LE40r87bd - Works after 10+mins
  • speedypro
    • Feb 2013
    • 561
    • United Kingdom
    I have this tv in for repair. The tv works perfectly after an initial 10min. During that 1o mins, it's hell; tv restarts, clicks, screen gets fuzzy etc. I dont know where to start. Caps look of etc.
    I've added two pictures.
    Full-time computer repair tech (10am - 6pm) and full-time, (8am - 11pm), Ruby on Rails Developer
  • vinceroger69
    • Mar 2012
    • 6714
    Re: LE40r87bd - Works after 10+mins
    Edited post as linked the wrong mainboard, but that board does looks like it may of been reflowed? as looks like a lot of flux on the board
    • CapLeaker
      Leaking Member
      • 8204
      What is all that goo over the bottom part of that main board? Everything seems to be covert in something. Yuck. That should be cleaned up. Can we see the backside of the main board too?
      On the PSU in the middle on the right side there is a pin out chart. Hook everything up and post the DC voltages measured on that connector. You can try heating one board with a hair dryer for 2-3 mins and see if the problem goes away.
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        For a start your mainboard has no bloody heatsink ! Also Vince its not flux its silicon for the thermal pads that are supposed to be on the cpu.
        • sordids999
          • May 2013
          • 2155
          lol thats why i had to look twice myself
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            Lol Cpu prolly over heating they run bloody hot on these boards, I have the LE37R88BD downstairs same board and put a huge heatsink on the cpu
            • vinceroger69
              • Mar 2012
              • 6714
              Thanks reece some more good information too know/note down.
              • srhofmann
                • Aug 2016
                • 135
                • usa
                What's with the peeling sticker that says "bordeaux plus 40"
                • speedypro
                  • Feb 2013
                  • 561
                  • United Kingdom
                  yea I tried to reflow but same.
                  But it's the same after a reflow. Could it be the cpu?
                  • finntricky
                    • Jan 2014
                    • 449
                    change the 2 silver SM caps 1000 - 10 in the white box area, they are a common fault with these boards,
                    also make sure you put the silicon pads and sheild back on,
                    • petehall347
                      • Jan 2015
                      • 4427
                      • United Kingdom
                      why is that resistor being like it is ?
                      • ReeceyBurger123
                        Never Give Up !
                        • May 2014
                        • 7325
                        • Britain
                        Originally posted by finntricky
                        change the 2 silver sm caps 1000 - 10 in the white box area, they are a common fault with these boards,
                        +1 and OP you better let us know if you fix this or not.
                        • speedypro
                          • Feb 2013
                          • 561
                          • United Kingdom
                          Will do. I'll hit up ebay then confirm. Thanks!
                          • speedypro
                            • Feb 2013
                            • 561
                            • United Kingdom
                            GUYS!!!! IT WORKED!!!! THANK YOU finntricky!
                            • finntricky
                              • Jan 2014
                              • 449
                              No probs, glad i could help
                              • ktmmotocross
                                RTX 3070Ti works normal, but when let 10min to work on full it crash
                                by ktmmotocross
                                Hello.
                                I have few RTX 3070Ti that works for hours on 90% of TDP, but when pushed to 100% tdp it crash in 10-15minutes. Cards was repasted and repaded, but still the same. Do u think that reball wil help?
                                05-07-2023, 12:24 AM
                              • CapLeaker
                                Dell ATX PSU won’t start, but forcing it works fine?
                                by CapLeaker
                                Got a case of something new weird at work. There is an old 2nd gen Intel i3 in an old “Pizza box” shell that has a small form factor power supply. Unfortunately I forgot to take pictures and model number off it.
                                Anyway, I get to work and get to look at this computer. Standby LED on the PSU is on, but the computer won't start. Hmm o.k. take the battery out of the main board try again, nothing. O.k. then… unplug the power supply from the main board and put in a full size ATX PSU (yeeeesss! Exact that blown Powerman IP that I fixed a while back), plug it in and the old...
                                10-28-2024, 06:59 PM
                              • rounin
                                MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                                by rounin
                                🛠 Original Issue
                                ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                                04-19-2025, 01:18 AM
                              • ex250
                                Kenwood SW-505D no sound issue and pops from time to time when it works
                                by ex250
                                Hello mates,
                                I bought this subwoofer a few days ago used and blind and it works erratically, as far as I could see, it has been tampered with, the speaker is not the original one and of 8 Ohm when it should be of 4, and there are some welds like reworked by the boards.
                                It doesn't have much power (expected more from it) and it distorts if you increase the volume over the middle, maybe it's because of the high impedance of the speaker. The problem is that it has sound when it wants, the led panels all work correctly, you can hear the power relay on power on, but right now...
                                12-29-2024, 03:27 PM
                              • eurowill
                                a2141 820-01700 internal display not working / external works
                                by eurowill
                                Hey ya'll this is my first post on here. I recently aquired a used/broken 2019 mbp 16 a2141 with the 820-01700 board. Seller told me that the laptop needed a new lcd. However upon doing some troubleshooting i found out the lcd is fine.
                                Laptop boots like a normal, plays chime, touchbar lights up however there is no image on the internal lcd. If i connect and external monitor while its already on, nothing happens and no image is displayed on external. However if i restart or boot the machine while its plugged in, the external then works and a backlight is now visible on the laptop....
                                07-23-2024, 10:06 AM
