LG 32LN 540B TV Sound but no video
  • CostasCostas
    • Feb 2017
    • 20
    • Cyprus
    Re: LG 32LN 540B TV Sound but no video
    Should have gone to Specsavers. I'll post the readings from these test points shortly.
    • CostasCostas
      • Feb 2017
      • 20
      • Cyprus
      VGH_R, VGH_F, ODD and EVEN all read MINUS 4.99V
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        Here's a guide that was put on the forum a few days ago worth looking at.
        It does look as though you probably have a faulty Tcon.
        • vinceroger69
          • Mar 2012
          • 6714
          your link is not working?
          my link looks like yours but works fine on my pc odd when i click your link page not found
          edit this may work
          https://cdn.badcaps-static.com/pdfs/...d6ef3fc97d.pdf
          • CostasCostas
            • Feb 2017
            • 20
            • Cyprus
            @dick_barton if you had seen the photo of the LCD panel board you probably wouldn't suspect the t-con. The left side of the board (from the front of the TV) looks in a right state.
            Picture now added.
            Over the last week or so I had priced up new t-con boards and found them very reasonable at $20 including delivery.
            Not checked the lcd panel boards yet but is it possible for a beginner to actually swap out these boards, even if they don't cost an arm and a leg?
            • dick_barton
              • Aug 2015
              • 6643
              • Wales
              #26
              It's hard to see just how damaged the circuit board is because of the flashlight. However you can try with cotton buds and alcohol to clean it up as much as possible but very, very carefully so that you do not damage any ribbon connections.
              These circuit boards are attached to the lcd panel and unfortunately if they are damaged then the panel is useless. You cannot change the circuit board.
              • CostasCostas
                • Feb 2017
                • 20
                • Cyprus
                #27
                A couple of shots before and after the clean up.
                Well and truly dead. Seems a shame that such an integral board that only costs a few dollars to produce can't be replaced.
                • dick_barton
                  • Aug 2015
                  • 6643
                  • Wales
                  #28
                  It is really annoying that they put the Tcon and panel tabs at the bottom of sets knowing full well that they are easily damaged.
                  Sell your power supply, mainboard and leds to get some money back towards a replacement set. When you advertise the mainboard also give the panel details it was connected to.
                  • CostasCostas
                    • Feb 2017
                    • 20
                    • Cyprus
                    #29
                    I was planning to use the power supply to power up a couple of Omega2+'s that are very fussy about the precise voltage they require. Must be spot on 3.3V or they'll not bootup.
                    • Exim
                      ASRock N100M, no picture no boot, but semi-alive
                      by Exim
                      Hi guys,
                      I managed to semi-kill an ASRock N100M board after updating Bios from 1.10 to 2.01. It's a zombie now, dead, but not dead.
                      ASRock N100M special features:
                      - CPU soldered to board, small Intel 12th gen
                      - iGPU
                      - four POST LEDs
                      Problem after updating Bios to 2.01 using the in-Bios update tool: no picture, no boot.
                      I am not sure anymore if it booted at least once successfully after updating the bios to 2.01, maybe not, I can't remember. I think it did not.
                      Symptoms:
                      - no picture/signal on any of the display connectors,...
                      04-01-2025, 02:36 PM
                    • Aimbit
                      JBL Flip Essentials - Bluetooth not connecting after a fall - video of board
                      by Aimbit
                      video: https://www.youtube.com/watch?v=S-xBu7m6SwE
                      Hi all. I was given this JBL Flip Essential speaker that 'fell from about 8 feet' and then the bluetooth would no longer function. It seems to power on normally and responds to button presses, but it will not showup on bluetooth for any device I try to connect to it.
                      The bluetooth daughter board has a 26mhz oscillator that I could not get to read the proper frequency so I tried replacing that to no avail. Thought maybe something was wrong with the bluetooth IC it's connected to, so I tried replacing that as well. None...
                      10-28-2024, 09:29 PM
                    • JRade
                      Audio video receiver KENWood KR-V990D,no sound
                      by JRade
                      When I select the FM receiver, I find a radio station, the sound is heard on REC OUT(L,R), REC TAPE1(L,R),REC TAPE2(L,R) on high-ohm headphones, the sound regulation does not work.
                      The output reacts when I connect the record player to PRE OUT FRONT L, the sound is heard in the speaker but the sound regulation does not work. Then it does not matter what I chose on the front selector.
                      I replaced the capacitor C303/0.047F, nothing changes.
                      I'm asking for help, what should I do next?
                      Thanks in advance!...
                      08-05-2025, 10:23 PM
                    • Hakuu
                      by Hakuu
                      Hi There,
                      More Details
                      TV Model - LG OLED77G1PUA
                      07-12-2023, 02:37 PM
