. I've actually have a question about a power supply it's a noob question really I'm doing a project where I'm using the cfl's from a flat screen the only issue I'm having is I can't seem to turn the power supply on with out the main board connected the power supply has the ballast integrated into the power supply what I need to do is take the power supple find where the p-on is jupiter it to turn it on the activation the cfl but I cant seem to find any reference to it her is the board part number 715g3770 p03 w30 003s
TV power supply
Tags: None
Re: TV power supply
We need makes, model, and good clear pictures of the board and how all the boards are connected together to be able to help you.
Details, details, details........Last edited by budm; 04-27-2017, 04:15 PM.Never stop learning
http://www.badcaps.net/forum/showthread.php?t=24809 -
Re: TV power supply
Dynex Power Supply Board 715G3770-P03-W30-003S for DX-32L221A12
thats the power supply and type of tv i got the power supply to turn on now im just trying to get the ccfl's to turn on im not sure if im using the correct resistor to jump bl-on wire i will upload pics in a fewComment
Re: TV power supply
i do know the lights and power supply were working when i did the tear down of the tv but i just cant seem to get it to send a on signal to the balast for the ccflComment
Re: TV power supply
Pins are labeled on the power supply board.
http://www.shopjimmy.com/dynex-pwtv9...pply-board.htmNever stop learning
Re: TV power supply
Usually your turn on voltage is about 3.2v so it is good to drop your 5v down with resistor. Some just jumper the pins with no resistor. To much resistance will drop voltage to much and will not work.I assume no responsibility for any stupid suggestions I might post.Comment
Re: TV power supply
470~1K will be fine, 1K will limit the max current to 5mA (5V supply) if it is fed to the PS-ON/BL-ON receiver pin without input resistor.Never stop learning
Assuming...7 Photos -
by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
One note when I tested the switching power supply and the voltage control board I noticed that this desoldering gun heat up much faster than the original switching power supply which I was really surprised by to the point that I might buy... -
by sam_sam_samI have been working on this concept for quite some time now with limited success but recently I found a switching power supply that is setup for the voltage that this soldering station needs to operate at however it also needs part of the secondary circuit from the original switching power because you need several voltage rails
I once tried to get a ZD-915 desoldering station to work on a 18 volt battery power supply but unfortunately things did not go well but I did find a work around but I might try this idea again but going at a little differently more about this another time... -
by JimBanvilleThe sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
Opened it up and discovered the power supply is making a faint clicking or ticking sound.
I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...-
by Gust zhangI have a 15 - inch Retina MacBook Pro from the mid - 2014 model. Here is the link: https://www.badcaps.net/forum/showth...light=820-3662 . The battery broke some time ago. After I removed the battery and plugged in the original power adapter, the MBP could boot up normally. However, when I checked with IntelPowerGadget, I found that the CPU speed was limited to 0.8 GHz, and it ran very slowly. Later, I found a solution on GitHub. There is an open - source project called cputune that can set the CPU running speed. So I can now run the MBP at full speed. But another problem...
- Loading...
