VIZIO VS420LF1A -- horizontal green lines
  • muhtvsux
    • Apr 2017
    • 6
    Hi all. So after a bunch of interneting and searching through the forums here I'm quite suspicious of the T-CON board but I'd like some input before I dive in and try to replace it.
    Again, VIZIO VS420LF1A. All is well with the TV with the exception of when I try to play any ps3 game on disk only! I get tons of horizontal green lines and a wider ban of snow that continuously travels up the screen.
    The wacky part is I can play off HDD with no issue and my chromecast and roku have zero issues (I do get a splash of the green lines for a second when the roku reboots but no other time).
    I've tested this with 2 different systems on each of the three HDMI ports. Then confirmed it was not the playstation by hooking up to my computer monitor where is issue was not present.
    Thoughts?
  • dick_barton
    • Aug 2015
    • 6642
    • Wales
    Re: VIZIO VS420LF1A -- horizontal green lines
    Is there a Games mode you can select. It could be that the frequency of the PS3 is not matched to the scan frequency of the Vizio set. Just a thought.
    • dskall
      • Oct 2016
      • 2905
      • usa
      I would think more likely at mainboard side which processes the video. The t-con passes what is sent to it. More like a software issue. Check for updates in firmware.
      • muhtvsux
        • Apr 2017
        • 6
        All a "game mode" would do on this model is adjust the picture levels, nothing to do with scan frequency. This sort of came out of the blue after years of use. Plus it's only with games on disk, downloaded games pose no issues.
        And firmware, I can't seem to find an update from vizio for this model so idk if thats it
        • muhtvsux
          • Apr 2017
          • 6
          So I unplugged the Tv for like an hour. Then powered on the PS3 with the HDMI unintentionally unplugged from the system but still attached to the TV. Hooked it backup, started up a game on disk and wow the lines are gone and all seems OK.
          I don't trust that it will last but at least for now it works... :/
          • arctor
            samsung 50tu8070u black display with horizontal green lines, sound and backlight ok
            by arctor
            hi guy my friend gives me this tv a 50tu8070u that has no picture at all, sound ok, backlights ok. i tought it was a bad panel, but the tv has many horizzontal lines green, i tried with the tape method but nothing change, only the green lines disappear but still no picture. You that have more good than me, do you think it s a panel or can be the main board, because my friend wants buy a new main board....but the tv respond to the remote control, have sound only no picture so i think it s a panel problem that is so broken that i cant fix with tape...or i wrong if someone can help me thanks, i give...
            04-26-2025, 05:22 AM
          • howardc64
            by howardc64
            07-24-2025, 05:17 PM
          • rapid911
            Vizio M58Q7 colored horizontal lines
            by rapid911
            Hi guys, I have a Vizio M58Q7-J01 and now there are some colored horizontal lines on the screen. Could someone tell me if it's probably a panel issue or something related to other parts and can be fixed? Thank you in advance....
            05-28-2023, 04:17 PM
          • jason123
            Vizio V555-H1 - Horizontal lines then double image bursts
            by jason123
            Hi there,
            I think it might be a bad panel but I thought I'd ask before I chuck it..
            thin colored horizontal lines bottom and thin section on top. As it runs warmer, you can see some ghosting or double image. Right hand side of the screen darker then brighter (backlight is always on, so it's the actual LCD that gets darker and brighter)
            Replaced the Main board, because I had one handy, no change.
            Is it worth replacing TCON? disconnecting ribbon on one side of the panel, the lines appear still on the other side (unplugged side.)
            12-15-2022, 03:53 PM
          • JRyan
            Vizio 39" horizontal lines
            by JRyan
            Found yet another TV by the road that has lines across the whole screen. What is causing this?
            12-22-2023, 10:02 PM
