LG60PC45 capacitors
  • habanerocat
    • Nov 2014
    • 96
    • Ireland
    LG60PC45 capacitors
    I an trying to repair one of these boards with bad caps. I foolishly removed all the bad caps, thinking they were all the same value, 7 by 3300uF 10V. However then I noticed one was 680uF 50V.
    Can anybody tell me which one is 680uF please?
    I can't find a circuit diagram anywhere for this board, EAX31466601/5.
    Would the odd one being 50V help me in any way?
    Please help and thanks.
    Habanerocat
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: LG60PC45 capacitors
    Lol I did one of these luckily for you a video too will upload it as I stated the positions of the caps in it.
    • habanerocat
      • Nov 2014
      • 96
      • Ireland
      That's great!
      But I don't understand, upload it to where?
      Thanks.
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Youtube will be in a few days.
        • habanerocat
          • Nov 2014
          • 96
          • Ireland
          By the process of elimination and some guess work I replaced C222 with the 680uF and all seems to be working ok now.
          Might help somebody else out.
          It's a BIG TV.........
          • dskall
            • Oct 2016
            • 2905
            • usa
            You can double check by measuring voltages at caps against voltage rating on them.
            • dokymobil
              • Jul 2016
              • 7
              • Egyesült Királyság
              Habanerocat
              hi .i do the same wrong way,when im just find the bad caps , and i just desolder all of them,but when i check it , one of them it was different,and i have no idea,where come from.....
              i do find it. it was on the "small PS board" position is c202
              i changed all caps , and the tv is go back to live.
              but after 2 days continued to use it,without switch on , my tv is just go to standby.
              im just realized,the two fans is newer turning on,so maybe this tv just overheated,again. but,i can't se any bad caps.
              when i try to switch on the tv, i hear two click noise(from relays) and after 6 green light flashing,just back to standby.
              if i want to switch on again,10 or 11 green light flash and back to solid red without relay clicks.
              • dokymobil
                • Jul 2016
                • 7
                just a short update.
                i find the problem,the two small fans is not working,one of capacitor is just exploded.(c237) .so i decided to take the long fan from my another LG 50" tv , and install into big one.
                i find the "Proper" place for the "big one" , im just remove the old fans and put the "new" on place.and i make a thermal controller and jobs done ! My tv is back to life ! I will share some pictures today,maybe is helpful for someone.sorry about my poor english.
                Good luck !
                • eryjus
                  by eryjus
                  05-10-2023, 11:21 AM
                • Paxman_Swede
                  by Paxman_Swede
                  Hello!
                  01-14-2025, 09:51 AM
                • captain150
                  by captain150
                  03-16-2025, 07:34 PM
                • Foetuss
                  Gigabyte GA-6OXT :: caps question
                  by Foetuss
                  Good evening
                  I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
                  Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
                  But I was also suprised about the bigger boys, which are 330µF 25V.
                  Could it be they used 25V caps because they were cheaper / available at that time?...
                  02-11-2025, 12:22 PM
                  by momaka
                  03-12-2025, 03:42 PM
