LG 50PZ750-UG loses menu settings when unplugged.
  • bdorset
    • Aug 2013
    • 30
    • St Vincent, Caribbean
    This Plasma TV loses its menu settings whenever it is unplugged for half an hour or more. TV goes back to initial setting from factory, asking to choose language, country etc. It does this every time the TV is unplug for several minutes even after I go through the process of initial setup. I attach a photo of the mainboard. Any suggestions?
  • heavymachines
    • Mar 2011
    • 1028
    Re: LG 50PZ750-UG loses menu settings when unplugged.
    Not retaining settings. For some reason IC1702 comes to mind. But have no idea honestly just a quick guess. I'll let the more knowledgable folks chime in on this one.
    I will say probability is high considering winbond is flash memory nand tech.
    • bdorset
      • Aug 2013
      • 30
      It looks like the user adjustable settings are stored in IC601. Is that correct? This set has several eeproms IC103, IC601, IC802
        LCD LED TV Service Menu Codes
        ALL LCD LED TV SERVICE MENU CODES
        Service Menu Code with Board Name
        China Universal Board / Jumper Board Service Menu Code
        Changhong Ruba Service Menu Code
        Ecostar LED TV Service Menu Code
        Orient LED TV Service Menu Code
        Haier LED TV Service Menu Code
        TCL LED TV Service Menu Code
        Samsung LED TV Service Menu Code
        LG LED TV Service Menu Code
        Videocon LED TV Service Menu Code
        Supra LED TV Service Menu Code
        Toshiba LED TV Service Menu Code
        Symphony LED TV Service Menu Code
        Veste/ LED TV Service Menu Code...
        10-31-2024, 03:58 AM
      • howardc64
        M557-G0 no WiFi/Bt no WIFIVendor file?
        by howardc64
        Thanks to Diah, got M557-G0 LCD panel buffer board repaired and running ( link ) Next challenge is no WiFi/Bt despite module on the main board and getting 3.3v supply (3.45v measured)
        • TV Menu shows Network Access Point option (enet unplugged) but menu can't select that entry
        • Service Menu shows many Bt/Wifi info missing
        • Vizio app shows no WIFIVendor file
        Prior owner used enet and said turned off wifi somehow. It seems system config info for wifi might be missing. Anyone experienced this before?
        • Tried countless enet unplug (user manual said need to unplug enet to get to wifi menu), factory
        10-15-2024, 01:12 PM
      • vf fa
        EIZO CX270 - No signal but Backlight and Panel works, logo works, admin menu works. OSD doesn't. What?!
        by vf fa
        Hi, so i guess I´ll have to make a new topic here, as i browsed through hundreds of other threads but couldn't find a solution to my problem yet.
        I got a EIZO CX270 from a friend. He said it doesn't work anymore and wont display any signal or take any OSD inputs. Well, as an aspiring photographer I couldn't say no, could I? Thought it was an easy game, replace a bad cap and have a working monitor. But nooope, it wasn't supposed to be this easy.
        So let me start with the problem description. I'll try my best not to skip anything so this might get rather long.
        01-31-2024, 01:40 PM
      • eltano4i20
        [HELP] SAMSUNG NP270E4E-K01AR
        by eltano4i20
        1) Error trying to enter the BIOS
        --> [F2] won't let me enter the BIOS. To enter the BIOS, I had to create a shortcut and then type C:\Windows\System32\shutdown.exe /r /fw /t 1 in the destination. This forced it to restart and enter the BIOS.
        Once inside, I went to the BOOT menu, but, surprise, it wasn't there. I got the following message:
        BOOT PRIORITY ORDER (img-05)
        1- Windows Boot Manager
        2- SATA HDD
        3- NETWORK
        4- Debian
        2) Error trying to access the BOOT MENU
        --> I restarted the notebook and pressed [F10] but the BOOT...
        07-04-2025, 12:39 AM
      • i440bx
        Elitebook 820 G3 engineering example: CMOS settings lost despite new cell
        by i440bx
        Hey there,
        I got a HP Elitebook 820 G3 Engineering Sample Laptop and I want to use it. Besides the difficult things at the ES-BIOS I have a big problem by saving the main BIOS settings.
        The laptop does not have a big battery because it was dead, but I already plugged in a new CMOS battery.
        It takes about 5min without power and the BIOS settings are lost. Unfortunatly I dont understand why the BIOS settings are only saved with power connected and this is the reason why I registered here.
        As written above, I plugged in a new CMOS cell and checked...
        08-19-2024, 02:28 PM
