Sharp Aquos Quattron LC-52LE810UN power cycle odd issue
  • ChrisCopper
    • Apr 2016
    • 7
    hey guys,
    Ive been a long time lurker, I am a repair tech and I like to help people out when I can.
    I have the above said set, given to me from a frustrated customer who has had it into 3 different shops and no joy on the repair. pretty odd I thought.
    anyway, the symptom is as follows.
    when the set is totally cold, it fires on no problem and will stay lit sometimes for up to 5 full mins , sometimes more sometimes less. then it starts power cycling. When it cycles the led light and shut down. There is no real code happening here, the set just power cycles every 15 to 20 seconds and tries to start with no joy.
    i have the set fully apart and the lcd panel removed. i can see any issues with the led wiring. if I dont try to start the set the stby is correct 3.3vdc and is sitting there.
    if i unplug the lamps i get the 1 long 1 short error code, but when I plug them in it just repeats the behavior.
    so, any tips? ive looked over the power supply, nothing is getting hot, caps seem fine, esr levels are all good, and capacitance also seems fine. This does seem like a capacitor issue to me thats for sure so Im wondering if i should change them anyway just to see. other than that I cannot find a single thing wrong at the point.
    any help appreciated if anyone has seen this before.
    cheers,
    chris
    Electronic Repair Services
    Chris Annis
    cpurepair@rogers.com
    "always willing to help someone out"
  • maxvalutech
    • 804
    • australia
    Re: Sharp Aquos Quattron LC-52LE810UN power cycle odd issue
    Surely sounds like a dry joint but the guys will need photos etc to respond properly.
    • R_J
      • 9558
      I guess you could try disconnecting the lvds cable from the t-con and see if the tv stays on, I know some of the panels have problems with the drive ic's that are on the panel ribbons on the side, I have seen one where one of the ic's would get hot and sht down the tv.
      • ChrisCopper
        • Apr 2016
        • 7
        well I have the panel totally dis connected and the lights are acting the same.
        it sure seems like solder on an IC or something. I guess a question would be, is there a particular IC that could control these led , then over heat and act up?
        Chris Annis
          Need to see the pictures of the whole back side of the TV showing how all the boards are connected together, that will a starting point.
          • dskall
            • Oct 2016
            • 2905
            • usa
            I think I would apply some freeze spray around the mainboard.
            • ChrisCopper
              • Apr 2016
              • 7
              here are a few pics. have everything connected but the panel itself and it behaves the exact same way.
              I'm almost positive it's a thermal issue I'm just not sure what chips would make the set behave this way.
              I'm thinking the freeze spray is a good idea as well.
              Chris Annis
              • ChrisCopper
                • Apr 2016
                • 7
                here is a better pic of board layout.
                Chris Annis
                • ChrisCopper
                  • Apr 2016
                  • 7
                  anyone have any idea? I'm pretty sure I have a cold joint on an IC on the main board but my question is which one?
                  Chris Annis
                  • rievax_60
                    • May 2012
                    • 897
                    • australia
                    A similar model has a common fault that affects the AC_DET. If it also uses an opto-coupler for the AC_DET try heating it.
                    • ChrisCopper
                      • Apr 2016
                      • 7
                      ok I'll look into this!!
                      Chris Annis
                      • 280zx
                        • May 2020
                        • 43
                        • US
                        I have the same set with the same problem. When I got it it had no power to the unit so I replaced the power supply. Now it turn on for about 4-5 minutes then turns off. After a few it turn on again and repeats the on and off cycle. Do you figure it out?
                        • 280zx
                          • May 2020
                          • 43
                          • US
                          I have the same set with the same problem. When I got it it had no power to the unit so I replaced the power supply. Now it turn on for about 4-5 minutes then turns off. After a few it turn on again and repeats the on and off cycle. I also noticed that the power button on the set does not work. Did you figure it out?
                          • kgavionics
                            • Apr 2017
                            • 152
                            Does the front led flashes before the tv goes off? if yes !how many times does it flash?
                            • 280zx
                              • May 2020
                              • 43
                              • US
                              No flashing lights. I turned it on and it worked for 3 minutes and turn off. After 3 minutes it turns on for 10 seconds and then cycles on and off every 5 seconds. I'm able to get the menu screen during the on cycle.
                              • 280zx
                                • May 2020
                                • 43
                                • US
                                Update TV runs for 3 minutes then turns off. At this point it tries to come back on every 5 seconds. At the 3 minute mark it come on for 3 minutes and keeps repeating the process.
