Panasonic TX-P42GT20B - Stuck Stby
  • benjamin.d.bird
    • Jun 2016
    • 45
    • United Kingdom
    Hi and to start with please forgive my ignorance.
    TV is giving a 10 flash fault code.
    Any help would be greatly appreciated.
    Thanks for your time.
  • tw2005
    • Oct 2011
    • 6458
    Re: Panasonic TX-P42GT20B - Stuck Stby
    possibly shorted SC board, check across SC2 for short or check if Q661 is shorted, it's on a heatsink of 2 transistors,
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Tnpa5105
      • tw2005
        • Oct 2011
        • 6458
        Originally posted by reeceyburger123
        tnpa5105
        tnpa5081
        • benjamin.d.bird
          • Jun 2016
          • 45
          • United Kingdom
          Originally posted by tw2005
          tnpa5081
          Am i missing something?
          also att is service manual
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            tnpa5081
            Similar design similar meltdown
            • dick_barton
              • Aug 2015
              • 6642
              • Wales
              Do a Forum search on those numbers given for more information.
              • benjamin.d.bird
                • Jun 2016
                • 45
                • United Kingdom
                thanks for the reply.
                can i just ask where i check them and what i am looking for?
                i have a DMM and a disassembled tv ready & eager to learn!
                Hungry for knowledge
                • tw2005
                  • Oct 2011
                  • 6458
                  you have the manuals but SC2 is the 2 pin power connector Vsus enters from the P board. Q661 is the location number of a RJP63F3A or could be F4A in the manual it will be Q16661.
                  In majority of cases it will be shorted if the board has failed, test it and see.
                  • ReeceyBurger123
                    Never Give Up !
                    • May 2014
                    • 7325
                    • Britain
                    Do some research then you will find out.
                    • benjamin.d.bird
                      • Jun 2016
                      • 45
                      • United Kingdom
                      funny you should mention that, not intending to overwhelm your cranium my friend but that is exactly what i am doing!
                      @tw2005
                      During initial start up before the led starts the 10 count, i temporary get led on SS board, none on SC board.
                      should i SC remove board before i check for shorts?
                      • martino
                        Not so "senior"
                        • Aug 2013
                        • 997
                        • canada
                        TV unplugged from the wall,take your DMM and put on low ohm scale (where it beeps when you touch leads). Just measure between the 3 legs of Q661,it's located left lower quarter on a heatsink. If it measures shorted between the legs then remove the board.
                        Then make sure you sit down,have enough coffee and/or guinness/smokes with you,phone your family/friends that you will be AFK for awhile and to not worry. THEN read this:
                        https://www.badcaps.net/forum/showth...light=tnpa5081
                        Proud owner of dozens of broken TV's and many,many,many boards.
                        Our website and passion:http://hollenhundshepherds.com/
                        • tw2005
                          • Oct 2011
                          • 6458
                          @tw2005
                          yeah or do it insitu. If the onboard LED does not momentarily illuminate at all sounding shorted, somewhat logical I'd think.
                          Unplug SC2 and check resistance or for short and q661 willbe lower left heatsink with the TV viewed from the back right way up.
                          My Avatar would be indicative of this board , LOL.
                          or remove the board. If you turned it on with the sc removed and it changed from 10 blink, that also may indicate SC. Search TNPA5081 , should be a fair bit of historic info around. Two most common codes for bad SC for this model would be 4 & 10 blink.
                          • ReeceyBurger123
                            Never Give Up !
                            • May 2014
                            • 7325
                            • Britain
                            Don't call me friend. Follow TW2005's advise hes the pro on these Im out.
                            • benjamin.d.bird
                              • Jun 2016
                              • 45
                              • United Kingdom
                              ok on SC2 no movement on 200 ohm,
                              on Q661 get 0.14 on one leg and 15.6 on other
                              not that i have any idea what this means lol
                              • tw2005
                                • Oct 2011
                                • 6458
                                neither do I. Sounds like a cheap meter not digital auto ranging.
