Troubleshooting TVs...
  • Roadkill203
    • Oct 2008
    • 68
    This is just a general question, but where do you start troubleshooting TVs? I have a TV that turns on (the green power light comes on), has sound (static), but no picture. I can provide the specific make/model if needed.
    I opened it up, checked the fuses with an ohm meter (both okay), checked all of the caps (none bloated or blown open), now I am at a loss.
    What are the most common problems that go along with 'no picture'? A bad picture tube? Is there a 'picture tube controller'? I know I probably sound retarded, so if it's better to take this to a pro, then I will.
    Any help would be appreciated. Thanks!
  • Wizard
    • Mar 2008
    • 2296
    Re: Troubleshooting TVs...
    Static is only with the tuner in out of band or dead, or have no 33V tuning voltage. Have you confirmed it is not in guide plus mode?
    Do you have video inputs? Is it working and clear pics?
    Cheers, Wizard
    • ironbot
      • Dec 2008
      • 8
      i have a Hyundai HPT4240 plasma tv, and need advice on what type of caps i need for it. they are square and bluemaybe about an inch long and half as wide, i think they are polypropylene,they are marked..SHINSHIN P1.0 (K)+-10% 630V. they are in the power supply.also maybe where i may be able to buy them. thank you in advance
      • Wizard
        • Mar 2008
        • 2296
        These are not the issues.
        Are you getting pic on the panel (getting menu, press the menu), works on any other inputs?
        Cheers, Wizard
        • ironbot
          • Dec 2008
          • 8
          a follow up. i found having warmed the caps up. the set will work first time.
          as normaly it will turn on then off. maybe bad electrolite?. i have read that sometimes caps loose there ability to opperate normaly when cold. or dried out. anyone confirm? thanks
          • Wizard
            • Mar 2008
            • 2296
            Certain these are the ones? Because there are electrolytic capacitor near by.
            Cheers, Wizard
            • ironbot
              • Dec 2008
              • 8
              i have read that these are the most likely wizard. along with an electrolitic. (50v 10uf) i have read that this one goes open. so heating it wont fix that one i think.so maybe its these ones?
              • kc8adu
                • Nov 2003
                • 8832
                • U.S.A!
                are the crt heaters lit?
                hear hv static when you turn it on?
                turn up g2 and see what you get.
                working on a jvc now that not only blanks video but shuts down with no vert out.
                keeps from burning a line in the tube.
                • ironbot
                  • Dec 2008
                  • 8
                  confirmed the cap with the prob i isolated it (with the help of a cardboard tube) and the set worked.
                  • ironbot
                    • Dec 2008
                    • 8
                    ok i ask again. anyone know where i can get these caps? SHINSHIN P1.0 (K)+-10% 630V 1 uF.....for Hyundai HPT4240 . the other cap i can get easy.
                    • Wizard
                      • Mar 2008
                      • 2296
                      1uF? 630V? Is it plastic dip or retangle?
                      Cheers, Wizard
                      • ironbot
                        • Dec 2008
                        • 8
                        wizard they are rectangle, blue and have SHINSHIN P1.0 (K)+-10% 630V on the top. from what i have read they are 1uf.
                        • Krankshaft
                          • Jan 2007
                          • 2328
                          It's probably either a Metalized Polyester cap or Polypropylene cap.
                          630 volts is a common voltage for those cap types.
                          They are usually pretty reliable (way more reliable than lytics) but with Chinachina stamped on it I'm sure that's the reason it failed.
                          Does it have any UL ratings on it? If so it's a line X or Y cap these are special caps.
                          • Tr0ll
                            by Tr0ll
                            Original T-con:
                            First replacement T-con:
                            10-07-2023, 07:48 PM
                          • JJAAMM
                            by JJAAMM
                            Problem
                            07-06-2023, 06:01 AM
                          • TR103
                            by TR103
                            - it keeps rebooting
                            01-22-2025, 04:12 PM
                          • Mgiffune
                            by Mgiffune
                            I have a 60 inch Samsung UN60EH6000F flatscreen TV. The screen went black a few months ago Sound is good, backlight is good, no menu. I replaced the TCon board with a used board purchased from Ebay. It worked fine for a 3-4 months, then the screen started β€˜fading' back. Once again, sound is good, backlight is good, no menu. However, this time the picture looks fine for about 10-15 minutes, then fades back. If I power cycle the TV, the display reappears, for another 10-15 minutes, then fades black again. Repeatable ever time.
                            I ordered a supposedly β€˜new' Tcon board this time, and
                            06-09-2024, 10:28 AM
                          • DCJack
                            B&K 707 tube tester. I need help.
                            by DCJack
                            Hi everyone!
                            I managed to get my hands on a rough condition B&K 707 for "the best price" because it was not working. It's my first tube tester and I'm really wanting to get it up and running. I downloaded that manual that has the schematics and tested every resistor and capacitor and replaced the ones that failed. I replaced the missing 83 rectifier tube with a used but tested-good one. I also have a number 80 rectifier tube that I have used in tests before I found the 83 tube.
                            Initially I noticed that I was not getting the red on-light to turn on, but it...
                            03-05-2024, 05:05 PM
