Skyworth 24E22 no power
  • yobbgsm
    • May 2017
    • 63
    Hi Mates,
    I am new to TV repair, looks fascinating to me. This is no power at all, no standby light. Can someone help me figure out what's the issue of this 24" led tv I am working with? What I noticed is there was no voltage on DC (12V, 24v) part of transformer, not sure if the transformer is defective? I already tried to replace the mosfet even I know it is still good, diodes also had good reading.
    Please help.
    Thank you.
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Skyworth 24E22 no power
    If you put your meter probes on M7 (black lead) and M8 (red lead ) and check what DC voltage is there when the set is plugged in (approx 160V DC) and on and when you come out of standby.
    Be careful since that's the live side of the power supply connected to the mains electricity supply.
    • thoma
      • Sep 2012
      • 268
      https://www.youtube.com/watch?v=uN1fNQGhyyM
      http://www.skyworthservice.com/2014/...-skyworth.html
      What is the name of your SMPS Power supply any sticker with name or
      numbers?
      168P-P24? stand on the white sticker but can not read
      • yobbgsm
        • May 2017
        • 63
        I will look into it later and will post result, thank you for you response.
        • yobbgsm
          • May 2017
          • 63
          numbers?
          • yobbgsm
            • May 2017
            • 63
            Hi dick_barton,
            I am getting 298 DC volts on M7 M8, (Capacitor) is that normal?
            @thoma,
            it's 168P-P24EQB-W1
            5800-P24EQB-WP00
            Thanks mate.
            • thoma
              • Sep 2012
              • 268
              http://tel-spb.ru/remont-tv-lcd/supra-stv-lc24t820fl
              scroll down until
              Скачать: Схема Chassis MSD309B Schematic diagram.
              download this schematic of power supply inside
              • dick_barton
                • Aug 2015
                • 6643
                • Wales
                Hello Thoma, Unfortunately the schematic does not appear to match the power supply shown in post #1
                • thoma
                  • Sep 2012
                  • 268
                  SUPRA STV-LC24660FL
                  Chassis: 5800-A8M280-OP10
                  Panel: HM236WU3-100
                  T-con: HM236WU1-100 X0.0
                  Inverter: integrated into PSU
                  Inverter IC: OB3362HP
                  Inverter FET:ME15N10-6
                  Inverter Trans: IVTEL 1900033 1036
                  Power: 168P-P24EQB-W2 - 580-P24EQB-WP10
                  Power IC: OB2273 (6pin)
                  Power Fet: JCS4N65F
                  MAIN: 5800-A8M280-OP10 Ver10.00
                  IC Main board: FLASH: Q32B-104HIP; SOUND: 1517 (20pin)
                  Tuner: ET-9Z2E-CF106H
                  Remote: RC13b
                  • dick_barton
                    • Aug 2015
                    • 6643
                    • Wales
                    Originally posted by yobbgsm
                    Hi dick_barton,
                    @thoma,
                    it's 168P-P24EQB-W1
                    5800-P24EQB-WP00
                    Thanks mate.
                    What is the voltage rating as written on the capacitor. I would have though the voltage read on the capacitor would be higher, maybe at 390V.
                    • thoma
                      • Sep 2012
                      • 268
                      http://televid-sib.ru/index.php?topi...27050#msg27050
                      • yobbgsm
                        • May 2017
                        • 63
                        Hi dick_barton,
                        It says 450V, 68uF. Thank you.
                        Will look into schematic thoma, thank you.
                        • thoma
                          • Sep 2012
                          • 268
                          https://cdn.badcaps-static.com/pdfs/...8b2a6bf076.pdf
                          • yobbgsm
                            • May 2017
                            • 63
                            Hi thoma,
                            Looks like you are referring to the IC behind the board, so after checking all, seems to me that IC was the problem. This is very helpful in my troubleshooting experience.
                            • thoma
                              • Sep 2012
                              • 268
                              Does your power supply react to heat and freeze?
                              Take a hair dryer and push the warm air to the power supply and the mainboard
                              the same do with freeze spray
                              Reaction?
                              • thoma
                                • Sep 2012
                                • 268
                                datasheet OB3362RP
                                • dick_barton
                                  • Aug 2015
                                  • 6643
                                  • Wales
                                  Hi dick_barton,
                                  Looking at the back of the power supply photo in post #1 it says 300V so your voltage looks fine. There is also 17V marked on the board which you can check it is there.
                                  There are a lot of solder joints (red boxes) that need to be soldered again that can be seen on the back of the board.
                                  Have you checked both fuses.
                                  What is the value of the resistor in the yellow box
                                  • thoma
                                    • Sep 2012
                                    • 268
                                    http://manualbase.ru/index.php?do=fi...file&lid=48419
                                    schematic stv-lc24660
                                    • thoma
                                      • Sep 2012
                                      • 268
                                      small lcd like this 24 inch do not have a pfc circuit
                                      therefore the voltage at the big capacitor is about 300V
                                      in greater lcds more than 32 inch there is a pfc circuit
                                      so the voltage on the big capacitor is about 400V
                                      you can see it in the schematic if there is no pfc
                                      the big capacitor is directly behind the Bridgerectifier
                                      if there is a pfc there is a pfc ic a power mos fet a powerdiode
                                      a inductivity before the big capacity
                                      google pfc circuits
                                      regards thoma
                                      • yobbgsm
                                        • May 2017
                                        • 63
                                        Hi dick_barton
                                        Those are the joints that I de-soldered when I off the circuit the mosfet and diodes on the other side. Both fuses are good. I will check the resistor later. Thank you for your patience.
                                        • PantherDave
                                          by PantherDave
                                          Hi all!
                                          05-29-2024, 02:01 PM
                                        • GLISIT
                                          by GLISIT
                                          01-16-2025, 02:29 PM
                                          09-06-2024, 05:59 AM
                                          HP Pavilion Power 580-187nz Pavilion Power i7-8700 Specification for Upgrade or Repair
                                          This specification for the HP Pavilion Power 580-187nz can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Power 580-187nz boardview and Pavilion Power 580-187nz schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-12-2024, 02:15 PM
