Sony Bravia KDL-40EX720 no backlight
  • olegau
    • Aug 2017
    • 15
    It seems to me all work except the backlight.
    The red standby and the green power on lights are stable, no flashing.
    I try to identify which board or the screen is faulty.
    Connections on LD board:
    CN1001 (4pins)+122V each
    CN1000 (5pins) four pins+28V each
    What confuse me is CN1001 voltages. They suppose to be negative but it is +122V each.
    I think the problem is somewhere around here.
    I appreciate any opinion.
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Sony Bravia KDL-40EX720 no backlight
    There are no negative voltages. The "+Out" indicates the power to the leds and the "-Out" is the return connection from the leds.
    • olegau
      • Aug 2017
      • 15
      Thanks for the clarification.
      So it looks LD board and screen leds are okey.
      Who knows how to identify a faulty board?
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        Unfortunately the power supply schematics within the above pdf are not readable which would have been of help.
        • olegau
          • Aug 2017
          • 15
          I checked supply 12V on conections CN6151 and CN6801. All of them 12.5V.
          Power on/off 3V/0V works.
          • Biruslapio
            • Nov 2013
            • 552
            • Brasil
            Hi,i had a 40EX725 but i broke its display,i still have all the boards except signal board,this one that you're having problems with is the exact same,and it was working when i pulled out,if you need measurements from it i can do it and you compare to see what is faulty,still have the LEDs and power supply also,but i don't know how to hotwire the PSU for it to supply voltage to this board.
            edit:you should also check the LED stripes inside the panel,it is not rare for them to burn out for this model.
            • olegau
              • Aug 2017
              • 15
              It would be great but a lot of hassle. Maybe take measurements only the power board without the load. But it may not work because the PSU will not get feedback from other boards.
                Can we see the pictures of the whole back side of the TV showing all the boards?
                What DCV do you have on
                CN1002:
                LD_ERR
                LED_ON
                GL_CTRL
                CN1003:
                1-PWM1
                2-PWM8
                3-PWM1
                4-PWM8
                Also leave the probe on one of the (+OUT) and record what you read when the TV is OFF and when the TV is turned on to see if it goes up to more than 122v and then drops down to 122V or less.
                  Is this your power supply board?
                  Sony 1-474-300-11 (APS-293, APS-293(CH)) G6 Power Supply.
                  Pictures provided by shojimmy.
                  • olegau
                    • Aug 2017
                    • 15
                    Yes, that is my power supply board.
                    • olegau
                      • Aug 2017
                      • 15
                      Pics of the TV:
                      General view
                      Connections of PCU
                      Connections of T-CON
                      • olegau
                        • Aug 2017
                        • 15
                        Today I was following an advice to disconnect one after another the T-CON two flat ribbons going down to the screen. Nothing happened.
                        • Biruslapio
                          • Nov 2013
                          • 552
                          • Brasil
                          This model generaly fails the main board,LEDs,display(crap quality) or ribbon cables between the T-CON and display,the power supply and inverter sells for nothing because they are reliable,maybe the T-CON fuse is blown.
                          Do you have sound AND picture?Aiming a flashlight at the display works,but you need to put back the Display<>T-CON flat cables.
                          • olegau
                            • Aug 2017
                            • 15
                            There is sound but I cannot say about the picture because the screen is black.
                              Read Post #8.
                              • olegau
                                • Aug 2017
                                • 15
                                Measurements:
                                CN1002: off/on
                                LD_ERR 0/0V something moving around 0 Volts
                                LED_ON 0.1/3.3V
                                GL_CTRL 0.7/0.0V
                                CN1003: off/on
                                1-PWM1 0/3V goes up slowly from 0V to 3.0V
                                2-PWM8 0/3V goes up slowly
                                3-PWM1 0/3V goes up slowly
                                4-PWM8 0/3V goes up slowly
                                "Also leave the probe on one of the (+OUT) and record what you read when the TV is OFF and when the TV is turned on to see if it goes up to more than 122v and then drops down to 122V or less".
                                All measurements of connection SN1001 show quick jump voltage from approximately 0V to 140V and then quick down to constant 122V.
                                  Originally posted by olegau
                                  Measurements:
                                  CN1002: off/on
                                  LED_ON 0.1/3.3V
                                  GL_CTRL 0.7/0.0V
                                  CN1003: off/on
                                  The booster circuit is working, I need to look at the LED driver board circuit in more details to give you the test points.
                                  • ryandesign
                                    Sony Bravia KDL-40v4100 has no picture but has power, backlight, and sound
                                    by ryandesign
                                    Hello! I would like to repair my father's Sony Bravia KDL-40v4100 LCD TV. It was in perfect working order the last time I used it before the pandemic. Then it sat plugged in but unused for a year or more. And now everything still works except that there is no picture on the screen. A relay can be heard to click when the power cable is connected. When the power button is pressed there is a green power LED and then the backlight turns on. If I connect an HDMI cable and play something with audio I can hear it through the speakers. The remote control buttons are recognized. There is just never anything...
                                    05-30-2021, 01:07 PM
                                  • triplefour
                                    by triplefour
                                    09-13-2023, 10:43 PM
                                  • justin35
                                    Sony bravia kdl-43w755c - boot loop
                                    by justin35
                                    i have this sony bravia kdl-43w755c which boot loops. After sony logo, it shows the android animation loading then it restarts…
                                    from what i read online it looks to be an emmc issue…
                                    i’m not familiar with this kind of tv repairs… i’m repairing laptops and gpu’s…
                                    i took out the board and say an samsung 16gb emmc
                                    i don’t have an exact replacement, but i have a few 32 and 64gb emms’s from laptops…
                                    i could try to put one instead of the 16gb one, but will it work?
                                    where do i get the software from?
                                    any help will be much appreciated!...
                                    03-06-2024, 12:26 PM
                                    Sony Bravia 22" LED Full HD TV KLV-22P402B Schematic
                                    Sony Bravia 22" LED Full HD TV KLV-22P402B Schematic...
                                    10-16-2024, 05:15 AM
                                  • DanPoka
                                    Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
                                    by DanPoka
                                    I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
                                    Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
                                    This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
                                    02-15-2025, 05:05 AM
