Lg 50pg20
  • Chubbytruck
    • May 2017
    Lg 50pg20
    Just wondering if someone could help me out with some information I have a lg 50pg20-ua plasma tv. It has some blown capacitors in it I order the right ones to replace them (10v 3300uf and 50v 680uf)however I got a head of myself and realized that I solder in 2 capacitors in the wrong places so I was wondering if someone could get the info for the following caps
    Power supply board LGE P/N :EAY41360901
    And capacitors numbers
    C 218
    C 203
    C 204
    C 202
    C 207
    C 917
    Thank you in advance
  • tvtimmy
    • Mar 2015
    • 1160
    • usa
    Re: Lg 50pg20
    C218, c203, c204, c202 are all 3300uf 10volt. Replace with higher voltage(25-35v).
    C207, c917 are 680uf 50volt
    • Oldschool297
      RELAND SUN 6.3v 3300uf Low or High ESR?
      by Oldschool297
      I found these, i would only like to try them on a board to see if it post. It don't post at the moment, i guess there are 9 6.3v 3300uf that can be broken. Is these low or high esr? I did not find info on the web.
      https://www.amazon.de/-/en/10-Capaci...s%2C469&sr=8-1
      08-14-2023, 04:32 AM
    • Ted29946
      LG 50PG20-ua Plasma TV repair help
      by Ted29946
      I'm new to this so I hope I'm doing it right So....I picked up a LG 50PG20-ua Plasma TV (Someone's throwaway pickup) First power up no picture or sound
      Found power board to be bad and I repaired it. (Bad caps) Now all power volt readings are good. Still no picture or sound. I plugged in power cord, no click and the standby light on the on/off button comes on blue as soon as it is plugged in and does not turn off when button is push. I then pulled the main board off to look at it better and the initial inspection (front and back) I cannot see anything bad. Before I put the board back
      10-24-2024, 11:12 AM
    • Satdude
      2700uF instead of 3300uF
      by Satdude
      Hey guys, I have a question. I need to replace the caps on my og Xbox motherboard, but I can't buy quality capacitors in my country with this specification (everything is either out of stock, with a minimum order of 1000 or just plain too big to fit in the Xbox). Can I replace the 5 3300uF caps with 5 Panasonic 2700uF caps? Thanks
      02-12-2023, 06:23 PM
    • EFritz20
      Available replacements Rubycon MBZ 3300uf 6.3v low ESR?
      by EFritz20
      I have a few busted Rubycons MBZ 3300uf 6.3v that are used for VRM purposes on a socket A motherboard. According to spec 12 mOhm with 2800 ripple.
      I have used the search engine and it appears the Panasonics are the ones to get, but those are topics already years old and these electronic ultra low ESR caps aren't availably anymore .
      I can't seem to find any available caps on the known sites that are in spec of these Rubycons. Also i can't find Polymers with 3300uf or even close to that. Closest ones i found where 2000/2200uf ones but...
      05-20-2021, 10:22 AM
    • ajdrenter
      Picking caps for Antec SU-380
      by ajdrenter
      In my search for a proper 5v heavy ATX power supply, I selected an old Antec SU-380 that I've had in storage for a long time. Opening the power supply reveals a couple bulged capacitors. I removed all the caps and made a map for myself. I found the datasheet for the PCE TUR series in this thread:
      https://www.badcaps.net/forum/showthread.php?t=14159
      It says these are general purpose, so I assume I can replace them with any general purpose capacitors, but I don't really know anything about power supply circuits or reading capacitor datasheets. Despite this, I've been shopping for replacements:...
      05-13-2023, 10:40 AM
