Panasonic TX-37LZD80F repair, intermitent relay click, low standby 5V, photocoupler
  • Chungalin
    • Jul 2014
    • 423
    • Spain
    This LCD TV had an intermittent failure consisting of unstable 5V standby. When standby 5V drop to 3V, relays click and TV resets. Sometimes it does this from cold state.
    I tried to heat all components related to 5V standby (switching regulator IC7000 SanKen STR-A6159, diodes, photocoupler PC7000 Panasonic CNC1S171R "3171 R", shunt regulator IC7001 Mitsumi MM1431AT "1431A"), with no changes in behaviour. Tried in cold state and hot state, apparently no differences. Vibration and knock test negative.
    I changed STR-A6159 with STR-A6151, no improvement. Since at that moment I couldn't identify photocouplers and shunt regulators (Mitsumi and Microchip logos are very similar!), I swapped PC7000 with PC7001, and IC7001 with IC7005. No problems after that.
    I found a latin repair forum talking about a similar issue in TC-32LX85X and they fixed it by replacing Panasonic photocouplers.
    http://www.dtforum.info/index.php?topic=83770.0;all
    Then, another latin blogger with same issue stating that he couldn't confirm that photocoupler was "really" bad, but that failure was definitively related to it.
    http://13norte.blogspot.com.es/2012/...-enciende.html
    Sometimes I've found what I call "creeping metallization" to occur between legs of IR receivers or tactswitches, causing intermittent or permanent failures. I haven't observed this fenomena in this case, but I've cleaned both photocouplers before resoldering. Let's see how long it lasts.
    PSU is TXN/P10NDA, and PCB marking is TNPA4467. Chassis LH69.
    Re: Panasonic TX-37LZD80F repair, intermitent relay click, low standby 5V, photocoupl
    You should check the resistors network that drive the LED side of the OPTO, they usually use very high value resistor to drop the line Voltage to drive the LED in the OPTO.
      I had a bad optocoupler cause an intermittent 7-blink error on my Panasonic plasma TV (TX-P42ST50B). I've also seen some older LG plasma TVs and one LCD TV model that suffer from failed optocouplers causing a variety of symptoms including low power rails or cycling power.
      It's a surprisingly common fault.
      • dskall
        • Oct 2016
        • 2905
        • usa
        What is best way to test optocoupler
          CTR.
          https://www.renesas.com/en-eu/produc...ology/ctr.html
          http://www.edn.com/design/test-and-m...ocoupler-s-CTR
          • attainteddragon
            • Apr 2013
            • 764
            • australia
            i have a rough method for quick checking.
            you use 2x dmm's
            if you diode test the diode side, you will see a resistance on the led side as it conducts.
            it's not definitive, but it works for a quick rule it out test.
            WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?
            • dskall
              • Oct 2016
              • 2905
              • usa
              Is it true that optocouplers degrade and get out of tolerance?
              • Th3_uN1Qu3
                Believe in
                • Jul 2010
                • 6031
                Yes. Optocouplers use infrared LEDs, which, like all other phosphor-based things that emit light, get dimmer with age.
                A working TV? How boring!
                • Chungalin
                  • Jul 2014
                  • 423
                  • Spain
                  Agree with everything, but I’ve returned the TV without replacing any photocoupler, and the only thing I’ve done is unsolder both photocouplers and resolder them in swapped position. Same for shunt regulators. Remember it was an intermittent failure. I’ve insisted to customer to bring back the TV in case of failing again soon, so we’ll know if photocouplers are really unreliable or not.
                  • Rensiee
                    Panasonic TH-50PX8EA Black screen, only relay clicks
                    by Rensiee
                    I have been reading a few threads on here regarding Panasonic plasma tv's. I've found one thread which explains the same problem as mine, unfortunately the thread has not been completed.
                    I got a free tv (TH-50PX8EA) from a friend which shows no screen. When plugged in only one red light shows up and when pushing the ON button, the red LED turns of and will only turn on again when pressing the ON button again.
                    When plugging in the TV i hear two relays click fast and after a few seconds the third relay clicks.
                    I have measured the voltage in the VSUS line, which...
                    06-18-2024, 12:58 PM
                  • BobbyMJ
                    Panasonic TC-P60S30 - no standby voltage
                    by BobbyMJ
                    Hi All,
                    Wanting to learn some electronics repair skills.
                    I found a non working Panasonic TC-P60S30 and this is my first project / attempt.
                    So far I have found a blown cap on the main power supply board.
                    After replacing it there's still no standby power.
                    Poked around and found a resistor on the PSUB power supply board that measures open.
                    An online resistor calculator shows this is a 93k ohm resister.
                    My questions:
                    Is that correct, 93k ohms?
                    Is it a fusible resistor?
                    Lastly, how do I know what wattage?...
                    05-14-2025, 06:42 PM
                  • CoinCoin88
                    Garage door RX unit (Cardin S38C) does not short relay to send opening signal
                    by CoinCoin88
                    I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
                    Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
                    09-15-2025, 03:36 AM
                  • Xrious
                    Panasonic TH-55FX600 - No standby LED
                    by Xrious
                    Got a TH-55FX600 that is showing no signs of life.
                    Outputs from the P board look good, but no 12V on the A board.
                    Very similar to https://www.badcaps.net/forum/troubl...3e-identidy-ic but where Tibd has 3.3v on the EN pin I have nothing, no voltage at all.
                    Looking at the diagram for the IC I can see the enable is W_OPCTRL9, but I can't find a source for this, can anyone help please?
                    Stu
                    05-02-2024, 08:56 PM
                  • BigPete
                    Panasonic Heatpump Dryer Repair
                    by BigPete
                    I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
                    The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
                    In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
                    Unfortunately the whole machine has to come apart to fix it.
                    I have...
                    11-01-2025, 06:40 PM
