did you try "Reseting NVRAM (EEPROM)" as shown in the wiki pages and follow the instructions shorting the various pins on the eeprom?
                                    • Jimmy1979
                                      • Apr 2015
                                      • 120
                                      • holland
                                      Yep i tried that as well tv doesn't turn on with😔
                                      • maxvalutech
                                        • 804
                                        • australia
                                        A new blank eeprom should not affect your standby .
                                          09-07-2024, 05:50 AM
                                        • Jacksoft
                                          Samsung 225MW EEPROM bootloop
                                          by Jacksoft
                                          I got an old Samsung 225MW TV with BN41-00825 motherboard.
                                          Since the TV has a buzzer when it starts it makes a beep. The main problem is that the TV goes in a sort of bootloop and beeps every 2-3 seconds.
                                          So I attached the VGA UART cable and read the debug data using a RT809H programmer:
                                          According to the Service Manual all the voltages looks good, so I made a backup of the internal flash and all the EEPROMs (1 Settings + 3 EDID) and cleaned the EEPROM.
                                          Now the TV boots but it's stuck on VGA. If I try to change the source it goes to TV, restarts...
                                          02-14-2025, 04:18 PM
                                        • Nairolf
                                          Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
                                          by Nairolf
                                          I have a Samsung DM32D display.
                                          When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
                                          Here’s what I have tried so far:
                                          1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
                                          2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
                                          3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
                                          From these tests, I suspect the problem might be on the mainboard. Could anyone...
                                          08-24-2025, 03:47 AM
                                        • bohaboha
                                          ADVICE FOR SAMSUNG MAINBOARD COMPTABILITY
                                          by bohaboha
                                          Hello all of you can any one tell if this Samsung Mainboard BN96-50992B 32" UE32T5300CK is compatible SAMSUNG UE32T5300AK ?...
                                          04-19-2025, 01:47 PM
                                          09-06-2024, 11:40 PM
