VIVO PTV43HD no PS-ON signal
  • dkneyle
    • Dec 2013
    • 441
    These were a badge engineered TV sold by Dick Smith Electronics in Australia. Inside all Samsung parts. Maybe somebody can recognise the actual model?
    There is no PS-ON signal being generated by the mainboard. When the PS-ON signal is jumpered to earth the power supply fires up and all voltages are spot on (Vs, Va, Vsc etc).
    The mainboard had some sort of brown goo on it (as shown in images). Has the consistency of contact adhesive. No signs of any spill on the external back cover. I couldn't shift it with methylated spirits; I had to resort to carefully removing with a very small blade screwdriver. Anyway, that didn't change the situation.
    So any hints to progress from here. Do people agree it appears to be a failed mainboard? I can get a secondhand mainboard for about A$100.
    The TV appears to be 2012 model, and it's in very good external condition. I'm reluctant to canabalise a good looking set, but then again it needs to be economical to repair.
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: VIVO PTV43HD no PS-ON signal
    The board number T.MSD306.9A 10331 appears when googled to be a generic number used in Bush & Technika.
    • dkneyle
      • Dec 2013
      • 441
      Thanks Dick. Yes, I too Googled the board number and saw the overseas models it is used in. Main boards tend to be country specific even when they have the same model number. In Australia we don't use the scart connector and instead they bring out rca sockets. The firmware seems customised for our channel allocations etc. I can only see one main board for sale here in Australia, from a seller I've dealt with before. I might have to see if I can negotiate the price down to make it economical.
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        Yes I saw one on sale Australia which was very, very expensive.
        • dskall
          • Oct 2016
          • 2905
          • usa
          I have a PN43D450A2D looks a lot alike. Different mainboard.
          • dkneyle
            • Dec 2013
            • 441
            Yes, I agree. It certainly looks like the PN43D450A2D in sheep's clothing. The mainboard in my Vivo appears to be configurable for a range of TVs, including LCD models.
            • dskall
              • Oct 2016
              • 2905
              • usa
              Have you checked to make sure the mainboard is receiving input from remote/buttons?
              • dkneyle
                • Dec 2013
                • 441
                Mmm..now that's a good question. Any quick thoughts about how to test that? I worked on that small board yesterday because it was very mobile and I found many plastic tabs were broken. I've glued it into the plastic frame it is meant to be supported by and I'm happy that the buttons are clicking OK. I note it has only three wires going to it so there must be some sort of multiplexing going on? It did cross my mind as to whether the turn on signal was coming from the front panel switches. I've been slack and haven't tried the remote control. I think I have it with the rescued TV (it came from the local landfill site and people often bring in the remote with the TV).
                • dskall
                  • Oct 2016
                  • 2905
                  • usa
                  Should get voltage changes on one or two wires when you push buttons
                  • dkneyle
                    • Dec 2013
                    • 441
                    Thanks to TW2005 I've been able to confirm via the test pattern test that the panel is operational along with all associated boards. So it does appear to be mainboard, and I'm very suspicious of that brown goo I first saw on the board.
                    Does anyone know if Samsung maainboards have a history of failing and whether there is a repair pathway? By the way, I'm still to check the on-switch for voltages back to the mainboard. Will report any findings of interest.
                    • tw2005
                      • Oct 2011
                      • 6458
                      I think it's worthwhile cleaning all thatbrown muck away. Looks like glue that has gone off, may have turned conductive. I just finished getting a Projecta IC5000 battery charger going again, the glue in that was yellow like contact glue which had turned black and corrosive.
                      Etched the board away and ate the legs off an optocoupler and corroded a Viper22 plus diode.
                      May need acetone or carefully chip away at it, looks a bit nasty
                      • dick_barton
                        • Aug 2015
                        • 6643
                        • Wales
                        It's good to see the manufacturers are still ensuring failure by the addition of these glues which are now known to become conductive over time.
                        This has been discussed many times on the forum so surely if we know, then they know.
                        • tw2005
                          • Oct 2011
                          • 6458
                          That was a $750 AUD, 50 Amp charger in 2014/15. In-laws are pretty lucky I have half an idea.
                          • dkneyle
                            • Dec 2013
                            • 441
                            I scrapped most of it away but couldn't find a solvent to shift it. I have acetone, guess there's nothing to be lost? I'd considered using acetone but was concerned about potential damage. Those very small SMT components near the red socket are covered in the stuff and it's difficult to see if they are damaged. Anyway, I think from what Dick says, especially about it being a point of often discussion, then I have my smoking gun. Mxmee (seller of reclaimed boards here in Oz) is offering to lower the price of a mainboard to A$80 plus postage. I need to find a buyer before I can justify the repair, unless I can get the mainboard going again.
