Samsung PN60E530 plasma tv power on issue
  • shelby5041
    • Feb 2009
    • 1505
    • united states of america usa
    Re: Samsung PN60E530 plasma tv power on issue
    bad news......power on ssue fixed but found out panel bad
    has thin black horizontal line groups in 2 areas
    its a veru veru common samsung product/design failure from what i have researched
    should be a lawsuit one day
    • shelby5041
      • Feb 2009
      • 1505
      hi...my research said panel was bad per many other posts in badcaps...
      ..but for the heck of it i reseated y buffers for the 3rd time....but this time i cleaned with alcohol and i think some of the lines disappeared...so maybe its not a panell issue in my case
      i will do more testing and follow up
      • Lloyd6202
        • May 2017
        • 59
        I have the same issue right now with a 58 inch samsung and ive narrowed it down to the y sus boards each top and bottom both have blown chips..waiting for parts now to swap them out
        • shelby5041
          • Feb 2009
          • 1505
          Not same issue as me.....mine was ysus urs is y buffers
          FYI....cleaned ybuffer connectors with alcohol and black horizontal lines gone
          Makes me wonder how many people tossed out Samsung plasma so with horizontal lines thinking panel was bad due to so many posts online saying that...just reseating connector didn't work for me....cleaning with alcohol worked...most people I saw in posts just reseated connectors and when it didn't fix lines they assumed panel bad
          • thoma
            • Sep 2012
            • 268
            WAIT UNTIL GET MANUAL APPEARS!!!!!!
            • GLISIT
              by GLISIT
              01-16-2025, 02:29 PM
            • lp20th
              Samsung Plasma TV Power Supply Issue
              by lp20th
              I have a vintage 2008 Samsung 50” Plasma TV, Model code PN50A550S1FXZA with a power supply part number BN44-00222A. I repaired the power supply board several years ago finding a couple of cold solder joints on the back side of the board and it's worked great up until now. Recently a fried sound occurred with the smell of burnt electronics and the TV shut down. Trying to turn it back on yielded the typical relay clicking with no TV boot up. Upon investigation, removing feeds to the other boards within the TV it was found that disconnecting the logic board from the power supply allowed the...
              11-28-2023, 10:28 AM
            • CDNBrewer
              Samsung Plasma PN43D450A2D No Power
              by CDNBrewer
              Hello, I have a Samsung Plasma TV - Model # PN43D450A2D
              This was my parents TV and the initial symptoms were that the display was hard to turn on with the display making various clicking noises until one day it would not turn on anymore.
              I took a look and found a couple 1000uF capacitors (i believe on the low voltage size) that had leaked out their electrolyte and did not test well on a tester. I replaced them but still no dice.
              When the TV is plugged in, there is no clicking, LED status lights (on PCB boards or the front display) and the power on button...
              03-02-2025, 04:59 PM
            • Cookybaby
              Samsung UN60ES6500FXZA Power Supply Issue
              by Cookybaby
              Hello Everyone, this is my first post and I am excited to be a part of such a great community. I've been reading these forums for awhile and there really is some good friendly people here. No bashing and being rude like 90% of other forums Ive been to. Lets get to the good stuff.
              I have two years of college in Electronics Engineering Technology. Ive been tinkering with electronics sine about 1990. I know enough just to be dangerous, so be gentle.
              Make: Samsung
              Model: UN60ES6500FXZA
              Power Supply P/N: BN44-00525A
              Symptoms: The TV was...
              08-20-2023, 12:26 PM
            • Drewwol11
              Samsung QN49Q70RAFXZA Power Cycling Issue
              by Drewwol11
              My Samsung TV display recently stopped working while I was playing PS4 (no storm or anything to indicate a power surge). I could still hear audio through the PS4 but no display. The TV kept trying to turn on but would turn off after a second or two.
              I tried the obvious troubleshooting steps like unplugging, replugging, trying different outlets and power cords with no luck. Someone on another forum suggested that it may be a power supply issue so I purchased a replacement power supply board but that did not help. I then disconnected the main board from the...
              08-31-2021, 09:32 AM
