LG 42LW4500 distorted picture and bootloop
  • khaahk
    • Dec 2013
    • 806
    • Estonia
    Hi
    power rails seem ok.
    Added picture and video.
    Reseated all connectors, did a reflow of main cpu LGE1027DC.
    No change.
    Tcon or mainboard? Any ideas?
  • attainteddragon
    • Apr 2013
    • 764
    • australia
    Re: LG 42LW4500 distorted picture and bootloop
    might be panel, but it could be tcon as well. disconnect a ribbon cable that goes from the tcon to the panel and see how it effects the picture, then do the opposite side.
    does it effect the osd as well?
    WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?
    • khaahk
      • Dec 2013
      • 806
      • Estonia
      if TCON to panel one ribbon disconnected - one half picture white the other stays the same (with defects). The same with the other ribbon.
      When i disconnect PL704 (41Pin LVDS Connector for FHD 120Hz)from main to tcon then picture shows the same defects but looks interleaved (white logo is striped).
      When i disconnect PL703 (51 pin LVDS Connector for FHD 60/120Hz) from main to tcon then picture stays black.
      OSD does not show up - reboot happens too fast.
      • attainteddragon
        • Apr 2013
        • 764
        • australia
        if the screen is the same with either side disconnected, then your panel should be ok.
        i missed the bit that said it was in bootloop. i would be looking at the main board then.
        not sure if i can be much more help on this one. have you tested the voltage regulators?
        • dskall
          • Oct 2016
          • 2905
          • usa
          Heat/cool small sections of mainboard to see if it will come on. Looks like some noise maybe cap or regulator going bad.
          • khaahk
            • Dec 2013
            • 806
            • Estonia
            Will give it a try, thanks everybody for ideas.
            • khaahk
              • Dec 2013
              • 806
              • Estonia
              In the end had to change the mainboard (bootloop disappeared) but the picture had different kind of vertical lines. After changing tcon - everything is fine.
              • attainteddragon
                • Apr 2013
                • 764
                • australia
                sucks that you had to change both boards, but great that it is working again.
                enjoy.
                • Fly_Among_Stars
                  VIZIO E70-E3 Half picture with half TCON
                  by Fly_Among_Stars
                  I have a VIZIO E70-E3.
                  Symptoms: Black screen, no picture, but LED backlights are working.
                  I probed the power board and voltages are as listed on the board.
                  Main board appears fine, too.
                  I believe the problem is either a bad T-CON board, or connection to LCD, or bad LCD.
                  There are two separate ribbon cables feeding the LCD.
                  If both are connected, the screen is black.
                  If only the ribbon cable that feeds the right side of the screen (when viewed from the front) is disconnected, the left side of the screen shows picture and...
                  04-24-2023, 08:20 PM
                • iglitare
                  by iglitare
                  09-04-2025, 07:13 AM
                • ChattFix
                  Samsung UN55TU700DFXZA Distorted Picture
                  by ChattFix
                  I have a Samsung UN55TU700DFXZA with a distorted picture and I thought it was a bad panel. I had a similar board with one number off and still tried it to see what the issue could be. The picture came out clear with only missing blue hue I think. I found a replacement board for $30 but wanted to learn if this would be the main IC or possibly something else. I don't have service manual so looking to learn about these cheap sets....
                  06-02-2024, 03:50 PM
                • shelby5041
                  Samsung LCD TV no picture backlight on no 12v at tcon
                  by shelby5041
                  hi
                  i have a samsung lcd tv
                  it powers on with sound and backlight but no picture
                  all voltages from PS are good 12v 3.3v and 5v
                  whats odd is that at the tcon i tested voltage across the fuse on the tcon and i get 0v
                  i figured main board issue..so i ordered a used main board....when i put replacement main board in i still have same issue
                  no 12v at the tcon fuse
                  i disconnect the panel ribbon cables to rule out any panel issues and i still have no 12v at the tcon fuse
                  the odds of having 2...
                  10-08-2021, 08:21 AM
                • x_orange90_x
                  TCL 50S535 bad tcon or panel issue?
                  by x_orange90_x
                  Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                  03-29-2025, 11:02 PM
