Strange defect on LG 42PC55
  • gabiz_ro
    • Mar 2011
    • 167
    Already checked all voltage and all OK
    Replaced ~20 cap's on mainboard.Rest of them seems OK on ESR-meter.
    Checked all cables etc.
    If TV is powered standing on vertical position effect is in clip.
    Image shifted 5 cm to right and under is another with some text looking like a boot or start message.
    I can see some part of words.
    boot
    Copyright
    PXE
    Licence
    Client
    https://youtu.be/aHtj-kUg4b0
    But if TV is standing on table,face down and is powered works fine,can be flipped on vertical position,still work,and works fine until power off.
    Any try to diagnose,knocking or flexing board don't change anything if image OK remain OK,if image flicker then continue to flicker.
    Any advice?
    Anyone encountered such case?
  • dick_barton
    • Aug 2015
    • 6642
    • Wales
    Re: Strange defect on LG 42PC55
    Can you post some pictures of your circuit boards. It could be that you have bad connections or bad solder joints on one or more of your boards.
    • gabiz_ro
      • Mar 2011
      • 167
      Already checked all boards,resoldered major components,checked all sockets and cables and flexes.
      On PSU checked all caps by ESR-meter.
      On logic board found many bad cap's replaced like I said ~20 of them.
      Strange is that image "under" real image.
      Is like PC show on display real desktop alternating with BIOS POST messages.
      • maxvalutech
        • Dec 2014
        • 804
        • australia
        Definite computer terms and would seem to be connected with a networking arrangement probably as a monitor. There must be a file retained by tv either an add on piece or component or instruction amendment to Eeprom but more likely the former. What moves in the set rear when you flip it and are all inputs unhooked and clear when starting up. Words client and pxe relate to master/slave arrangement.
        • maxvalutech
          • Dec 2014
          • 804
          • australia
          Further to above the service manual for this set is readily available and on p7 adjustments it is evident that pc terms are used. Seems likely that service menu may have been corrupted. See if you can do a factory reset. Why ok flat and not vertical I don't know but one thing that does move is plasma which should not be transported or lay flat for extended time.
            HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
            This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
            09-12-2024, 02:20 PM
          • fixit007
            Samsung flicker - BN44-00932T board or else?
            by fixit007
            I picked up this TV that the prior owner said - just died.
            Tested the fuse - burnt. A dead capacitor is visible too on the hot side (CP801). Got the replacement power board (cheaply - used). Replaced the board - the TV turned ON!
            Now, about a month later (yesterday) I noticed the left side of the screen was flickering from time to time. That was already happening with the antenna input, not through HDMI.
            Also, some glitchiness with a Fire stick on HDMI3 - I hit an app with quick dark screen in stick, the TV goes - no input. Then I had to choose the stick...
            05-04-2024, 06:14 PM
            HP ProBook 430 G6 + Image Load & Asset Tag Notebook 400 Specification for Upgrade or Repair
            This specification for the HP ProBook 430 G6 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G6 + Image Load & Asset Tag boardview and 430 G6 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
            09-06-2024, 10:56 AM
            HP ProBook 430 G6 + Image Load, Asset Tag & Testntag Notebook 400 Specification for Upgrade or Repair
            This specification for the HP ProBook 430 G6 + Image Load, Asset Tag & Testntag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G6 + Image Load, Asset Tag & Testntag boardview and 430 G6 + Image Load, Asset Tag & Testntag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
            HP EliteBook 1050 G1 + Image Load, Asset Tag & Testntag Notebook 1000 Specification for Upgrade or Repair
            This specification for the HP EliteBook 1050 G1 + Image Load, Asset Tag & Testntag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1050 G1 + Image Load, Asset Tag & Testntag boardview and 1050 G1 + Image Load, Asset Tag & Testntag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
