UE32C5100 Standby Only
+ More Options
Posts
  • StephenU
    • Dec 2013
    • 230
    • United Kingdom
    Hi all I have the following TV which I'm trying to repair. I'm only getting 5v standby on the output of connector CNM801 (pin 16). No other voltages present and TV won't come out of standby. Both fuses are fine and I've also checked the backlights are working and they are fine.
    PSU - BN44-00351B
    Any help would be appreciated, thanks in advance.
    S.
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: UE32C5100 Standby Only
    Disconnect the mainboard and connect pin 16 to pin 18 using a 1K resistor. Then check you have all the voltages on that connector.
    • StephenU
      • Dec 2013
      • 230
      • United Kingdom
      Sorry can't seem to find a 1K only one I have found is a surface mount one. I'll need to order some up. Unless there is another option. Thanks
      • dskall
        • Oct 2016
        • 2905
        • usa
        Something close. I have just jumped direct and haven't had a problem. But better to bring voltage down with resistor
        • dick_barton
          • Aug 2015
          • 6643
          • Wales
          Go around to any local electrical repair shop and scrounge some.
            The value can be anything from 330~1000 Ohms, it is to limit the current in case the connection is made wrong.
            • dick_barton
              • Aug 2015
              • 6643
              • Wales
              On many set you can jumper without a resistor but unless you have the circuit diagram in front of you it can actually cause damage.
              • StephenU
                • Dec 2013
                • 230
                • United Kingdom
                Thanks all I'll be grabbing a few things from Maplins on way home today so will also get a few resistors also. And see how I get on later. (Hopefully can repair it as I've noticed a few on the bay for £50+, don't fancy forking that out tbh.!!)
                Thanks again.
                S.
                • StephenU
                  • Dec 2013
                  • 230
                  • United Kingdom
                  Readings took with 1K res in place across 16-18
                  Pin 1 - 13.27
                  Pin 2 - 0
                  Pin 3 - 13.27
                  Pin 4 - 2.951
                  Pin 5 - 13.26
                  Pin 6 - 5.126
                  Pin 7 - GND
                  Pin 8 - GND
                  Pin 9 - GND
                  Pin 10 - GND
                  Pin 11 - 5.279
                  Pin 12 - 0
                  Pin 13 - 5.279
                  Pin 14 - 5.279
                  Pin 15 - 13.26
                  Pin 16 - 5.279
                  Pin 17 - 13.26
                  Pin 18 - 1.164
                  • dskall
                    • Oct 2016
                    • 2905
                    • usa
                    You will make it easier on us if you give us pin descriptions
                    • StephenU
                      • Dec 2013
                      • 230
                      • United Kingdom
                      Silkscreen on the PCB
                      Pin 1 (D12V) - 13.27
                      Pin 2 (DET) - 0
                      Pin 3 (D12V) - 13.27
                      Pin 4 (BL ON)- 2.951
                      Pin 5 (D12V) - 13.26
                      Pin 6 (PWM) - 5.126
                      Pin 7 - GND
                      Pin 8 - GND
                      Pin 9 - GND
                      Pin 10 - GND
                      Pin 11 (D5.3V) - 5.279
                      Pin 12 (GND) - 0
                      Pin 13 (D5.3V) - 5.279
                      Pin 14 (D5.3V) - 5.279
                      Pin 15 (Vamp) - 13.26
                      Pin 16 (SB) - 5.279
                      Pin 17 (Vamp) - 13.26
                      Pin 18 (PS) - 1.164
                      • dskall
                        • Oct 2016
                        • 2905
                        • usa
                        How are you trying to power on? With remote, power button on tv. With everything plugged in do you get anything on PS when you push button?
                        • dick_barton
                          • Aug 2015
                          • 6643
                          • Wales
                          Those voltages all look fine except for Pin 2 (DET) which I'm unsure of what value it should be.
                          So once again disconnect the mainboard and connect pin 16 to pin 18 using a 1K resistor and also a 1K resistor between pin 16 to pin 4 (Backlights On) and see if the backlights come on?
                          • dick_barton
                            • Aug 2015
                            • 6643
                            • Wales
                            I've just re-read your first post and you say that the backlights are working.
                            Put the resistors to one side for now and reconnect your mainboard and check the dc voltage at Pin 18 when in standby and when you attempt to take it out of standby and post results.
                            • StephenU
                              • Dec 2013
                              • 230
                              • United Kingdom
                              When I connect the TV back up and apply power, I get basically 0v then it jumps to 0.7v on pin 18 and does this every 3/4 seconds, no response from remote or touch power sensor. When I disconnect power the DC voltage slowly drops from 0.7v to 0v
                              • dskall
                                • Oct 2016
                                • 2905
                                • usa
                                You may have a bad voltage regulator on main board. Maybe some good pictures of main board.
                                • StephenU
                                  • Dec 2013
                                  • 230
                                  • United Kingdom
                                  Hope these help guys, thanks.
                                  • dick_barton
                                    • Aug 2015
                                    • 6643
                                    • Wales
                                    It looks like you are not getting PWR_ON from the main board so whatever the problem is it's not the power supply.
                                    Some good photo's of your mainboard would be good.
                                    • StephenU
                                      • Dec 2013
                                      • 230
                                      • United Kingdom
                                      heh guys, plugged it all in and run a hairdryer over the mainboard and within 30 seconds tv booted up fine, so most definitely mainboard issue....
                                      mainboard number - BN41-01549B
                                        Pictures of the Main board?
                                        • tvguy12012012120
                                          by tvguy12012012120
                                          02-07-2025, 05:13 PM
                                        • fharris1977
                                          Vizio D50u-D1 Dead Set No Standby
                                          by fharris1977
                                          Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
                                          12-28-2023, 10:25 AM
                                        • Crystaleyes
                                          Samsung BN44-00259A standby question
                                          by Crystaleyes
                                          Hi all.
                                          I started a thread while back regarding TV power supply standby circuitry as it is something I am not quite on top of.
                                          SMPS theory and function is becoming more familiar, however the standby part is still a bit of a mystery.
                                          Anyway, a friend has this TV with the above mentioned power supply board which has no standby voltage, nor any other voltages leaving the board.
                                          The mains AC comes in fine, gets filtered and rectified with power is on the main filter cap as well as the transformer and drain pins of the ICE3B0665J, but that's it.
                                          08-11-2023, 05:15 AM
                                        • psssst
                                          Yamaha TSX 120 Standby Problem
                                          by psssst
                                          Hello forum. I've recently been given a Yamaha TSX 120 DAB radio and ipod dock. Its working well however when put on standby its using 6.3 watts. The manual states less than 1 watt on standby. I measured this with a plug in monitor which seems accurate with other items. In use it uses around 7.5 watts. Firstly has anyone who owns a similar radio also got a plug in monitor to check if this is normal with this unit? In the first half a second the monitor shows 0.3 watts which I suspect is what it should use but something is switching it to be almost fully powered. I've searched the manual for eco...
                                          03-01-2024, 07:25 AM
                                        • ChristianBr01
                                          LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                                          by ChristianBr01
                                          I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                                          The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                                          What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                                          04-23-2025, 01:48 AM
