Sony KDL-46W5500 got backlights, no picture.
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    Have this TV which turns the backlights on but shows no picture. Have quickly checked voltages, may have missed some on the power supply and main but overall it looks ok. Responds to buttons, backlight brightness changes if i press the "Home" button.
    Tcon fuse is good. Tcon is generating all drive voltages for the panel. Scoped some of the LVDS pins on the Tcon side, it looks to me like it's getting data from the mainboard.
    Reflowed both BGAs on the Tcon, although the board underside did not show any signs of them getting hot. No change.
    Would this pretty much guarantee the Tcon is bad, or should i dig deeper into the mainboard as well?
    A working TV? How boring!
  • attainteddragon
    • Apr 2013
    • 764
    • australia
    Re: Sony KDL-46W5500 got backlights, no picture.
    disconnect one half of the t-con, where it attaches to the panel and see if you get half a pic and then try the opposing half.
    WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?
    • vinceroger69
      • Mar 2012
      • 6714
      • uk
      Edit! was typing this when above poster did too
      do you get anyting on the screen if you remove one of the ribbon cables on the the tcon try doing this too the left and right ribbon cables.
      • Th3_uN1Qu3
        Believe in
        • Jul 2010
        • 6031
        No picture with either half.
        • dick_barton
          • Aug 2015
          • 6642
          • Wales
          Check very carefully to see if there is a small crack in the panel, perhaps in one of the corners.
          • dskall
            • Oct 2016
            • 2905
            • usa
            Are you getting data coming out of t-con
            • Th3_uN1Qu3
              Believe in
              • Jul 2010
              • 6031
              To my uneducated eye, i would say "not really", hence why i suspect one of the processors on the T-Con to be faulty, as there is definitely data going IN via the LVDS cable. If you could show an example waveform though, and which pins to scope, i would be grateful.
                The T-con data output is also LVDS; the purpose of the T-con is essentially to generate the row/column scan and latch signals in sync with "re-timed" LVDS data. (Hence "timing controller"). If you see no LVDS out, check the crystal on the board, and all voltage regulators/buck converters.
                • dskall
                  • Oct 2016
                  • 2905
                  • usa
                  Hey tom66 have you thought about writing a book on plasma tv repair. Explaining how they work and troubleshooting?
                    Yes and I gave up because I didn't have the time.
                    There is far too much to explain.
                    • dskall
                      • Oct 2016
                      • 2905
                      • usa
                      Maybe some short guides on specific components.
                        I've already posted several.
                        • nomoresonys
                          • 12145
                          • U.S.
                          Could be the tcon, shop jimmy is out of stock, some on ebay, took a quick look, saw one for 28 dollars or so, there's probably more there, just took a fast look.
                          • Th3_uN1Qu3
                            Believe in
                            • Jul 2010
                            • 6031
                            Received a new Tcon - still no picture.
                            • dskall
                              • Oct 2016
                              • 2905
                              • usa
                              I have a tv that has a separate frc. I saw data going in but nothing coming out so I replaced frc. Still have same problem. So I wonder if main board needs to send enable signal to enable board. You have checked new t-con to be good?
                              • nomoresonys
                                • 12145
                                • U.S.
                                Did you ever figure out what was wrong?
                                • Th3_uN1Qu3
                                  Believe in
                                  • Jul 2010
                                  • 6031
                                  No, we gave it back and the boss put the replacement Tcon up for sale.
                                  • nomoresonys
                                    • 12145
                                    • U.S.
                                    Ok thanks.
                                    • Daren87
                                      Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                                      by Daren87
                                      I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                                      08-13-2023, 03:25 PM
                                    • CyberPhoenix
                                      Issue with picture quality of Sony bravia TV
                                      by CyberPhoenix
                                      Hello, Last week I bought the 50" Sony X80j tv everything was working fine, untill I plugged the tv in a ups power supply 650va the tv remote control became unresponsive and the TV became laggy after a while the picture quality isn't the same as before the tv seems less brighter and the picture is somehow blurry, people's faces don't look as natural as before, there is a mini orange-pink tint to the edge of people's faces especially in NETFLIX Dolby Vision like in One Piece ep1 Alvida skin tone, my intention was to protect the tv but something went wrong I checked the ups with a multimeter,...
                                      01-22-2024, 02:08 AM
                                    • noisykid
                                      Sony XBR-85X950G Gray horizontal lines and vertical picture shift diagnosis?
                                      by noisykid
                                      5.5 year old 85 inch Sony Bravia X950G started showing gray horizontal lines across the bottom of the screen and the picture shifts slightly vertically when it happens. The lines sometimes get bigger/smaller vertically and bounce back. See the video for the problem. It seems to be happening after it warms up after an hour or so. Happens regardless of source. Right now there's nothing but power cable connected and it's happening. We did hook up a new Nintendo Switch to our HDMI switching receiver today, and played for a while with no issues, but this problem didn't occur til a few hours later while...
                                      12-30-2024, 07:15 PM
                                    • thelankanguy
                                      Sony KD-55X9000F TCON Issue
                                      by thelankanguy
                                      The TV shows a black screen with no image.
                                      TCON ribbon connectors were disconnected individually for image and there was no half image even.
                                      Later both ribbons were disconnected and TCON voltages were tested.
                                      12V, 3.3V, 1.8V were seen present but VONE signal reads 0V.
                                      There is also a short to ground in this circled inductor.
                                      Is this a TCON issue or something else ?...
                                      12-13-2024, 12:27 AM
                                    • bbrain
                                      Sony KD-55AG9 TCON?
                                      by bbrain
                                      I have this problem with my Sony 55' AG9.
                                      It flashes 4x.
                                      I have found the service manual, and seems it is the TCON.
                                      Before I buy a TCON can someone check the vid?
                                      Thanks in advance!...
                                      09-19-2024, 10:50 AM
