Sharp LC-70LE745U
  • Samantha143
    • Apr 2017
    • 21
    • Usa
    Sharp LC-70LE745U
    Hi guys I am breaking my head here and not sure what to do next.
    We have a sharp LC-70LE745U that was originally giving us a blinking error code 2 long 3 short and it pointed to be a main board error. We replaced the main board and the error code went away and he front logo turns on regular. Now we have no backlight. We did the flashlight test and there is a faint image. We opened it up and tested each LED strip and they all turn on , we replaced the power board and it does the same thing. Not sure what else to do, any ideas ? Maybe a reset ? Not sure
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: Sharp LC-70LE745U
    Now you can only check EACH individual LED if you dismantled the Panel. What you probably tested was each LED strip, which may light-up as there could be shorted LEDs on the strips that will demand a higher than normal current from the PSU. Therefore, backlight shutdown will occur. If you are sure the PSU you replaced was good then the only diagnostic will point to LED backlight.
    • dskall
      • Oct 2016
      • 2905
      • usa
      You can connect power and main with panel removed and power it on. The backlights should flash briefly and you can see if they all light or not. Testing individually is not reliable test.
      • Samantha143
        • Apr 2017
        • 21
        • Usa
        We have the led removed from the back to the front with the boards connected and the logo still turns on the same way but the LED do not light up at all not even a quick flash. We even tested the LED cable that connects to the power board and it works.
        • dskall
          • Oct 2016
          • 2905
          • usa
          You have panel off and everything connected including leds except panel?
          • Samantha143
            • Apr 2017
            • 21
            • Usa
            The panel is still basically off but we connected everything to see the LED strips but nothing
            • Andrew F. Ali
              • Jan 2014
              • 2450
              • Trinidad & Tobago
              If you don't test each LED individually you'll be going in circles. Remove the glass screen, prism sheet, polarizer sheet, etc. Mark them so that you would know what order to replace them. If you do not have a LED backlight tester, you could use an analogue meter set at Rx1 to test the individual LEDs. You may have to scrape a little bit off the white coating to bet the testing points.
              • dskall
                • Oct 2016
                • 2905
                • usa
                Can we get some pictures and panel sticker and pictures of led board connector. You may not be getting signal from main board to turn leds on.
                • Samantha143
                  • Apr 2017
                  • 21
                  • Usa
                  Hope this helps. We are testing each LED right now
                  • Samantha143
                    • Apr 2017
                    • 21
                    • Usa
                    OK here is an update. I tested each LED individually and they were giving me 2.8 volts each. Tested the strips with the LED tester and it read 92.1 volts to power on. I measured the volts coming out of the power both PB the old and new and they both are giving me 83 volts.
                    • dskall
                      • Oct 2016
                      • 2905
                      • usa
                      Can we get picture of connector on power board that runs to main board to see pin legend? Since you get no flash at start up need to see if you are getting signal to turn backlights on
                      • Samantha143
                        • Apr 2017
                        • 21
                        • Usa
                        Does this help ?
                        • Andrew F. Ali
                          • Jan 2014
                          • 2450
                          • Trinidad & Tobago
                          OK...So we are sure now ALL LEDs are good.....check the connectors on the strips to make sure they are solid.......Be careful with the reassemble....once everything is back in....give it a try.....GO>...Let it run a few days...see if problem reappear....NOGO>.....Check the BL-ON signal from Main Bd is present......I was almost sure we checked that before....probably didn't.........
                          • Samantha143
                            • Apr 2017
                            • 21
                            • Usa
                            BL-ON? Do you mean the little light on the main board ? If so yes it lights up.
                            • vinceroger69
                              • Mar 2012
                              • 6714
                              • uk
                              BL ON means a voltage/signal too tell the back lights to turn on if thats missing we need too find out why.It should say on the pcb writing what each pin on the connectors do.There is a pin marked dimmer? in not sure what that one is for
                              • dskall
                                • Oct 2016
                                • 2905
                                • usa
                                Ok we Need voltages from connector that goes from power supply board to main board. Will need pin#- PIN DESCRIPTION -Pin voltage in standby-Pin voltage when pushing power button
                                Format:
                                Pin# - Pin Description - Pin Voltage standby - Pin voltage power on
                                1 - XXXXXXX - XXv - XXXv
                                2 - XXXXXXX - XXXv - XXXv
                                3 - XXXXXXX - XXXv - XXXv
                                4 - etc.
                                Pin 21 maybe bl_on since there is no standard naming of functions
                                • Samantha143
                                  • Apr 2017
                                  • 21
                                  • Usa
                                  Let me know if this helps .
                                  • dskall
                                    • Oct 2016
                                    • 2905
                                    • usa
                                    Very nice. Unfortunately I am not sure what function last few pins do. Hopefully budm or someone with more knowledge can decipher.
                                    • Samantha143
                                      • Apr 2017
                                      • 21
                                      • Usa
                                      You said pin 21 maybe bl_on and it weird that it starts at 3.2V and drops to .6V on its own ��
                                      • Samantha143
                                        • Apr 2017
                                        • 21
                                        • Usa
                                        Also here are some pictures with voltages that I got from the wiring and to the leds themselves. Also a picture of how the wiring splits. But when I measure the wiring coming from the PS I get 83 from all positives.
                                        • advant
                                          by advant
                                          02-03-2020, 12:25 AM
                                        • cheeky2
                                          by cheeky2
                                          05-25-2024, 03:27 AM
                                        • Dani_2024
                                          by Dani_2024
                                          10-28-2024, 05:06 PM
                                        • Asraf Atb
                                          Help Needed: Samsung UE55MU8000 Dead - Possible Main Board Issue
                                          by Asraf Atb
                                          Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
                                          Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
                                          I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....
                                          01-27-2025, 05:02 PM
                                        • yoyokafka
                                          M60-C3 Replaced PSU & Main Board: Still No Good
                                          by yoyokafka
                                          My tv only goes to the splash/logo screen then turns off and repeats this on its own every couple minutes. I replaced the main board and got the same thing. So I replaced the power board and still got the same thing.
                                          Could it be the T-Con? The logo screen indicates it's processing the image and outputting to the screen and triggering the LEDs just fine. But could there be something with the communication between the T-Con & the main board that prevents the main board from continuing it's bootup into it's operating system?
                                          Someone please help me figure out what...
                                          09-23-2020, 06:52 PM