                            • dick_barton
                              • Aug 2015
                              • 6643
                              • Wales
                              From what I've seen Shopjimmy uses acetone for clearing the flux away after soldering so I cannot see that it would be a problem using it on your board. Try it on a small area and see if it can remove the glue.
                              • vinceroger69
                                • Mar 2012
                                • 6714
                                I have not really worked on many plasmas so may be a stupid question but do these mainboards have eeprom on like lcd mainboards do as when they get corrupted etc it can stop the ps on signal etc.
                                • dick_barton
                                  • Aug 2015
                                  • 6643
                                  • Wales
                                  The mainboard model appears to be near identical for both the lcd and plasma sets so I would suspect that they also have their EEPROM problems.
                                  https://spares2repair.co.uk/bush-bpd...sd306.9a-10331
                                  • vinceroger69
                                    • Mar 2012
                                    • 6714
                                    maybe worth freezing it then with proper freeze spray if set starts up ok maybe remove ic and freeze again and to read ic data and reprograme one.
                                    • maxvalutech
                                      • 804
                                      • australia
                                      Doesn't seem any doubt on mainboard at fault but that is a strange number. The Vivos I had 2 plasma all had Samsung board numbers LJ....... or whatever. My view is a going set not worth more than $99 and what warranty can one offer!
                                      • dkneyle
                                        • Dec 2013
                                        • 441
                                        Thanks maxvaluetech and others for your input. Will have a go tonight at trying to remove any remaining glue contamination and see if I can detect any residual damage when looking closely through a mag glass. I agree that it can't be worth more than $90 in going condition.
                                        • AstutePauciloquent
                                          Requesting Help For GA-970A-DS3 rev. 1.0, No Post code, no RSMRST# signal
                                          by AstutePauciloquent
                                          Hi everyone, over the past few months i have taken a deep dive into motherboard diagnostics and I love the challenge. Currently im trying to learn all about the signals that travel around the motherboard, such as frequencies, enable signals High and Low logic states etc. And i have been learning to read and using the Schematics for this board that i requested here on Badcaps forum, from a few months ago, this is such a great place for these.
                                          I’ve been working on a GA-970A-DS3 (rev. 1.0) that does not post. This motherboard has been my main learning board. I would like share...
                                          11-23-2023, 11:02 PM
                                        • howardc64
                                          Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
                                          by howardc64
                                          Failure Symptom
                                          No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
                                          Where is the short?
                                          Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
                                          Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
                                          05-27-2025, 02:56 PM
                                        • JayPoorJay
                                          Converting +/- 5v to a Usable Hz Signal
                                          by JayPoorJay
                                          Good morning.
                                          I have posted here before and have gotten AMAZING advise (thank you!). I'm back for more. This BCaps Sub Forum is so well attended I thought I would post here.
                                          This question is for an automotive application but has to do with what are essentially electrical questions and problem solving... If this is inappropriate I get it. Feel free to delete it or move the question.
                                          The V 12 Jaguar XJS is notorious for overheating in stop and go traffic in hot weather... Y'all will be potentially helpinh a LOT of people. The solutions and directions...
                                          08-07-2022, 08:35 AM
                                        • Mirenia
                                          Dell Latitude 7420 - Touchscreen not working since Mainboard replacement
                                          by Mirenia
                                          I've got a little "problem child": my Dell Latitude 7420 2-in-1, which had a faulty mainboard.
                                          I replaced it, but ever since, the touchscreen no longer works — and honestly, I’m running out of ideas…
                                          In Windows Device Manager, I just see an I2C HID Device with error code 10. Sporadically, the touchscreen is recognized correctly for just a few seconds, but I haven’t been able to determine under which circumstances this happens.
                                          The touchscreen also doesn’t work in UEFI/BIOS, although it’s enabled...
                                          03-30-2025, 06:47 AM
                                        • orcic
                                          MASTER TL240 and new mainboard LW36BKC01
                                          by orcic
                                          I have an old MASTER TL-240 LED TV. Since it stopped working and it had a DVB-T receiver that is being dismissed in Italy, I've decided to replace the mainboard with a DVB-T2 one.
                                          The original problem was that when switching on the TV, the power LED was transitioning from red to steady blue, without showing video or audio.
                                          After checking some voltages on the power supply board (HKL-240101-B Rev. 1.4, HKL from now on) someone suggested me to replace the mainboard.
                                          Now I have some doubts about how to connect the new mainboard to the old power supply.
                                          First of...
                                          05-12-2023, 08:10 AM
