Panasonic VT60 Plasma Panel drive modification?
  • Plasmafan92
    • Jul 2017
    • 8
    Hey guys, I've done some digging around and it seems that the ZT60 panasonic plasma panel drive has been tweaked when compared to the VT60.
    ZT60/ZT65 holds the upper hand in anti-reflection screen coating and general “cleanliness” of the image – it's as if the ZT's native [IFC] level is set somewhere between “Off” and “Min“, resulting in a squeaky clean output with marginally less dynamic false contouring (DFC).
    http://www.hdtvtest.co.uk/news/zt-201403233655.htm
    Video mentioning the panel drive tweaking
    With my VT60 setting motion smoothing from off to min results in a jump of motion resolution equal or greater than 1200 lines vs 1080 lines or slightly lower on off. I would love for the panel to natively support a higher especially when using game mode.
    I would really appreciate if you experts could guide me in the right direction as to what part or board i would need to change from my 65VT60 to get this improved panel drive performance. The ZT60 and VT60 are basically the same besides the anti glare filter and that panel drive tweak so i know it would work if i exchanged the correct parts if I'm able to find it. Here is the 65ZT60 and the 65VT60 layout side by side:
  • Moreno83
    • Jun 2014
    • 2008
    • The Netherlands
    Re: Panasonic VT60 Plasma Panel drive modification?
    The ZT has a "Studio Master Panel" and the VT has a "Infinite black panel".
    I don't think its just software.
      It probably is just software. Swapping the A board would probably do it.
      The panel is the same on ST50 and GT50 for instance.
      • Plasmafan92
        • Jul 2017
        • 8
        Thanks for the help guys. Yeah i was hoping for it to be anything other than the A board as that is somewhat expensive. It's not even a money issue, the board is extremely hard to find since it's for the 65ZT60 variation, and it has to be the board for the 65 inch tv because of the three fans. Anyways in the near future when i decide to do this i will bump the thread and share my results, the difference should be immediately noticeable with a test pattern. Thanks again guys.
        • Plasmafan92
          • Jul 2017
          • 8
          Ok so i managed to get the A board for the 65ZT60 panel and when i opened my 65VT60 i noticed it only had 2 fans, i thought it was supposed to have 3 since it is a bigger size. Anyways i connect everything and the board works, upon powering up i am greeted with the studio master panel logo. There's one major problem though, the boards fan connector is wider than the fan cable on my tv. I can connect it but there's like 2 pins on the connector that are open. Every 10 seconds i am getting this message:
          And then the tv shuts off automatically after a couple of minutes. This is the connector:
          Can anyone help me? I assume this happens because this A board has a wider connector to accomodate 3 fans instead of 2 that i have.
          • jetadm123
            • 2169
            With the fan connector plugged into the new A board, do both of your fans spin up? On the new A board, I count 9 solder pads coming out of the back of the black connector. Correct? If yes, that's probably power, ground and sense (output pulse sent to cpu to tell it fan is running) pins for each fan. You can trace the wiring from each fan and/or use a meter to determine which pin is which. Due to the different connectors on the A boards, I'm thinking that maybe one (or both) of the sense outputs on one (or both) of the fans is not properly connected.
            • Plasmafan92
              • Jul 2017
              • 8
              That's correct, the new board has 9 solder pads but that white fan cable has 6 connectors only, that's why the tv keeps shutting down and showing the message. When i try to connect it both fans never spin. I need to find that white connector with 9 pins but i don't even know what part it is.
              • Moreno83
                • Jun 2014
                • 2008
                • The Netherlands
                Why not jump the cables? I think a small wire from 1 of the fans to the sense pad on the mainboard will do the trick. You need to fool the tv...
                • Plasmafan92
                  • Jul 2017
                  • 8
                  I might try to split the cables as a last resort, i would have to remove the fan cables from that 6 pin white connector and then how would i even keep them inside if it works. The best solution would be to find someone selling all 3 65ZT60 fans along with the cables that has the 9 pins in the end. I haven't seen that sold anywhere.
