Samsung ln-t4061f stuck in rebooting sequence
  • engelwood39
    • Mar 2015
    • 93
    I have a Samsung ln-t4061f that would just click when you tried to turn it on. I pulled off the back and saw that 4 caps were bulged. I ordered the replacement caps and installed them, when I plugged the tv back in it made a startup sound and went to a black (but back-lit screen). It will then shut itself down after about 10 seconds and then try to reboot again after about 5 more seconds. Any advise?
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Samsung ln-t4061f stuck in rebooting sequence
    Always a good starting point when asking for assistance.
    https://www.badcaps.net/forum/showthread.php?t=39740
    • engelwood39
      • Mar 2015
      • 93
      sorry, dick barton. I will get some pics up, but I already replaced the bulged caps
      • dskall
        • Oct 2016
        • 2905
        • usa
        Might try unplugging t-con and see if it stays on.
        • engelwood39
          • Mar 2015
          • 93
          When I unplugged the T-con it didn't change anything.
          Here are the pics. I put yellow arrows to the caps that I replaced with these caps:
          http://www.ebay.com/itm/172024725260...%3AMEBIDX%3AIT
          • dskall
            • Oct 2016
            • 2905
            • usa
            Check rectifiers on cold side around where you changed capacitors
            • dick_barton
              • Aug 2015
              • 6643
              • Wales
              What voltages do you have on CN801 when it first comes up and when it goes to black.
              Check the soldering on T1801 for poor joints.
              • engelwood39
                • Mar 2015
                • 93
                dick_barton, I sent a picture of the solder joints on T1801. They look pretty good to me.
                I also sent a picture of CN801 (2nd picture). It has a 24 pin connector to it and I'm not sure what you want me to test on it? Also does the ribbon cable need to be plugged in when I make the tests?
                The 3rd Picture is of connector CN1801 and CN1802. I was wondering if that was what you maybe were wanting the voltage on instead of CN801?
                Hey dskall, I am not sure how to test the rectifiers. Could you let me know what I should do to test them and where they are?
                • cliff_hootarski
                  • Jul 2006
                  • 411
                  Isn't this model known for bad caps which in turn corrupts the firmware on the main board?
                  • dick_barton
                    • Aug 2015
                    • 6643
                    • Wales
                    +1
                    The previous threads do indicate bad capacitors and there are repair kits out there on Ebay so may be a good starting point to replace existing capacitors.
                    • engelwood39
                      • Mar 2015
                      • 93
                      Originally posted by dick_barton
                      +1
                      I replaced the capacitors that were bad already. I replaced all four that are included in the Ebay repair kits. These are the capacitors that I used instead of buying the more expensive kit. They have the same ratings and were pretty popular on BadCaps preferred capacitors thread.
                      cliff_hootarski, Does that mean that replacing the capacitors may not be the fix? I may need to replace the main board?
                      • dskall
                        • Oct 2016
                        • 2905
                        • usa
                        Would need good pictures of front and back of mainboard to see if this is board with that problem.
                        • dick_barton
                          • Aug 2015
                          • 6643
                          • Wales
                          The kit I believe which was referred to in that thread said changed all 9 capacitors?
                          • engelwood39
                            • Mar 2015
                            • 93
                            Here are the pics of the main board dskall.
                            Dick Barton, Do you suggest that I replace all the capacitors on the power board? Also were you able to clarify what point you wanted me to test voltage at? Was it the CN1801 or CN801? (The attached pictures with those close up are on the post 6 up from this one)
                            • dskall
                              • Oct 2016
                              • 2905
                              • usa
                              Not a board I am familiar with having bad caps
                              • dick_barton
                                • Aug 2015
                                • 6643
                                • Wales
                                CN801 I think it's marked. There's a legend on the board naming the pin out so if you could provide the voltages alongside could prove useful.
                                http://www.ebay.co.uk/itm/Repair-Kit...-/230579176045
                                You may have an EEPROM problem if the set is rebooting but it's best to check the voltages are correct and caps have not failed first.
                                • cliff_hootarski
                                  • Jul 2006
                                  • 411
                                  This is what I was thinking of when I said bad caps (on the power supply) could corrupt the eeprom data.
                                  https://wiki.samygo.tv/index.php/UnB...y_EEPROM_Reset
                                  However, I don't see your TV listed.
                                  • vinceroger69
                                    • Mar 2012
                                    • 6714
                                    does heating or cooling the boards alter anything?
                                    • engelwood39
                                      • Mar 2015
                                      • 93
                                      Here are the voltages:
                                      Power on/off: 2.78V
                                      STB 5.2V: 5.233V
                                      12V: 11.95V
                                      5.4V: 5.38V
                                      13V: 12.95
                                      Just to clarify what is is doing: It plays a start up tune (i think its a startup tune) and then the backlight comes on with nothing displayed. It stays illuminated for approximately 30 seconds when it shuts down for a couple seconds and then starts the cycle over again back in a loop.
                                      I already ordered the Ebay kit that has all of the caps that are on the board. Not sure it that is a waste of time at this point? Here is the kit:
                                      http://www.ebay.com/itm/330524305728...%3AMEBIDX%3AIT
                                      • engelwood39
                                        • Mar 2015
                                        • 93
                                        Power on/off: 2.78V
                                        STB 5.2V: 5.233V
                                        12V: 11.95V
                                        5.4V: 5.38V
                                        13V: 12.95
                                        Would it be recommended to try replacing all the capacitors on the power board at this point, or should I look in another direction?
                                          09-07-2024, 05:50 AM
                                        • TR103
                                          by TR103
                                          - it keeps rebooting
                                          01-22-2025, 04:12 PM
                                        • plytek
                                          Samsung QE50Q60TA rebooting
                                          by plytek
                                          Hi all.
                                          I'm trying to fix my Samsung QE50Q60TA TV.
                                          IT's rebooting every few seconds.
                                          I have done some tests and it looks like it stops rebooting when I tape pin 46 (I thinks it's FB_1) on the ribbon tape that connects two boards atteched to screen, but nothing is visible, just backlight is solid and I can hear sound. Taping over other pins doesn't work.
                                          Have also soldered two pins on the motherboard to check if I can get an image on the rights side of the tv, but it keeps rebooting.
                                          Can anyone suggest what I can test and do to get it working again please?...
                                          02-08-2025, 06:02 AM
                                        • unimatrix93
                                          SAMSUNG UE55TU7002KXXH rebooting
                                          by unimatrix93
                                          Hello everyone, I'm working on a Samsung TV that constantly rebooting.
                                          MB/PSU unit: BN9654185QE
                                          It loads up to the main menu then as soon as the backlight goes brighter it reboots.
                                          First I suspected the LCD panel, so a disconnected the LCD display from the mainboard but did the same thing.
                                          Then I removed the backlight connector which only delayed the bootloop by a minute maybe, I know it because I test it with the remote, it does gives the menu sounds a bit longer.
                                          Also I have to note, that the MB/PSU combo gives out a very noticible...
                                          04-07-2025, 09:49 AM
                                          09-06-2024, 11:40 PM
