Dick Smith GE6824 no backlights plus more
  • dkneyle
    • Dec 2013
    • 441
    One of these cheap Chinese TVs made for the re-badging market. 32 inch. Pulled from the dumpster at the garbage tip. Surprisingly clean, only just dumped I'd say.
    The indicator LED changes from Red to Green. No sign of any image even with the flashlight test. All voltages other than backlight come up good. The BL-ON signal is good and remains constant. At power on the backlight give a quick flash, but a check of backlight voltages show a peak at the expected voltage then a quick cascade back towards 0 volts.
    So the mainboard appears to be sending out the correct signals to start the TV. For some reason we get the volts for the LEDS but then this collapses. And no sign of a video signal to the panel.
    What am I missing here in this diagnosis?
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Dick Smith GE6824 no backlights plus more
    Looks like a classic led fault.
    • dkneyle
      • Dec 2013
      • 441
      I'd thought because I saw the leds flash on then they were OK. You think not?
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        No. The flashing leds tend to be symptomatic of led problems. Looks as though you may have some shorted out leds. It could also be poor interconnections between the strips but I think it's a led problem.
        • dskall
          • Oct 2016
          • 2905
          • usa
          Have you looked with menu up? With bad led's voltage will ramp up till it hits preset voltage and go into protection. If all is good it will not reach cutoff voltage. I have an led tester as backlights are the new plague now. I can light up screen etc, with it.
          • dkneyle
            • Dec 2013
            • 441
            Even when the LED string is unplugged from the power supply it comes up to voltage then quickly cascades to zero as the capacitors discharge. Is that because it detects an open circuit and shuts off the LED supply?
              The LED driver circuit has two protection modes: over Voltage output protection when load is not connected, then over current protection if the load draw to much current.
                Can we see the good straight shot of the back side of the board? Also pictures of the whole back side of the TV showing how all the wires are connected.
                • dkneyle
                  • Dec 2013
                  • 441
                  Stripped the panel down. Found one LED that appears open circuit. I can make all other LEDs fire up when I put about 2.5 volts across them. Interestingly, the diode test function give 0.75V forward conduction for nearly all. A couple are at about 0.85V, and one doesn't read anything although lights up when volts are applied. Would I be right in assuming these different voltage LEDs might be on the way out?
                  • dkneyle
                    • Dec 2013
                    • 441
                    I sweated off the dud LED and replaced with one from another strip for a larger TV panel. Not sure if it's compatible? On the diode reading of my meter I couldn't get a forward bias reading. Anyway, re-assembled, and at switch on I had backlights and a menu. Confirmed therefore I had a panel backlight fault originally I guess? The backlight had a slight flickering to it like a joint about to go open circuit. I wondered about my workmanship on the LED replacement job? Lasted about 2 minutes before it failed. Dropped back into "2 seconds to black" syndrome. Then eventually nothing brought the backlights on.
                    It's an Innolux panel. I'm seriously thinking of junking it. I reckon other LEDs will fail soon enough.
                    • dskall
                      • Oct 2016
                      • 2905
                      • usa
                      Well seems a shame to junk one for backlights. Individual leds are inexpensive. Depends on your reason for repairing. I do it for hobby so would replace them all individually if necessary. Plenty of people have good success with various repair methods. Some say like you the repair doesn't last. I sell mine after and haven't had one come back yet. Need to keep backlights turned down as manufactures drive them to hard so they fail and you buy new tv
                      • dick_barton
                        • Aug 2015
                        • 6643
                        • Wales
                        Buy one led strip for this model (ebay/shopjimmy) and then use leds from this strip as replacements knowing that they are the correct leds.
                        Turn down the backlights and hopefully you should get many months of further use.
                        • max789
                          Samsung UE48H6410 replaced Mainboard but backlights doesnt go on
                          by max789
                          Hello, I have a problem with my Samsung UE48H6410SSXZG with the main board BN41-02156A and the power board BN44-00709A. Everything seemed like this, the TV could no longer be switched on, the standby LED always flashed 5x2 times. Backlight was off and no sound from TV. Also made the flashlight test and there was no picture.
                          I made the following tests:
                          1. Disconnected the main board from Power Board = backlight works.
                          2. Connected the main board and disconnected the T-Con = backlights does not work.
                          So I ordered a main board from Ebay also BN41-02156A but from...
                          01-18-2024, 06:56 AM
                        • bpcannan
                          VIZIO M557-G0: Backlights or ???
                          by bpcannan
                          'Morning,
                          I get sound and picture when powering on the TV and its stays that EXCEPT that the left half of the screen will dim every few seconds then return to normal while the right side of the screen performs as designed.
                          Did the soft and hard reset options pulling the plug, using the reet option in the vizio menu to no avail.
                          I checked the mainboard - found some popped capacitors so replaced it - but that did not change the situation.
                          I checked the t-con board. It is getting good power. Then I removed one ribbon cable to see if I could isolate...
                          10-29-2023, 06:36 AM
                        • jesterace
                          Samsung UE49MU6400 acts dead until disconnecting backlights, then works.
                          by jesterace
                          Hi everyone I have this TV which was dead one day when I tried to turn it on. I've had the cover off and there was just a pulsating/electrical clicking/ticking noise from the PSU. I disconnected the mainboard as sometimes this works to just fire it up with backlights on? That didn't help. Same noise. Then I disconnected the backlight cable from the PSU and the TV came alive. It appeared to respond to the remote and i'm pretty sure it's fully operational when there is no backlight connected.
                          However, I am in a dilemma.
                          I tested the backlight outputs with the lights disconnected...
                          10-20-2024, 10:15 AM
                        • x_orange90_x
                          Sony KD-75X750H no backlights
                          by x_orange90_x
                          I just removed the back cover to test the backlights because when I first plug it in it will flash once and then start dark but I can see the image. I got 131v on string 1 and 167v on string 2. Usually when I get a bad set the meter reads 300v and they won't light up. When testing, each set lights up inside the tv. When I plug in the power and check the leads with my multimeter both strings are only about 3v.
                          Does this difference in voltage between the strings indicate that the lesser has bad LEDs? Or is it normal that they are not the same voltage? I've read some about this tv and...
                          07-16-2025, 07:49 PM
                        • jimbofz
                          toshiba 65ul2163 dbl no backlights NOT BACKLIGHTS?
                          by jimbofz
                          Hi this vestel 65in tv had classic no backlights ,so nothing new there!
                          tested with b/l tester and the b/l seemed to be fine
                          so investigated psu 17ips72 (on this 65inch there are 3 fets and control iv type DB83630P)
                          did a thorough check on b/l circuit all ok .
                          When i tried again with b/l tester all ok .but then when i reinstalled psu all worked fine ,
                          could there be a component on psu that is causing the protection mode to stop b/l
                          .maybee causing it to be too sensitive?
                          it seems to me if the b/l have been on with my tester ,within a couple of minutes...
                          06-07-2025, 10:11 AM
