Vizio e550i-b2 distorted picture
  • johns1mj
    • May 2015
    • 242
    I have a vizio e550i-b2 that randomly distorts the picture. It had the classic broke solder joints that have been repaired. This did not change the distortion. The Vizio logo always comes on fine. Then it changes to lines across the screen. I have tried 2 power supplies, 2 inverter boards, 3 inputs and two t-cons. The only thing left is the screen. I have tried to move every cable but nothing consistently changes the screen. if i have a bad screen why does the logo work every time? I have not read about bad screens on this model and was wondering if someone else could confirm.
  • R_J
    • 9588
    Re: Vizio e550i-b2 distorted picture
    With the T-con being at the bottom of the screen its usually water/cleaning fluid damage to the board that is attached to the lcd panel, give it look
    • johns1mj
      • May 2015
      • 242
      Make sure I understand. The boards along the bottom of the screen? t-con is behind the steel panel by the stand.
      • budwich
        • Jul 2015
        • 3097
        its was a bit of a "mis-spoke"... but related... as some people think that spraying a little water / cleaner on the screen will do no harm. It doesn't hurt the screen but any moisture finding its way down the screen into the edge boards at the bottom (not tcon) may have a very bad outcome. What is the history of the tv / failure?
        • johns1mj
          • May 2015
          • 242
          I got it this way.
          I don't understand why the Logo would be perfect every time. It goes stupid after the logo. I thought corrupted main board but 3 corrupted mains?
          • budwich
            • Jul 2015
            • 3097
            the logo doesn't cover all fault conditions. Anyways, your picture appears to show issues with signals entering the bottom of the panel (ie. vertical issues) that usually point to potentially problems with cabling / drivers down there... especially since you have tried other components already.
            • maricm
              Vizio m65-c1 picture flashing on and off on the screen
              by maricm
              HI all,
              hope someone point to the possible issue before I start buying replacement parts.
              Tv starts normal and responds to remote fine, PSU voltages mesured fine 19v was 18.9V under load and 19V with main board disconnected.
              Backlight stays on all the time,
              Sound works fine.
              screen keeps changing form black to full picture in about 1sec intervals.
              Picture looks fine with no visible artifacts.
              I have disconnected backlights and flashlight test confirmed that picture is still doing the same.
              Disconnecting left and right ribbons on...
              11-25-2023, 06:32 PM
            • Mgiffune
              by Mgiffune
              06-09-2024, 10:28 AM
            • Ryan.man
              by Ryan.man
              02-04-2025, 12:23 PM
            • arbitarytwist
              Samsung UN50NU7400 - No Picture (but boot screen and screensaver)
              by arbitarytwist
              Have a Samsung UN50NU7400 which shows a boot screen and a screen saver if left on long enough but no picture ?
              Would a moving screen saver confirm that the panel is ok or it could still be a panel issue ?
              03-01-2025, 01:16 PM
            • reformatt
              by reformatt
              07-31-2025, 08:37 PM
