Panasonic TX-L42B6B No Picture
  • Norman1
    • Jun 2017
    • 77
    • Uk
    Hi guys, got a Panasonic that comes on with a dark picture which you can see for a few seconds with a torch shining on the screen while it flashes slightly, then it go's off with the red standby light flashing. Anyone had the same?
  • unxtres
    • Aug 2017
    • 20
    Re: Panasonic TX-L42B6B No Picture
    Bad capacitors, dry solder joints, broken led controller, burned led in backlight stripes.
    I`ve listed few possible issues that can cause problems you`ve got .
    • Norman1
      • Jun 2017
      • 77
      • Uk
      Anyway of narrowing it down a bit the red s/by light flashes once every 4seconds
      • unxtres
        • Aug 2017
        • 20
        Wow. you think this is simple repair and you do this with screwdriver? The answer is no.
        This is PSU or backlight leds are gone, if you don`t know what are you doing than take tv to nearest tv service
        • dskall
          • Oct 2016
          • 2905
          • usa
          Is image staying on?
          • Norman1
            • Jun 2017
            • 77
            • Uk
            Unxtres, this is a forum to help people, and incidentally I have been in the tv business since the days of crt, so if you have nothing constructive to say,,,Go Away and take your toddlers mentality with you. Hello Dskall, when you first power the tv up I can see the menu with a torch, the screen is still flashing every two seconds, then shuts down and red led blinks steadily every 4 seconds. I have read it might be the led's,,be nice to check if it's a board though
            • unxtres
              • Aug 2017
              • 20
              Norman1 sorry if you take my answer as an attack, but if you are in business, than you need to know that multimeter is your friend, you have provided nothing about your tv... only serial number. So you expect that i`ll find psu, main model etc in google?
              You need to provide few more info some photos, etc. check voltages
              • Norman1
                • Jun 2017
                • 77
                • Uk
                Good evening unxtres I will admit I have been out of the loop for a few years while I concentrated on the aerial install side of things, but I'm getting back into it again now. But I'm not sure what voltages should be on what pins, il get a few pics up.
                • R_J
                  • Jun 2012
                  • 9588
                  Here is a similar thread https://www.badcaps.net/forum/showth...ight=TX-L42B6B found by searching the model number. It's a good chance there is one or more bad led's in the panel.
                  That thread has a link to the manual, check the voltages on the LD board (LD1) plug, then check the voltages on (LD3)
                  • Norman1
                    • Jun 2017
                    • 77
                    • Uk
                    Thanks R.J, il check a few voltages tomorow. This is the second potential led problem in a week. It's very annoying.
                    • dick_barton
                      • Aug 2015
                      • 6643
                      • Wales
                      Have you got a led tester. They are cheap enough and is a useful tool to have available.
                      As an example:-
                      https://www.ebay.co.uk/i/27226263323...6856138&crdt=0
                      • Hamie
                        • Apr 2014
                        • 1383
                        This TV uses a LN series LG panel.
                        The LN series are famed for bad LEDs
                        • Norman1
                          • Jun 2017
                          • 77
                          • Uk
                          I have the same model tv sat next to it in a 50" screen, not very good are they,
                          • FZG
                            Panasonic AG-1000B VHS player with bad picture quality
                            by FZG
                            Hello!
                            I recently got an old VHS player from Panasonic and just for fun I want to try to repair this device. It is an AG-1000B portable VHS player from 1990 and it has a problem with picture quality in playback mode.
                            Picture in playback mode is very noisy and often loses sync but the still images are nearly perfect.
                            I want to know, is this something that could be solved by recapping or is the video head likely gone?
                            Also, what mechanism is this?
                            Any feedback is appreciated!...
                            05-06-2024, 07:16 AM
                          • Bazfletch3
                            Panasonic TH-65FX800A backlight LED's working but picture is very dark
                            by Bazfletch3
                            Hi all
                            While I have quite a decent background in electrical & electronic troubleshooting & repairs, this is my first time stripping down an LCD TV for repair.... I have inherited a 3yr old Panasonic LCD which has a picture, but it is quite dark (too dark to be watchable - but still quite easy to see; I didnt need a torch to see it).
                            I started by checking and trying to adjust all of the picture and backlighting levels, but that made little to no difference. I also did a factory reset.
                            From there I envisaged that the backlighting wasn't working, however...
                            01-08-2024, 10:18 PM
                          • ItepK
                            LG 32LG3000 TV, three red light flashes, then the backlight turns on, but no picture
                            by ItepK
                            Hello everyone! I've found this television, and I began troubleshooting it.
                            First, the television kept rapidly power cycling. I've warmed up the capacitors with a hairdryer, and after 3 dimmed red blinks, the backlight turned on, then turned dim, and no picture was present on the screen.
                            I believed that this was caused by a bad power supply producing insufficent power (I've measured 3.5v on the 5.2v rail), so I've blindly recapped the board.
                            After the recapping, all the voltages stableized, however, the issue in the title still remains.
                            I could...
                            01-03-2025, 09:01 AM
                          • Tr0ll
                            by Tr0ll
                            Original T-con:
                            First replacement T-con:
                            10-07-2023, 07:48 PM
                          • JJAAMM
                            by JJAAMM
                            Problem
                            07-06-2023, 06:01 AM
