RCA led42c45rq no picture, unable to turn off
  • jasonbay13
    • Jul 2014
    • 185
    • usa
    i'm trying to fix this tv for a friend of a friend, but i have never seen a problem like this before and have no idea where to start.
    The tv, according to a manual i found the red led is standby and goes out when turned on. When i plug in the tv the red light comes on and i get 13.5v (too high?) at the 12v pins and 5v at the 5v pins. the backlight connector is showing 60v and the panel does not light up. i have tried the flashlight method, but nothing on screen that i can see (no dim flash of any sort, either). I am unable to turn the tv back off as pressing the power button does nothing and has to be unplugged and plugged back in to go back to standby.
    the caps all tested good on the power supply board. (first thing i checked).
    so what i think i am looking at is a bad backlight and mainboard but that is mostly just a guess. i'm stumped. multiple seemingly unrelated problems?
    thanks for reading through and potential solutions
  • CapLeaker
    Leaking Member
    • 8158
    Re: RCA led42c45rq no picture, unable to turn off
    check the DC voltage of the PS-On and the BL-On pin on the PSU. I am thinking you may have a main board problem only. However if there is proper voltage on the BL-On pin, then yes, you have a backlight problem too. So check those voltages and report back.
    • jasonbay13
      • Jul 2014
      • 185
      • usa
      looks like i missed a section of text. the above voltages are specified with the tv on (red light off).
      with the tv off (red light on) the only voltage is the 5vsb.
      with the tv on the ps-on is 4.6v and bl-on is 5v.
      • CapLeaker
        Leaking Member
        • 8158
        It looks like you have at least 2 problems. PSon and BLon are there, but no back lights. So there is something wrong with the wiring or most likely a bad LED that needs to be fixed first. The not being able to turn off problem is a main board problem.
        • dskall
          • Oct 2016
          • 2905
          • usa
          You might have a look at this http://www.shopjimmy.com/rca-42lb45r...eprom-only.htm - TV turns on but there is no backlight (LED indicator shows TV is on but there is no image
          • Rjholly71
            • Jan 2017
            • 6
            • Usa
            looks like a lot of backlight issues with rca
            • dskall
              • Oct 2016
              • 2905
              • usa
              It's only a problem with TV's that have led backlighting. Which is all of them now!
              • koby058
                vostro comes up with back light but no picture
                by koby058
                Hi people!!
                The owner said it showed bad picture once in a while (attached)
                I see that there is back light but no picture.
                I want to ask if it is possible to disable the NVIDIA GPU and use the intel one?
                Also attached schematic and BDV
                LINK to schematic & boardview - https://www.badcaps.net/forum/troubl...ll-vostro-5590...
                07-13-2025, 01:03 PM
              • dronerat
                Samsung UE48JU6400W - back light on, sound on, sometimes picture.
                by dronerat
                Hi Guys,
                This forum has been in great help to me, but I stumbled upon a strange problem with a salvaged Samsung TV that I am banging my head to troubleshoot.
                PSU: L48S6 FHS BN44-00807D
                T-Con: BN95-01937A
                Panel: CY-GJ048HGLVLH
                MB: NA (Currently as the TV is assembled and forgot to take picture)
                As I said earlier I have some issues with the TV I got from a friend of mine. The TV had no picture, but sound, back light and everything else was working fine.
                It was sent to an authorized service for repairs and returned with the...
                05-15-2020, 08:03 AM
              • SluggerB
                Panasonic TH-50PX80 killed by lightning strike, help me save her!
                by SluggerB
                Yes it's a 17 year old Panasonic plasma!
                I was watching TV when there was a huge lighting strike nearby my house that shook the house. When that happened, the picture on the TV froze and the TV wouldn't turn off except by pulling the power cable. Now if you plug in the TV, it seems to turn on (it makes the turn on "clikcs" it always does, the red power light comes on but there is no picture, although I can see the back light around the edges. And the TV doesn't respond to the power button on the remote to turn off, and doesn't respond to the manual power button on the front...
                06-04-2025, 07:02 PM
              • pajdek
                Lenovo Y700-17ISK turn on and off
                by pajdek
                Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
                09-20-2023, 02:49 AM
              • reessi
                Acer Alienware Nitro 5 (GH51G LA-L181P Rev: 1C) & Dell Alienware M15 (GDP50 LA-k452P Rev:1) - Both Shorted PCH (SRKMA)!
                by reessi
                Hello:
                I have both these laptops that appeared to have the same fault so I thought I would have a go at replacing the PCH as something to learn, they both are using the same PCH.
                I started on the ACER:
                Up on connecting power no signs of life but current is consumed from the bench power supply and the PCH is hot.
                All the caps on the top of the PCH are showing 0 ohms and the 3.3v rail is shorted.
                I followed the videos from Sorin, Electronics Repair School on Youtube heating from the bottom to install. I practised on around 10 scrap...
                10-29-2024, 11:31 AM