                                  • 12206
                                  • U.S.
                                  If you can find a backlight NOT brightness setting try turning it down see if tv stays on longer if not turn it up and see what it does.
                                  • 280zx
                                    • May 2020
                                    • 43
                                    • US
                                    Lowered backlight setting all the way and now TV runs for 14 minutes then turns off. At this point it tries to come back on every 5 seconds. At the 1 minute mark it came on for 14 minutes again and keeps repeating this process. When I turned the backlight setting all the way up TV ran for 8 minutes then turns off. At this point it tries to come back on every 5 seconds. At the 1 minute mark it came on for 8 minutes again and keeps repeating this process.
                                      • 12206
                                      • U.S.
                                      Backlight problem, you probably need to replace the backlight strips.
                                      • 280zx
                                        • May 2020
                                        • 43
                                        • US
                                        Wouldn't I get sound during the time it goes off if it was the backlights?
                                        • scubacamper
                                          Sharp Aquos LC-70C6400U Half Screen Dark
                                          by scubacamper
                                          I found another post on this site the other day which has been very helpful in troubleshooting this issue I am having with my tv. The left half of the screen is dark, and the other half is VERY slow to generate it's image - and it only generates part of its image at that.
                                          Based on this yt video, I have narrowed it down to an issue (short?) on the left side of the display, somewhere in the system of ribbon cables.
                                          when I remove the bezel and the rear cover, I can get the image to display correctly by manipulating the ribbon cables on the left side which connects the left lower display...
                                          05-03-2025, 12:19 PM
                                        • jonah1024
                                          Sharp Aquos LC-40UG7252E LCD TV burn in?
                                          by jonah1024
                                          Hello!
                                          I'm a few days old into this TV screens repair universe so please bear with me.
                                          Recently, and all of a sudden my 40” 4K Sharp Aquos LCD TV turned on with colors all smudged in some places on the screen that remain like that even without any kind of video source. I do have image but the colors are smudged/tinted/ washed out in patches as per defects. This to me looks similar to burn in but I’m shore this is not an OLED.
                                          - I did the classic unplug and hold power button to discharge the caps but it didn't help.
                                          - I did a factory reset as well...
                                          07-16-2024, 04:23 AM
                                        • klassic
                                          Sharp Aquos LC-60LE635E three blinks
                                          by klassic
                                          Hi community,
                                          I will describe my problem with a TV in those short following terms to be the most precise :
                                          What i have :
                                          power board DPS-162KP-1
                                          main logic board QPWBXF733WJN2
                                          symptoms :
                                          white led light logo at startup,
                                          after 2 minutes, blinking 3 times a row, repeating
                                          no backlight (and apparently no picture, checked panel with flashlight)
                                          no startup sound
                                          powerboard investigations :
                                          1-2 PNL : 0v
                                          3-4 GND
                                          5-6-7-8 UR : 13.15v
                                          9-10-11-12...
                                          10-24-2023, 01:39 PM
                                        • Joekhoe
                                          Sharp Aquos Quattron LC-52LE835X Totally Dead, no output voltages
                                          by Joekhoe
                                          Hello all, I'm Joekhoe, a newbie here and ask your masters permissions and solutions for the problem i'm facing at the present.
                                          I am in the middle of working on a SHARP Smart TV model LC-52LE835X from my customer, which totally dead and there's no output voltages at all at the output pins even though i have replace some of the components the output voltages remain the same with 0 volt.
                                          The replacement as follows:
                                          1. IC7905 : TNY264PN (first found exploded)
                                          2. Q7915 : BT169D (exploded too)
                                          3. IC7901 : 1608B (controller ic)
                                          4. IC7601 :...
                                          09-17-2020, 05:52 AM
                                        • foxyUK
                                          Sharp Aquos LC-32LE600E, No 12v as no PNL_POW
                                          by foxyUK
                                          Can anyone help me diagnose this? Almost not worth bothering with, but it has 'sentimental value' for the owner. I'm no TV technician, but dabble a bit.
                                          The TV has standby power but no reaction at all to switching on or reboot steps, No flashing lights or response to menu button. All voltages on the power board are correct apart from missing voltage on pin 12 of CN7003.
                                          There is 13 v on U7053 but no 3v signal to switch it on. I don't really understand whether the 3v should come from U7401 in the standby control area, or (as suggested elsewhere) from the mainboard via pin 12....
                                          10-22-2024, 10:27 AM
