Technika 40f21b-fhd
  • sordids999
    • May 2013
    • 2151
    Technika 40f21b-fhd
    Hello
    i have this tv stuck in standby would anyone have the firmware or know where i could get a eeprom from
    im sure its a firmware fault
    board number TP.MSD309.BP710
    thanks
  • vinceroger69
    • Mar 2012
    • 6714
    Re: Technika 40f21b-fhd
    what panel number does the set use? have you tried ohms supplies?
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Freeze epprom see if power up if so factory reset and download fw off umc site and update.
      • sordids999
        • May 2013
        • 2151
        Hi vince the panel number is V400HJ6-PE1 the only eeprom i can find is for the TECHNIKA 40" 40F22B-FHD-DVD but the board is different using TP.MS6308.PB710 so unsure if this will work ?
        plus there is this eeprom on OHM but again for a different model of technika http://www.ohmsupplies.co.uk/epages/...roducts/E2P200
        reece even if i freeze the eeprom i cant find the firmware anywhere including UMC
        • vinceroger69
          • Mar 2012
          • 6714
          if you freeze the eeprom does the set start ok? if so what about freezing it then reading it then re writing to a new eeprom
          • sordids999
            • May 2013
            • 2151
            No freezing it does nothing
            • vinceroger69
              • Mar 2012
              • 6714
              not sure then if its a eeprom problem or not maybe reece will have a idea is a replacement mainboard a resonable price? if available
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                Might be a regulator issue Ive had the very small 1F type fail on these start testing them first bud.
                • sordids999
                  • May 2013
                  • 2151
                  On further checking I have noticed a short in m7 smd diode maybe this is what's causing the fault
                  • vinceroger69
                    • Mar 2012
                    • 6714
                    it maybe hard but any parts that read short in circuit i remove and retset the part
                    • sordids999
                      • May 2013
                      • 2151
                      Correct you are Vince removed from circuit all good back to the drawing board
                      Got a message from ohm supplies today though :
                      We can reprogram the eeprom from the one fitted in the set but we don't have a firware upgrade for this set.
                      • sordids999
                        • May 2013
                        • 2151
                        Update:
                        Ended up trying this board and all working again
                        TP.MSD309.BP710 MAIN BOARD.
                        from a bush 40/233f led tv
                        • sordids999
                          • May 2013
                          • 2151
                          Recently had this tv for repair
                          Tv turns on fine but no backlights tested with my backlight tester and backlight was fine,so changed eeprom
                          And now up and testing at the moment
                          This may help someone in the future
                          • NSkyLab
                            Toshiba 55SL417U looking for EEPROM and Firmware
                            by NSkyLab
                            Hello everyone, I described the symptoms and measurements here
                            It seems I tried everything, my last idea is that the eeprom or firmware (or both) may be corrupt.
                            I'm not able to find eeprom and firmware dumps in open sources.
                            Hoping someone here has access to closed forums or manufacturer's service center resources and can help get those dumps?
                            01-20-2023, 12:29 PM
                          • Faluky
                            firmware for Marantz SR5008 stuck in update loop
                            by Faluky
                            After an update it stopped playing audio and video, I have reset it as it says in the manual and tried to reinstall the firmware over the internet but logging failed each time and I tried to download the firmware to install it by usb but it does not appear on the official page, could you help me? Since it would be a shame to have to get rid of him, European version Thank you very much
                            Best regards.
                            Anyone got their hands on firmware for Marantz SR5008 stuck in update loop
                            01-17-2023, 04:33 AM
                          • FlashFireSix
                            LG xboom PN5 stuck in demo mode(?). Looking for retail firmware.
                            by FlashFireSix
                            I took an ebay gamble on an LG xboom pn5 speaker which was listed as having battery issues (turning on then off).
                            I got it earlier today and concluded it's in a demo mode because of the following:
                            • When it's plugged in, it'll turn on and the power button will not turn it off
                            • Battery is healthy, reading 4.2v and not swollen, charges according to the xboom app
                            • the play/pause and volume buttons don't work
                            • You can pair to it and play music fine, as long as it's connected to power
                            • The bluetooth connection is disconnected after 5 seconds of audio pausing
                            • The DTS setting is defaulted
                            06-26-2024, 09:35 AM
                          • SidneyCanadas
                            93C46 and 93C56 EEPROM
                            by SidneyCanadas
                            I tore apart my instrument cluster for my 2008 Toyota Corolla made in 2007 in Cambridge, Ontario, Canada and pcb location: IC6=EEPROM is a surface mounted device with part # of 93C46W7, some claim the EEPROM out of a Camry part # 93C56 will allow odometer to roll over 299 999 KM or miles. The data sheet for both is below:
                            https://cdn.badcaps-static.com/pdfs/...c6e42b20d3.pdf 2
                            Anyone know if the Camry one will work on my Corolla?. And which EEPROM reader/writers do you all recommend I purchase that will allow me to read the old values of the old...
                            06-14-2023, 01:16 PM
                          • Meraxes
                            Ps4 Slim firmware update stuck on 53%
                            by Meraxes
                            I have a Ps4 Slim, it works perfectly, I wanted to update to firmware v 10.1 and now it remains stuck at 53%, before it had version 6.50
                            Hdd is ok, it is tested with hdtune pro
                            The Blu-ray worked perfectly before the update
                            I tried several USB flash drives, no change
                            The wifi module was changed does the same
                            Can someone help me ? can the southbridge have problems?
                            03-07-2023, 09:37 AM
