Alright ive taken on this and so here we go...took of the back and i see the coils on power supply there is black tinge in the middle bit not to sure un less i take the board out..i plugged the set in and there is power to start up theres the samsung chime and red led in front and also blinking green on logic board, does not look like a code its continuous..But then after a few minutes something started burning up and stink so i shut her down..fuses are good and thats where im at...need a manual cant find one B650 SERIES heres some pics..
Samsung PN58B650S1F Sound but not picture
Re: Samsung PN58B650S1F Sound but not picture
Might as well let what's started to burn up continue then replace it as probably too late now. The set is operating normally except for picture but no other useful info given. Then again I'm a fatalistic so others may suggest something else.Comment
Might as well let what's started to burn up continue then work out why and replace whatever as probably too late now to save the component. The set is operating normally except for picture but no other useful info given. Then again I'm a fatalist so others may suggest something else.Last edited by maxvalutech; 06-26-2017, 01:15 AM.Comment
what, like some voltage measurements.
now that is crazy.
let's start with va and vs voltage and go from there.WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?Comment
i take it that all boards are hooked up for these voltage measurements and your vs/va are close to the panel specs.
there will be a couple more voltages to check, probably ve, vsc, vscan, -vy or similar.WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?Comment
by TR103Hi, I have a Samsung UE50TU with:
- it keeps rebooting
- without cable between mainboard and lcd panel and with a jumpered... -
by MgiffuneI have a 60 inch Samsung UN60EH6000F flatscreen TV. The screen went black a few months ago Sound is good, backlight is good, no menu. I replaced the TCon board with a used board purchased from Ebay. It worked fine for a 3-4 months, then the screen started ‘fading' back. Once again, sound is good, backlight is good, no menu. However, this time the picture looks fine for about 10-15 minutes, then fades back. If I power cycle the TV, the display reappears, for another 10-15 minutes, then fades black again. Repeatable ever time.
I ordered a supposedly ‘new' Tcon board this time, and... -
by IerwinHello everyone,
Anyway I still fully expect that there has been something seriously damaged... -
by jchangHi all
I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
Symptom:
No picture no sound.
When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
No sound at all.
What I tried:
1. I tried unplugging the left or right ribbon... -
by DodgethisHello all,
This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...5 Photos - Loading...
