Sony kdl-70w850b
  • zukdj
    • 104
    Sony kdl-70w850b
    So frustrated, my TV was having inverted color issues so I purchased a new TCON, installed it and now when I turn it on the power led comes on white and then it goes into a constant amber/green flash, no backlights, nothing but the constant flashing. I removed the TCON and put my old one back in and now I get no picture, just back-light and tones when I switch options around and a garble of colors on the screen, the screen moves so I know I am getting menus, just can't see them. I was told I need to flash the firmware with the new TCON installed while it is flashing amber/green but how do I do that if I have no way to see anything on the screen? I am so frustrated.
    PLEASE HELP ME RECOVER THIS TV......
    Just wanted to reiterate prior to installing the new TCON I was able to get a not perfect but decent picture.
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: Sony kdl-70w850b
    Check your ribbon and lvds sounds like connector or cable problem.
    • zukdj
      • 104
      I was told firmware is not consistent across all boards, turned it on and plugged in the USB with the bin file on it to see if it will force install the firmware.
      • zukdj
        • 104
        Prior to installing the new TCON all the images had a red hue around them, it is most evident in the picture of the guitar. Cartoons were the best but once you started with overlays the pics got nasty.
        • zukdj
          • 104
          After installing the new TCON and forcing a firmware update I now get a very different scenario. The firmware was needed to get everything on the same firmware. See pics of TV now. I have no testing meters, I am a newbie, what would be the best guess at what is causing this? I'm thinking the firmware only further damaged whatever board was failing, suggestions?
          • Daren87
            Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
            by Daren87
            I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
            08-13-2023, 03:25 PM
          • iglitare
            by iglitare
            09-04-2025, 07:13 AM
          • kca
            by kca
            Hello all ~
            08-31-2025, 06:38 AM
          • thelankanguy
            Sony KD-55X9000F TCON Issue
            by thelankanguy
            The TV shows a black screen with no image.
            TCON ribbon connectors were disconnected individually for image and there was no half image even.
            Later both ribbons were disconnected and TCON voltages were tested.
            12V, 3.3V, 1.8V were seen present but VONE signal reads 0V.
            There is also a short to ground in this circled inductor.
            Is this a TCON issue or something else ?...
            12-13-2024, 12:27 AM
          • bbrain
            Sony KD-55AG9 TCON?
            by bbrain
            I have this problem with my Sony 55' AG9.
            It flashes 4x.
            I have found the service manual, and seems it is the TCON.
            Before I buy a TCON can someone check the vid?
            Thanks in advance!...
            09-19-2024, 10:50 AM
