Philips 32pfl3403d/27 no power
  • vinceroger69
    • Mar 2012
    • 6714
    • uk
    #101
    Re: Philips 32pfl3403d/27 no power
    check resistane or voltage tv turned on black probe on metal tv chassis what dc voltage to both sides of the fuse?
    • Georgia088
      • Sep 2014
      • 109
      Ok. I checked the fuse and it is good. Is there any thing else I can try or anyway to combine the two boards to make one work? I can return the main board it but I want to get the tv working. I can't find any other exact matches for this main board. Thanks!
        So do you have 12VDC at both ends of the fuse with ref to GND?
        • Georgia088
          • Sep 2014
          • 109
          I had 11.8v to both sides of fuse.
          • Georgia088
            • Sep 2014
            • 109
            Ok, so I got a little side tracked on this project, but I purchased another main board for this tv. I plugged it in, and I get basically the same thing that I got with the first replacement main board (The white light on front comes on the a blue light comes on on the inverter board (I think this is the correct name) but there is nothing on the screen. Any ideas what I can check?
            Also, Once I press the power button after the tv is plugged in, the white light on the front of the tv comes on. The white light will not go off no matter what I do unless I unplug the power chord. Even if I press the power button or hold the power button down.
            THanks!
