No backlight on Sharp LC-32LB261U
  • lkvee
    • Feb 2009
    • 198
    Red LED blinks 8 times before turning steady blue, but I see the "No Signal" image without backlighting.
    At CN9101, I get these readings on steady red LED (standby):
    NC gives 0 volts
    +12V gives 12.59V
    +12V gives 12.59V
    +12VAU gives 12.47V
    GND gives 0V
    GND gives 0V
    NC gives 0.057V
    DIM ON/OFF gives 0V
    At CN9101, I get these readings on steady blue LED (ON):
    NC gives 0V
    +12V gives 12.58V
    +12V gives 12.58V
    +12VAU gives 12.33V
    GND gives 0V
    GND gives 0V
    NC gives 3.35V
    DIM ON/OFF gives 2.964V
    At CN8101, I get these readings during steady blue LED (ON):
    VLED+ gives 12.38V
    VLED+ gives 12.38V
    N/A gives 0V
    N/A gives 0V
    LED1 gives 0V
    LED1 gives 0V
    Three filter caps spec'ed for 56uF and 450V give these readings:
    C9103, C9102, and C9101 give 0V when power is disconnected
    C9103, C9102, and C9101 give 166V when LED is steady red (standby)
    C9103, C9102, and C9101 give 166V when LED is steady blue (ON)
    Thinking LED1 and main cap readings are off, but not sure what to examine and/or replace next. Gratuitous picture T-Con board included.
  • cliff_hootarski
    • Jul 2006
    • 411
    Re: No backlight on Sharp LC-32LB261U
    Connection CN9101 is a 16 pin connector. We need to know if the main board is telling the power supply to come ON. What is the voltage reading of pin 2 ON/OFF?
    • dskall
      • Oct 2016
      • 2905
      • usa
      What are you getting when first powering on at VLED
        "DIM ON/OFF gives 2.964V" Do you mean that the Dim pin = 2.964v, and also the ON/OFF (Bl-on) pin is also 2.964V? Those are two separate pins.
        • lkvee
          • Feb 2009
          • 198
          Can't find the button/link to edit my original post, but the original post was for Pins 15 to 1 in descending order.
          For Pins 16 to 2, I got these readings during standby (steady red LED):
          NC 0.23V
          +12V 12.6V
          +12V 12.6V
          +12VAU 12.48V
          GND 0V
          GND 0V
          NC 0.16V
          DIM ON/OFF 0.14V
          For Pins 16 to 2, I got these readings during ON state (steady blue LED):
          NC 0.23V
          +12V 12.59V
          +12V 12.59V
          +12VAU 12.34V
          GND 0V
          GND 0V
          NC 0.16V
          DIM ON/OFF 2.964V
          I put a probe on Pin 2 and then plugged in the TV. Voltage went to 2.964V and descended to near zero until the 4th (out of 8) red LED blink and then went back to 2.964V.
          Replicated on Pin 1.
          Have yet to test VLED but want to do so and measure from the minute I plug in the TV also.
            So you are saying Pin 1 (DIM) has exact same Voltage reading as Pin 2 (ON/OFF)?
            Also do this: Put black probe on the chassis and keep red probe on the VLED+ then turn on the TV to see how high the DCV goes up to and wait for seconds to see what it goes down to, it is going to happen fast so keep your eyes on the meter.
            • lkvee
              • Feb 2009
              • 198
              Black lead was on the metal chassis. Red one was on one of the two VLED+ pins. I plugged in the TV and observed voltage.
              Immediately went to 12.39V and then went to "OL" (around the fourth out of eight red LED blinks), then to a range of 36-37 volts and back to 12.39V
              I'm using a Fluke meter with autorange.
              Not sure if what I saw was a consistent "surge".
              Both VLED+ pins behaved this way.
                Since the meter went into OL (Over range) mode, you should set it to 200V manual mode.
                It sounds to me that you have open circuit int he LED strings.
