Panasonic Viera Plasma TC-P60S30 (weird blob on screen)
  • heavymachines
    • Mar 2011
    • 1028
    Re: Panasonic Viera Plasma TC-P60S30 (weird blob on screen)
    Agree +1
    • joeblah
      • Apr 2016
      • 65
      thanks heavy, tw, reecey, I appreciate the tips and resources. have determined definitely have a bad SU buffer and bad SC/Y. I totally agree about sourcing parts from eBay, but sometimes SJ doesn't have what I need in stock. I always try SJ first. SJ sells on eBay too, I prefer to buy SJ through eBay for the "bonus bucks." pretty sure people just remove parts from cracked screens and sell the guts without any testing. gonna order boards now and I'll update the post when the parts arrive. thanks!
      by the way, is there a trick to connecting the ribbon cables from the panel to the buffer boards? I get it all aligned and get the cable past the plastic notches and locked down. just kinda difficult, is there a better way or is that par for the course?
      • heavymachines
        • Mar 2011
        • 1028
        There are few others like tristate module, electropartsonline, Payless components etc....
        • joeblah
          • Apr 2016
          • 65
          thanks heavy, I looked at Payless but they were out of stock on one part, ordered from SJ instead. thanks for the heads up on tristate and electropartsonline. I think I saw some for sale on eBay from electro. Cheers!
          • joeblah
            • Apr 2016
            • 65
            hello again, back to update. so, I ended up replacing the SC, SU, SD, and power boards. now the TV works again but I still have a few horizontal lines. I know this could be from the ribbon cables not seating properly so I want to adjust them.
            here is where I screwed up last time; I adjusted them while the power was on! eek
            so my question is, what's the proper way? remove power, let the caps drain... do I disconnect SC2 and SS11? thanks!
            • heavymachines
              • Mar 2011
              • 1028
              Yes never on plasma do you disconnect anything while energized the high current will ripple and surge and pop things. Yes discharge for minimal of 30 seconds power cord must be disconnected.
              • chrismurphy
                • May 2014
                • 251
                • australia
                #27
                Just some info that i have found for Panasonics plasmas
                for the tabs ,make sure they are seated very well . when they are hold to tabs in and unclip and reclip the locking tabs a few times before leaving in the clipped state , i find that this usually corrects the issue with connections . also inspect the tap fingers for any damage as this can happen if they are not inserted correctly
                • joeblah
                  • Apr 2016
                  • 65
                  thanks chris, I took your advice and tried that a few times. didn't change anything. there doesn't appear to be any physical damage. is it okay to spray in some DeOxit contact cleaner?
                  • joeblah
                    • Apr 2016
                    • 65
                    well, cleaned with deoxit silver and gold. lines changed a bit but they are still there. could something else be causing the lines? if I tap on the ribbon cable the lines change. I've reseated them a dozen times.
                    • joeblah
                      • Apr 2016
                      • 65
                      all is good now! found that in order to get the ribbon cables to seat perfectly into the SU/SD boards, I had to loosen the screws holding said boards. seems so simple, hope it'll save someone else the frustration.
                      • badcappo
                        Dead Panasonic Viera TX-P65STW50 Plasma TV
                        by badcappo
                        Hello, got a ST50 plasma TV for repair. No signs of life, not even blink codes. Opened it up to check the power supply, type MPF6914. Apparent issues from visual detection and measuring for shorts:
                        Diode type G972s6 - D101 with a short
                        Mosfet 06N90E - Q301 shorted
                        Fuse T5AH 250V - F103 blown
                        Diode D301 shorted
                        Relay DG1U-17VDC II - RL001 blown
                        I have not found a circuit diagram. Maybe someone here already dealt with a similar issue? Thanks for tips where else to check 😀...
                        11-24-2024, 11:27 AM
                      • LITEZONER
                        Panasonic TH-65PF9UK 65" plasma display weird issue
                        by LITEZONER
                        forgot to put the model number in the last post, could not edit it, guess I waited to long. anyway, has anyone seen this weird issue on one of these plasma sets, I was thinking maybe a loose ribbon, but wanted to check if anyone had seen this before. thank you...
                        10-22-2021, 09:27 PM
                      • Loki_Fido
                        (Weird) BIOS info for HP Pavilion Aero 13-be1021AU
                        by Loki_Fido
                        Hi folks,
                        This HP Pavilion Aero 13-be1021AU came to me for a repair. And it seems to have a weird BIOS chip. (Pic attached)
                        I asked my CH341A to read it and doesn't even know what to do with this. We are both very confused.
                        BIOS - XMC 25RU128CH10 (1.8v)
                        What the heck is this? I looked all over the MB. This is the only bios.
                        When I asked the NeoProgrammer to detect it, it just pops up an empty screen, and asked me to enter the bios number. And when I did, it doesn't do anything. NeoProgrammer showed me just this SPI ID: 204418. Don't know what...
                        03-20-2025, 01:57 AM
                      • ArMaaN376
                        Samsung PS51E550 Plasma TV
                        by ArMaaN376
                        I am having Samsung PS51E550 Plasma TV. While the TV was working, a crackling sound heard & video went off with audio still ON. After switching it off & ON, the red LED on TV blinks six times & then off.
                        Opened TV cover & observed foll
                        a) Green LED on the small PCB blinks at @5-6sec ON & off for 3-4 secs. Red LED on logic board ON
                        b)Vs & Va on power supply board raises momentarily to 209v & 58v resp & then drops.
                        c) Cold test on Y-main board shows all 3 pins of FGPF4536 IGBT short to Grnd.
                        How to confirm Y -Buffer board...
                        06-19-2024, 04:05 AM
                        APC BR1000G battery backup has a weird issue sometimes a bad battery icon and making a weird sound for about 30 seconds
                        This started a few days ago and does this about every 8 hours
                        After it does this it goes back to normal no bad battery icon and no weird sounds and it goes to battery backup mode so I am not sure what is going on with this battery backup
                        The battery backup is about 3 or 4 years old
                        Dose anyone have any idea on how to troubleshoot this issue I have never had a battery backup do this kind-a thing before so I am not sure exactly how to troubleshoot it and where to start
                        06-02-2024, 02:30 AM
