Re: Panasonic 65" VT20 10 blink code
Well I have an update.
The replacement IC's came in. I soldered the chip in and turned the TV on. It worked!. I checked output voltage from the IC it was 8.5V. Then I turned the TV off.... and tried to turn it back on again. The relay clicked to turn on and then the TV turned off with the same blink code again. Bugger...
The other symptom is the IC does get hot while the TV is on.
Since I've tested most other parts in circuit I feel I'm chasing my tail.
I've done a non normal fix I guess and used a 5v relay to trigger when the 3.3V panel on comes through. This triggers a separate adjustable output voltage regulator which is powered by the 15V and changes it to the required 8V and feeds that back into the circuit.
The long and short of it is that this seems to work but theres obviously some other part in circuit thats not performing correctly. I've had the TV on for an hour and nothing seems to be getting hot.
If it dies I'll just have to get another board.
Thanks very much for the help in finding the faulty area!
So far I've fixed a corrupted eeprom with it and done a conversion on a new zealand board. Kinda fun transferring the DNA across.
3M and Pomona are 2 brands for those clips. Not cheap, I'll get one one dayLeave a comment:
HERE.
has a link for downloads, not sure what'll you'll find
https://www.youtube.com/watch?v=L0ChYNwunUE
what sort of playing?
If you're playing with the A boards, copy and save the original contents , label so it can't get mixed up. Pay attention to whether it's a 24 or 25 series chip as the pinouts are different and how you set up the the CH341A too.
If it's wrong you'll see the led go dim, things get hot and then some of that smoky stuff starts to release.
I know the original clip and cable was rubbish, broke after a few uses,
So did you get a clip with yours to clip onto the chip while its still soldered on the board?
Otherwise mine must have been too cheap and missed the whole clip idea...Leave a comment:
I know the original clip and cable was rubbish, broke after a few uses,Leave a comment:
Postage of what?
I'm thinking down the track a bit for the 65"
No manuals will make it hard but essentially if you think of the board as a processor then the only difference between any model is the firmware , data, program loaded on non volatile memory.
some of it is common. So either desolder and swapover or copy the data and overwrite the chips but you'd need a clip.
I've had some fun with a CH341 but the clips supplied are rubbish
CheersLeave a comment:
Thanks heaps.
I'd never heard of utsource.
Cheapest other one I found was the same price but postage was minimum of $30.Leave a comment:
you could try utsource but check package and dimensions of what's currently fitted just in case there's more than one package size.
Datasheet has it as SOIC 8, 5mm x 4mm
UTSOURCE has SOP8, which could be an error
expect 3 weeks turnaroundLeave a comment:
but as suggested, do the "comparison resistive" measurement around the chip. This may give you an idea if the chip is indeed the culprit or a supporting circuit component is fried. The "re-chip" is somewhat of a "last resort".Leave a comment:
I dont mind to try desoldering/soldering the IC. However I'd like to find and order a backup one or 2 just in case and then try while the backup ones are on the way here.
The problem is I cant find anywhere to order the things to send to AustraliaLeave a comment:
Good progress anyway I think. I was mainly asking for resistance on pin 2 to see if there was a short in the circuit on the output side of the ic dropping the output down. Doesn't seem to be shorted as the 8v you supplied remained, though there is a difference in the resistance reading. I guess you could confirm if it's the ic or not by swapping them between the boards. Resistance readings on all the pins might give some direction too. If you do remove the ics take readings on pads while ics are off. Also a bit of freeze spray may just kick the bad ic into action - maybe try that first. Just throwing out ideas.Leave a comment:
measure the same points in reverse as there is a diode in the circuit which maybe impacting measurements.... maybe. It doesn't look good for the IC based on some of your work to date. But possibly do some more resistance check comparison between the working board and non-working. This may give you some further pointers to either the IC or supporting / connnected circuit component issues.Leave a comment:
Well I tried a bit more experimenting but everything seems OK.
If I put 8V on pin 2 output everything works. I do have to wait till the IC tries and fails to start itself otherwise it goes ballistic and starts outputting 14.5V which is dangerous I guess.
Anyway I turn the TV on... wait for the IC to try and start and give up. Then give it 8V from external powersupply. Everything is happy and hardly and power draw from the powersupply.
The IC voltages are then:
1. 0
2. 8
3. 12.75
4. 3.27
5. 0.8
6. 5.1
7. 5.2
8. 15.89
So everything seems happy and the TV runs sweet.
I checked the service menu and it reckon the TV power on time is 222 and turned on and off 192 .
Anyway does it make sense then that this IC is just stuffed or maybe its too sensitive in detecting a short?Leave a comment:
OK I gave the bad board 0.1V on pin 5 again.
The voltages then are stable (for the brief moment I let it stay on as they are obviously wrong)
1. 0V (Ground)
2. 11.47V (too high should be 8V)
3. 15.4V
4. 3.3
5. 0.1V (I didnt check this pin if it ended up higher or not)
6. 0V
7. 5V
8. 15.89
The TV turns on like this but I dont want to leave it on with 11.47 instead of 8V.
I might see if I can make up a separate circuit from pin 5 to pin 2 as described in the IC datasheet.
Maybe something is dragging it down so its not getting the input it needs.Last edited by infrag; 03-19-2017, 12:31 AM.Leave a comment:
well it doesnt appear to be the diode. I've tested it and it appears OK. Tried a replacement and that does the same thing anyway.Leave a comment:
Excuse my ignorance but is there a way to test the diode in circuit?
I realise I could check voltages on the pins when its on but since its only on for a split second before voltage drops how can I check this?
I've tried removing the diode from the board but its been a pig and I feel if i try anymore I'll wreck it.
I do have some non surface mount diodes lying around but I have no idea what specs they need to have if I had to replace it.Leave a comment:
I did my pin 5 test with my bad board. I couldn't at the time check the other voltage while I was doing this.
Thanks for the feedback. I'll check it now.Leave a comment:
Assuming...7 Photos -
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... -
by sam_sam_samI did not have any 27uf @ 50 volt capacitors but one nice thing is that it has enough room for two capacitors in parallel a 22uf and a 4.7uf @ 50 volts 22 plus 4.7 equals 26.7uf which so very close to 27uf I will show some pictures of it sometime tomorrow
After all of... -
by canadaboy25I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
The panel is primed as there is a slight glow from the entire panel. This means the problem should be logic related. The service manual also confirms this and recommends replacing the A or the D board.
I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was... -
by tikuHello Friends, i am having this model Panasonic TH-L32C30D, suddenly when i switch on, it went on One Blink, after looking at the service manual it says Backlight_SOS, I can see the menu on the tv screen for few seconds in the dark with the help of flashlight Before it goes into blinking cycle.
I was having a backup P-Board which i replaced it and now its working fine, but i need to repair my faulty P-Board, as now its getting dificult to find any type of spares of this model, so can any friend who is master in Panasonic Repair, be kind enough to guide me or tell me which component should...09-05-2021, 05:02 AM - Loading...