                • lkvee
                  • Feb 2009
                  • 198
                  TV changed behavior. LED cycles with two RED blinks, but fails to turn blue. Using the remote fails to turn it on, too. Eventually, that blinking red LED goes steady but I still can't turn it on.
                  I do remember being less than careful enough with the needle probe on CN9101. I saw a blue spark on three occasions.
                  Here's what I found for CN9101 on the outer pins:
                  NC 0V
                  +12V cycles between 12.5V and 0V
                  +12VAU steady at 12.4V
                  GND 0V
                  GND 0V
                  NC cycles between 3.3V and 0.5V
                  DIM ON/OFF cycles between 2.9V and 0V
                  Readings are also similar for the inner pins but I failed to get anything other than 0V on Pin 2 (DIM ON/OFF).
                  Forgot to measure those capacitors.
                  • lkvee
                    • Feb 2009
                    • 198
                    Just acquired the service manual from Elektro Tanya. It's the same manual for the next two larger size TV's, too.
                    There's a decision flowchart, and one of the decision diamonds ask whether I am getting 12V AND 19.5V from the power board. If not, replace it.
                    I see the 19.5V at C9100 but nowhere else. I can say with confidence I never got 19.5V on any pin during any state.
                    My schematic literacy is barely >0 but I can't read which pin's supposed to generate 19.5V
                    • Noah Glasse
                      LG 50PK590 - three clicks and steady red light, won't turn on.
                      by Noah Glasse
                      I've got a LG 50PK590 plasma TV which upon plugging in will click three times and the red LED in the corner will come on and stay on, the TV however doesn't come on (no humming, sound, video, etc.) and using the touch controls or the remote does nothing. On exceptionally odd occasions, the TV will come on and work normally when plugged in and will last about 5 minutes before going back to off and unresponsive.
                      I've got the back off of it and none of the caps stand out as visibly buggered, I've also tested the three resistors in the corner of the power board which...
                      02-24-2025, 07:23 AM
                    • koby058
                      Dell optiplex 990 steady orange light
                      by koby058
                      Hi
                      FOXCONN E253117 94V-0 ML1-Y MOTHER BOARD
                      when connecting power its fan starting no beeps and steady orange light
                      No post and nothing on screen
                      Any body have idea about test direction ?
                      12-10-2022, 11:36 AM
                    • FMstatic
                      Sony KDL-48W657D (main board protect, green light steady at the same time red light s
                      by FMstatic
                      Diagnose (panel problem)
                      - main board replaced- still no good
                      - panel board check all supply present and correct voltage
                      - hang flex ribbon main board to panel (error 5blink) but when connected again nonstop red blink no pose and green light steady
                      -SDA and SCL supply 3.3v panel board
                      -BL is good simulated
                      Guys help me any suggestion
                      Main board protect 12v shut off when connected to panel board
                      06-08-2021, 09:29 PM
                    • shovenose
                      Christmas Light Power Supply Question
                      by shovenose
                      I have a cheap rainbow christmas light set off Amazon which has this little power supply that has a button to change modes. I had a white set with the same power supply that I returned but I can't find any other rainbow themed ones that don't use this setup.
                      Anyway, the problem is every time you unplug them and then plug them in it reverts back to "Combination" mode which cycles through all these annoying tacky effects instead of going back to what you had selected or at least defaulting to "Steady on" which is what I want. So I'm thinking I can just...
                      12-08-2023, 09:59 AM
                    • ivtec
                      Hisense Roku Tv 55R6E3 steady red led help.
                      by ivtec
                      Hi folks i need your help ,have here a tv that i found on the curb and i'd like to repair it if it doesn't cost me much since i don't have no 4 k tv,
                      Are these Voltages going to the main board Ok?
                      Unplugged from main board
                      0.00v
                      0.00
                      20.20
                      20.20
                      0.00
                      0.00
                      9.20
                      9.20
                      Plugged to main board
                      0.00v
                      0.00
                      20.20
                      20.20
                      0.00
                      2.93
                      12
                      12...
                      05-08-2022, 11:22 AM