                                What meter is it? Does it have a diode check or continuity check beeper or buzzer? Just probe two legs on that Q661 see if it beeps constantly. 0.14 ohms is a short But since you don't understand the meter fully makes it hard for me to say with confidence.
                                • benjamin.d.bird
                                  • Jun 2016
                                  • 45
                                  • United Kingdom
                                  You are absolutely right it is a cheap meter,
                                  • benjamin.d.bird
                                    • Jun 2016
                                    • 45
                                    • United Kingdom
                                    It doesn't have a buzzer but it does check for continuity, the display changes across all 3 legs. Which it does if I touch the 2 probes together so I assume means that there is continuity same applies to SC2
                                    • tw2005
                                      • Oct 2011
                                      • 6458
                                      Sorry mate but yuck. Good for maybe a little tinkering on a car.
                                      stick it on diode mode , touch the probes together and note the reading then probe the legs on that Q661, have someone take photos of the reading but I'm not going to waste too much time figuring that meter out . I find they are good at confusing everyone.
                                      • benjamin.d.bird
                                        • Jun 2016
                                        • 45
                                        • United Kingdom
                                        Touching the probes together reads 001
                                        Probes on middle and lower leg reads 014
                                        Probes on middle and upper leg reads 001
                                        Probes on upper and lower legs reads 014
                                        • Andre Gilbert
                                          by Andre Gilbert
                                          Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
                                          Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
                                          11-20-2024, 08:52 PM
                                        • Ancient1
                                          I'm stuck . Panasonic TH-L32U20M panel's boards issue
                                          by Ancient1
                                          Hi
                                          The TV seem to start ( blinking green) but goes into blinking red. No display and or backlight. Full view photo.
                                          Actions :
                                          1. Disconnected Panel's Right, 2nd, board : TV comes ON (steady green , no blinking red )
                                          1a. You can see in two photos the B/W screen , fading blue "HDMI12" , and the wierd sides of the image, like an old CRT.
                                          Obviously the fault is from or on the Right, secondary board
                                          2. I taped the Flex tracks, ~2 tracks at a time- see Photo. The issue seems to be on the V lines (Assuming Data...
                                          09-03-2023, 03:51 AM
                                        • stormanimal83
                                          Gigabyte B450 Aorus Pro stuck at VGA LED, burning hot LED Controller MCU 1 under PCI slot...
                                          by stormanimal83
                                          Hey....
                                          Board as written in description was stuck at VGA LED. common Problem wit these type of bords.... tried all the "standard stuff" like resettin... reseatin.... found out the LED Controller MCU1 = IT8295FN-56A geting burning hot under the last PCI Slot.. now i desoldered it cause there were only 18 ohms at the caps arround.... another aorus x470 in working condition with similar part and nearly same layout had arround 280 ohms...
                                          my question is: why doesnt the board start know without this chip.... worked myself through the boardview but i can´t understand...
                                          01-18-2024, 02:15 PM
                                        • gigigi
                                          Panasonic tx-55cx802b stuck on panel test mode
                                          by gigigi
                                          Panasonic tx-55cx802b stuck on panel test mode.
                                          It was working normally but few days ago some of the LED reflectors fall off.
                                          I've opened it up carefully, re-glued, while it was open switched it on to test LEDs.
                                          Then carefully assembled back.
                                          After plugging in to power remote does not work.
                                          Using power button on the TV it turns on but gets itself into a panel testing mode: white, gradient, red, gradient, blue, gradient, green and so on switching between colours.
                                          Anyone knows how to get out of this panel testing mode?
                                          I've tried so...
                                          06-20-2021, 07:06 AM
                                        • WhiteWolfHellas
                                          Toshiba 32AV933G stuck on stby
                                          by WhiteWolfHellas
                                          Hello, I have this TOSHIBA 32AV933G and it is stuck on standby LED (red). It doesn't turn on and the 12V is missing. Anyone has any experience with these PSUs and what to check? (DPS-140SP A)
                                          01-17-2022, 01:10 PM