                  • Plasmafan92
                    • Jul 2017
                    • 8
                    Update: I managed to find an 60ZT60 A board online and ordered it, i'm not parting with the 65ZT60 board just yet until i know for sure the 60 board works, it should work since it has the 6 pin connector because the 60 inch only has 2 fans just like my 65VT60.
                      You shouldn't put a 60" board in 65", as the panel drive is different. It can cause maldischarge and SC/SS failure as the ER waveforms are misaligned with the panel capacitance. The smaller panel has lower capacitance, so the resonance circuit is tuned differently and the timings are subtly different; this will cause extra power dissipation in the ER/SUS IGBTs and may cause a pink or cyan tint on the brightest parts of the image.
                      For the fan issue, it looks like there are three groups of three pins, for each fan: 12V, GND, Sense, 12V, GND, Sense, 12V, GND, Sense. It would be reasonably trivial to solder a wire between the two sense lines of one fan, so the TV sees two fans spinning at the same rate, and rig this up to the two fan configuration you have. On the other hand, you may also be able to get a fan assembly for the three fan version of your set, so have a look for that as well.
                      I believe Panasonic revised the fans on these units due to complaints of a "fridge-like sound" from the TV. So you might have a later model with only two fans.
                      • Plasmafan92
                        • Jul 2017
                        • 8
                        Tom you are right, I didn't take into account the differences since the boards look more or less the same. I don't want to take a chance breaking my tv since it was a pain to even find it in the first place. I think I'm going to take the safe way out and wait for someone to sell the three fans along with the 9 pin cable. It should be easier than finding the A board. I'll bump the thread when everything is completed, at least I know the board works and the panel has all the benefits of the ZT besides the filter.
                        • Moreno83
                          • Jun 2014
                          • 2008
                          • The Netherlands
                          Why wait out , just solder a wire to the sense pad.
                          • SurrealMustard
                            What parts can be salvaged from a plasma with a damaged display panel?
                            by SurrealMustard
                            I recently found myself the proud owner of a later-model Samsung plasma (the PN59D7000 for those keeping score at home) whose panel was, unfortunately, damaged in transport. I'm now preparing to part it out, but am curious as to whether or not any damage would have come to any of the components by attempting to power it up with the panel being broken. I read in one Avsforum thread (for whatever that's worth 😂) that the "scan driver boards" (by which I assume he means buffer boards) could be impacted by doing so. Is that actually the case? If so, since I don't intend on selling bad...
                            03-09-2025, 08:29 PM
                          • jm1234
                            Panasonic plasma TX-P42ST50 - 6 blinks
                            by jm1234
                            anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                            It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                            I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                            I checked that board for any obvious faults...
                            05-22-2024, 06:59 AM
                          • stecos
                            Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
                            by stecos
                            Hi everyone!
                            I happened several times, in the search for help from the web, to consult this very interesting forum.
                            So I decided to sign up and I intend to participate actively by making available my knowledge and experience on the subject, I'm a new user but at the same time I'm old in the sense that I have 4 decades of experience in repairing and designing electronics but above all I'm a great passionate about the subject.
                            Having said that I come to the gist of my post on the forum as the title suggests.
                            For my passion for technology I'm now collecting several...
                            11-28-2022, 11:39 AM
                          • canadaboy25
                            Panasonic TH-50PX60U Plasma Shorted Panel Drivers
                            by canadaboy25
                            Hey guys, I have a Panasonic plasma here with two black rectangles in the display. As you can see from the picture, they affect the menus as well. Both black rectangles extend to exactly the center of the screen.
                            I started with the bottom right black bar as it was closest to me on the desk. I found that the two 6.8 ohm resistors pictured were open circuit. I removed them to verify and they were blown. According to the schematic, these are for the 75V VDA rail.
                            I then did a diode mode test on the load side of the resistor and sure enough there was a short. I disconnected...
                            01-13-2021, 05:54 PM
                          • Alicat
                            Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
                            by Alicat
                            Stopped by this site trying to fix my parents Panasonic Plasma TV.
                            Model number is TH-50PZ85U
                            Power comes on and the red power light stays on solid.
                            Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
                            I also hear a few clicks.
                            I also think my parents said there was a thunderstorm and the TV failed after that.
                            Section 6 in the service manual talks about power and no screen,...
                            10-30-2024, 10:09 AM
