Optocouplers pc123
  • Chicd
    • Jun 2015
    • 40
    Optocouplers pc123
    Have several power boards that have no power/voltage to the 'cold'side....could the pc123 optocouplers be the cause?
    Tried testing and think I have several that are bad...any hints?
    Have no voltages on the main board other than standby...
    Still learning....
    Re: Optocouplers pc123
    Hard to help without full details and good clear pictures of what we are dealing with.
    Makes and model?
    • Chicd
      • Jun 2015
      • 40
      Thanks Bud...
      Vizio 37L HDTV10A
      Standby ok (amber)
      No power when switched on...have 5.2v all three pins on connector....no other voltages PB# 0500-0507-0250
      MB#3637-0072-0150(2D)...F1-0v F2-5.2v
      U8 tests Ok...5.2/3.3/2.1
      U33,7,9,2 all 0v
      Slowly learning...have several Vizio's with same symptoms...does the 'cold' side of PB remain 'cold' until the main board sends it a signal to 'turn on'?
      Guessing my problem may be in the MB...
      Thanks for your willingness to teach...
      Chic
        • 31197
        they can fail - or be killed.
        • dskall
          • Oct 2016
          • 2905
          • usa
          Need voltages from connector that goes from power supply board to main board. Will need pin#- PIN DESCRIPTION -Pin voltage in standby-Pin voltage when pushing power button and picture of connector on power supply board.
          Format:
          Pin# - Pin Description - Pin Voltage standby - Pin voltage power on
          1 - XXXXXXX - XXv - XXXv
          2 - XXXXXXX - XXXv - XXXv
          3 - XXXXXXX - XXXv - XXXv
          4 - etc.
          • Chicd
            • Jun 2015
            • 40
            Thanks for replies....
            Voltages on connector from PB to MB
            1-pson-0
            2-(12v) 0
            3-(12v) 0
            4-(12v) 0
            5-blank
            6-gnd
            7-gnd
            8-gnd
            9-(stby) 5.2
            10-(stby) 5.2
            11-(stby) 5.2
            12- (A) 0
            13-(B0 0
            Same after pushing power button...
            • dskall
              • Oct 2016
              • 2905
              • usa
              Disconnect connector from mainboard side and insert 1k resistor from Pin1 to pin9 see if you get your 12v
              • Chicd
                • Jun 2015
                • 40
                Will do tomorrow...
                • Chicd
                  • Jun 2015
                  • 40
                  After inserting resistor....what if I do/do not get the 12v?
                    If you are able to force on the rest of the power supply using the resistor then it means the power supply is OK, just make sure you disconnect the cable going back to the main board first before attempting the force on.
                    So far it looks like you have main board problem because it is not sending the PS-ON to turn on the rest of the power supply.
                    • Chicd
                      • Jun 2015
                      • 40
                      OK...I replace quite a few 1117's in Vizios
                      • John McGivern
                        Delta DPS-160QP Power Supply
                        by John McGivern
                        This power supply is for a HP Pavilion Slimline PC.
                        1 Turn on 330vdc at high voltage cap.
                        2 No 5vstby or any low voltage rails.
                        3 PWM chip is UC3845B.
                        4 PFC chip is 1CE1PCS02.
                        5 Switcher TNY267.
                        6 There are 4 optocouplers. PC123. and TL431.
                        I am retired and a novice at electronics.
                        Any help would be much appreciated and a schematic would be handy if anyone knows where to get one.
                        Many thanks in advance, John....
                        12-02-2022, 10:27 AM
                      • Eel_dahc
                        Optocouplers
                        by Eel_dahc
                        I got a free Polaroid flm 323 TV and I am assuming that the power supply is bad because I don't get any voltages like shown on Copp#ll tv site or youtubes. But I have it at the main cap. I already replaced a couple of diodes and tested the caps.
                        This is just for me to learn on and try to fix.
                        So I was wondering about the optocouplers. Took them off to test. Using a DMM I got nothing in diode mode up to 200k. My little lcr-t4 didn't find anything.
                        Using a tester i rigged up with a 3.7v battery, led and 1k res on breadboard and only one lit up and it...
                        03-07-2020, 12:37 PM
                      • conan981
                        Plastic welding machine repair and hints
                        by conan981
                        hi, i have a welding machine with ultrasonics. it's REALLY old
                        btw since now i could use it without any trouble. now i have the HIGH POWER NPN TRANSISTORS MJ802 that keep shorting after 1-2 hours of using.
                        this board is powered with a transformer that from 220V give 55v, 6v, 12v
                        MY question is : why these transistors burn?
                        i wish someone expert can give me some hints and what to check on the board.
                        There are few components luckily. i am uploading photos of the board so you can have an idea. if something else is needed i can do measurements or else...
                        06-26-2019, 07:55 AM
                      • EnderFFX
                        P15 Gen 1, Error 2203 but B0 / C0 are okay. possibly GPU swap?
                        by EnderFFX
                        Hello!
                        I bought a P15 Gen 1 as defective and without much hints to its history.
                        Was sold as "cannot start, weird stuff on screen".
                        So i bought a replacement GPU (2070 Super) and BOOM it worked immediatly, i got lucky.
                        Only that error 2203 every single time with beep loud enough to wake the kids is annoying.
                        I sincerly tried to read up and got a U One to work (3.5.40, that update tool will always say 3-5-40 is latest on cloud althiugh i ran it 3 times, it updated once from 3.5.30 to .40. Is that a problem? P15 Gen 1 is old anyways...)...
                        07-26-2025, 04:23 AM
                      • re-atari
                        Onkyo TX-NR414 doesn't switch on
                        by re-atari
                        Hello All,
                        I am trying to repair my defective OnkyoTX-NR414, which won't switch on. Pressing the On button doesn't do anything at all, device stays dead.
                        I didn't do any voltage measurements with the receiver connected to the mains yet, just started with resistance and diode tests using the service manual as reference.
                        I already found a few suspects. The PSU pcb contains 2 Sharp PC123 optocouplers, that appear to be malfunctioning. Measuring out of circuit with my Metex 3650 on diodetest, on both optocouplers the fototransistor shows 'open' in either...
                        10-02-2017, 06:18 AM
