Pioneer PDP-5070 issue
  • Jbrownin
    • Jul 2017
    • 4
    • US
    Hello there.
    New member, enthusiast. My display just developed an issue that I'm hopeful is addressable via a board(s) replacement. As shown in the attached image, display has a horizontal bar on lower half of screen, with a split image.No blinking LEDs. Based on my rather recent investigation, seems this is likely a lower Scan A assy(buffer board?) fault. Perhaps also Y main drive and Y sub drive?
    Any guidance on a fix/ replacement part(s) and also reputable source of such parts (no way ebay) would be greatly appreciated. I'm aware of the trap switch and also the need to allow for V discharge prior to wrenching on stuff...
    I'm hoping on a fix vs junking the TV, which up until yesterday had an exceptional picture (calibrated, of course).
    Thank you
    Kindest regards
    JB
    Re: Pioneer PDP-5070 issue
    This looks like a scan buffer board failure. However before diagnosing this fault make sure to check the panel itself for cracks. I can see a thin black line on the panel which looks to be unilluminated in the fault area. If the panel were to be cracked in that area, you might see this fault. Sometimes, although it is exceedingly rare on well-designed panels like Pioneer ones, the glass can crack under use, and it can be almost invisible if it is right on an edge.
    Example of possible panel crack fault: https://www.youtube.com/watch?v=e26jLO-kJJQ
    • Jbrownin
      • Jul 2017
      • 4
      • US
      Thank you. I went to re-inspect with a good flashlight, and i indeed see a crack (almost like a bb shot/ star pattern). Panel is toast... thank you for your time and insight.
      Cheers
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        That's really sharp eyes there Tom66 to see the unilluminated line in that photo.
        • CDNBrewer
          Running out of Ideas, hoping someone smart can provide some for my ONKYO TX-SR353 Receiver
          by CDNBrewer
          Hello Everyone,
          I have an Onkyo TX-SR353 Audio/Video Receiver (5.1 ch with HDMI) that I am having a really hard time diagnosing and I'm about to throw this in the junk and go buy a new unit that is on sale until the 7th.
          Symptoms:
          • Intermittent (part of the reason why i'm having a hard time isolating problem), sometimes will work for 10+h at a time without issue
          • Original symptom was wife reported loud banging noise (like someone was banging on the wall with their fists) from the LEFT SURROUND speaker and then the unit shut off.
          • I swapped the Left and Right surround
          08-05-2025, 09:29 PM
        • rounin
          MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
          by rounin
          🛠 Original Issue
          ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
          04-19-2025, 01:18 AM
        • GraphicMan
          Pioneer A-205 faint noise/hiss issue
          by GraphicMan
          as the title says, i noticed a faint noise/hiss when there is nothing playing that i dont think i have had with this unit before ever, i have not changed its location
          what makes it more weird, this noise is gone almost completely if my hand gets within 5cm or less close to it (close to the panel)!!
          out of curiosity what does that mean?
          thanks
          05-19-2024, 11:45 AM
        • shahnld
          Lenovo legion 5 pro startup issue
          by shahnld
          Good day Experts
          I have a lenovo Legion pro 5 16ACH6H with AMD RYZEN 7 5800H and RTX3070,.
          A weird issue has troubled me. If i power on off the laptop 20 times then only power LED will lit but no fan spin no display. At this stage gpu, vram. DDR voltage. 5v 3.3v 1.8v and the rest are present and cpu core is stuck at 0.84v.
          And sometimes lets say the 21st time it will boot perfectly and there is image and everything is working perfectly and at this stage i see cpu core...
          08-24-2025, 12:31 PM
        • ahmarzo
          Acer laptop battery draining issue
          by ahmarzo
          Have a acer laptop ex215-22 with motherboard part no daz8emb18a0 the issue is the battery gets drain overnight upto 25-30 percent even when switched off / shutdown.even after ssd is removed and laptop off with button the battery keeps draining.i have updated the bios but same issue have tried another new battery and the charging works fine only issue is battery is discharging when connected to motherboard in off condition.
          Help me to diagnose this issue as there is no shortage in the inputs MOSFET
          08-02-2025, 06:39 AM
