Vestel turns on ok but dim picture after 1 minute
  • PowerAmpFreak
    • 982
    • Sweden
    This Vestel turns on OK, but after one minute suddenly backlight goes very dim, set continue working with sound and possible to control by remote.
    According to owner, by pressing teletext button could bring back picture.
    Sounds like corrupt eeprom or similair in my ears, what do you say guys?
  • vinceroger69
    • Mar 2012
    • 6714
    Re: Vestel turns on ok but dim picture after 1 minute
    does the BL ON voltage drop when the backlight goes dim what board numbers are used in this set?
    • dick_barton
      • Aug 2015
      • 6642
      • Wales
      +1 Or the DIM voltage?
      • PowerAmpFreak
        • 982
        • Sweden
        Both DIM voltage and BL ON voltage is OK when screen dims.
        Forget about the corrupt eeprom thought I had initially. It must be the LED driver module then.
        • dskall
          • Oct 2016
          • 2905
          • usa
          Whole screen dims? What are voltages to leds
          • PowerAmpFreak
            • 982
            • Sweden
            Whole screen dims. The high side of the LED supply goes down to +24V (from +50V when screen is bright)
            The two driver IC's to the right of the PCB gets really hot.
            • dick_barton
              • Aug 2015
              • 6642
              • Wales
              With the leds disconnected what led driving voltage do you have?
              • PowerAmpFreak
                • 982
                • Sweden
                LED voltage goes to +53,5V, but soon turned off due to protection.
                But I will take a look on the quick heat-up driver IC's.
                • burbutsalos
                  55" QLED QE55Q60T Turns on after 1 minute the picture goes bad and get in boot loop
                  by burbutsalos
                  Hello ,
                  The issue with this set is that it turn on just fine and after a minute or so the picture shows either vertical lines or turns half black and from that point on starts a boot loop.
                  If a let the unit to cool down for a minute the same pattern starts again. i had exactly the same mainboard as a spare and replaced it but nothing changed.
                  Any ideas what to check?...
                  12-12-2023, 06:06 AM
                • Kambi13
                  Dell Inspiron 3542 Turns on works for 30 seconds to 1 minute then turns off
                  by Kambi13
                  Hi all need some help, I've got a Dell insprion 15 3542 that turns on works for about 30 seconds or sometimes a minute or two and then turns off and wont turn on again until I remove and replug the power connector
                  Not heat related, everything is ok regarding to that.
                  All voltages are present.
                  Wondering if this as anything to do with one wire circuit, the charger is not original, but it was working fine
                  Motherboard is Cedar 13269-1 F3XMC Rev A00...
                  07-12-2024, 06:10 AM
                • ItepK
                  LG 32LG3000 TV, three red light flashes, then the backlight turns on, but no picture
                  by ItepK
                  Hello everyone! I've found this television, and I began troubleshooting it.
                  First, the television kept rapidly power cycling. I've warmed up the capacitors with a hairdryer, and after 3 dimmed red blinks, the backlight turned on, then turned dim, and no picture was present on the screen.
                  I believed that this was caused by a bad power supply producing insufficent power (I've measured 3.5v on the 5.2v rail), so I've blindly recapped the board.
                  After the recapping, all the voltages stableized, however, the issue in the title still remains.
                  I could...
                  01-03-2025, 09:01 AM
                • Tr0ll
                  by Tr0ll
                  Original T-con:
                  First replacement T-con:
                  10-07-2023, 07:48 PM
                • JJAAMM
                  by JJAAMM
                  Problem
                  07-06-2023, 06:01 AM
