Hitachi LE55A6R9A confirm bad LEDs
  • jason424
    • Dec 2015
    • 187
    I was just given this set, I've looked at many posts and videos that point towards the leds going bad on this set. I've tested the boards and the leads going to the leds and get high voltage at them (287 at red/black lines in pic attached). According to this post sounds like that means an open circuit and the leds should be tested?
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: Hitachi LE55A6R9A confirm bad LEDs
    My experience so far is bad leds. If they flash when you first turn it on I pull the panel and inevitably failed leds.
    • jason424
      • Dec 2015
      • 187
      I don't get a flash at all when turning the set on. Just red to blue power led changing.
      Also, is there a specific brand of led tester to look for? Price point?
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        Have you disconnected the main board and then powered up to see if the backlights come on.
        Do you have a photo of your circuit boards?
        • jason424
          • Dec 2015
          • 187
          If I disconnect the main board I got nothing. No power led or anything since it looks like it's integrated into the main. Pics attached.
          • dick_barton
            • Aug 2015
            • 6643
            • Wales
            Behind CN201 you have legends along side the pins. What voltages do you have on each pin.
            Pin number.......Pin Name...... Pin voltage
            etc
            • dskall
              • Oct 2016
              • 2905
              • usa
              Need voltages from connector that goes from power supply board to main board. Will need pin#- PIN DESCRIPTION -Pin voltage in standby-Pin voltage when pushing power button and picture of connector on power supply board.
              Format:
              Pin# - Pin Description - Pin Voltage standby - Pin voltage power on
              1 - XXXXXXX - XXv - XXXv
              2 - XXXXXXX - XXXv - XXXv
              3 - XXXXXXX - XXXv - XXXv
              4 - etc.
              Here's tester led tester I have. http://www.ebay.com/itm/NEW-110V-265...item3ad03eb6c6
              • jason424
                • Dec 2015
                • 187
                CN201:
                12v: 12.2
                12v: 12.2
                12v: 12.2
                GND: 0
                GND: 0
                GND: 0
                GND: 0
                BK/ON: 3.2
                ADJ: 3.1
                PS/ON: 3.2
                EDIT: Pic attached of desc/table
                • jason424
                  • Dec 2015
                  • 187
                  CN202:
                  268
                  187
                  CN203:
                  187
                  0.00
                  When testing CN202(red) and CN203(black) I get 287 as outlined in the first post.
                  • jason424
                    • Dec 2015
                    • 187
                    con901:
                    gnd: 0
                    key0: 3.3
                    key1: 3.3
                    led-g: 3.0
                    led-r: .1
                    ir-in: 5.2
                    gnd: 0
                    5v: 5.2
                    • jason424
                      • Dec 2015
                      • 187
                      con701:
                      l+: .2
                      l-: .2
                      r-: .2
                      r+: .2
                      • Andrew F. Ali
                        • Jan 2014
                        • 2450
                        • Trinidad & Tobago
                        Confirmed....Bad LED backlights.
                        • jason424
                          • Dec 2015
                          • 187
                          Thank you everyone for your help/confirmation.
                          Looks like ShopJimmy is out of the replacements at the moment so I will wait until they're back in stock. In the mean time I will order the tester.
                          Is is best to just replace all the led strips instead of just isolating those that are bad and just replace those?
                          • dskall
                            • Oct 2016
                            • 2905
                            • usa
                            Preference I guess I just replace bad leds. Shopjimmy is selling used strips. Thier like bad caps now they all going to fail
                            • Shane711
                              • 493
                              I got this TV, I am just going to heat the bad LEDs off the strip and heat replacement LEDs from another TV onto the strip. Why buy a strip when I have lots of these LEDs laying around. A heat gun works great for changing them out, a soldering iron will NOT work.
                              • jason424
                                • Dec 2015
                                • 187
                                I ordered the tester and found that all but 1 were out on a strip so I replaced the whole strip and removed the one that was still good and threw it in my parts pile
                                • Pipolups
                                  Corsair K70 LUX RGB dying LEDs
                                  by Pipolups
                                  Hi there !
                                  I'm having an issue for several weeks with my quite old K70 LUX RGB keyboard. I haven't used it for few months, and once I setup up again my desktop computer, I got several dead LEDs on that keyboard. I tried the Corsair troubleshooting thing (disabling options in iCUE, ...) but nothing changed so I conclude that for some reason some LEDs went in retirement...😅
                                  Decision taken to change these LEDs as I have access to desoldering iron and binocular magnifier, I wrote a ticket to tech support, hopping to obtain the LEDs reference and... They refused to tell me 🙄...
                                  10-08-2024, 11:58 AM
                                • lmcancu
                                  RCA RLDED 4331B: 43 inch LED TV: Backlight issue
                                  by lmcancu
                                  Hi I am having an issue with the LED backlight of this TV. I can see the picture with a flash light, so I determined it was a backlight issue.
                                  Initially, after opening it I found 2 shorted and 1 open LED on 2 strips (total of 4). I removed the LEDs and shorted the pads together to verify if the backlight would work.
                                  Testing it, I found the backlight turned on and I measured 54V when TV was in standby (off), and 100v when TV was turned on. The 4 strips each contain 9 LEDs, so 36 in all minus 3.
                                  Instead of putting it back together I decided to replace...
                                  04-01-2023, 01:11 PM
                                • Jaime Morillo
                                  Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
                                  by Jaime Morillo
                                  Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
                                  The TV was stuck on the logo and I couldn't access the update menu.
                                  I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
                                  The image result was good, but the image is inverted.
                                  The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
                                  Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
                                  08-18-2025, 11:38 AM
                                • THE GTC
                                  Insignia NS-37D20SNA14 intermittent LEDs
                                  by THE GTC
                                  So I use this TV daily as a second monitor for my PC or my Playstation - at one point a few months back I tried to fix the problem - but in the process, I figured out something that works so I haven't posted this for awhile. It is an annoying trick to have to do though, so I decided to post about it to see if anyone could spot what's wrong. It baffles me because it works on it's own half the time.
                                  When I first got this TV, I was told it wouldn't turn on, and of course I did the flashlight test, and the image was there. Also, the red LED on the front indicated that it had power (it...
                                  11-03-2020, 02:40 AM
                                • sorrowfulfloyd
                                  Samsung UE32J5373AS Weird LED Problem
                                  by sorrowfulfloyd
                                  Hi all, first time seeing a LED problem this weird so I wanted to discuss with y'all before handing back this TV to my costumer.
                                  This TV came to my shop with no picture but sound present. So I thought ok this must be a LED problem and I shine a light with my phone's torch amd and yup I see the image. So I disassemble it and before changing the LEDs I check the motherboard voltages (this unit works with an external 16V DC brick) and I see 54 volts at the input pin of LED strip, considering this TV has 2 strips of 7 LEDs which at 3~ volts it must be equal to like 42 volts. I remove...
                                  12-23-2022, 07:00 AM
