Sony KDL-55NX723 suddenly 4 blinks
  • PowerAmpFreak
    • 982
    • Sweden
    This Sony KDL-55NX723 can work for minutes to days and suddenly give 4 blink code.
    What can be wrong ?
  • zomi
    • Nov 2011
    • 513
    Re: Sony KDL-55NX723 suddenly 4 blinks
    Dry joint maybe
    go over all joints on power boards
    and on the led driver board where power is supplied from the psu boards.
    Had a simialr issue on a 55ex720
    did the above and has been good for last couple of months.
    before was shuuting down daily flashing.
    Its happens on some of there maybe you have issue.
    • PowerAmpFreak
      • 982
      • Sweden
      Could not find any dry joints. Solderwork seems good.
      • dskall
        • Oct 2016
        • 2905
        • usa
        Try heat/cool boards. See if you can replicate the problem.
        • keeney123
          Lauren
          • Sep 2014
          • 2536
          What can be wrong ?
          Reset to factory default. Measure power board voltage.
          • freakaftr8
            • Oct 2012
            • 3743
            Probably defective led driver board. Any dark spots in the picture before it turns off with the Four blinks? I had a 55hx729 do the same thing to me and I replace the LED driver board in a problem was solved. BAd ic driver on that board it was cheaper for me to replace and repair
            • PowerAmpFreak
              • 982
              • Sweden
              No luck finding out the problem.
              I want to measure the 'ERROR' signal on the led driver board in order to verify this is the problem first of all.
              Anyone know where to monitor the error signal and what state it should have ?
              • jason123
                Sony XR-55A80J OLED TV 5 blinks - Troubleshooting steps
                by jason123
                Hi there,
                I see a couple of posts related to the troubleshooting of similar TV. The one I have is acting slightly differently and I'd love your help.
                So it has the 5 blinks. Previous owner got a TCON, no luck. Got a new Main board (though he didn't do the USB firmware update), again, no improvements.
                I see 2 posts that are relevant:
                https://www.badcaps.net/forum/troubl...j-oled-5-blink
                https://www.badcaps.net/forum/troubl...g-hardware-dev...
                10-29-2025, 02:01 PM
              • matwan
                Sony XR-55X90J 5 blinks
                by matwan
                I have problem with SONY 55X90J. After several check status is as below;
                1. Running power board as stand alone:
                TCON_12V =~ 12.6V
                EVDD V On Max 24V= 19V.
                2.
                Running power board with TCON as stand alone:
                Effect as below, attched.
                3. When bottom LVDS cable is disconnected no blinks, but of course no TCON 12V and EVDD.
                "I'm almost sure it's a defective panel, but maybe someone has encountered a similar issue on their screen.
                Best regards....
                09-28-2025, 04:26 AM
              • GoodCapDude
                Sony XBR-75X940E intermittent 6 blinks error code
                by GoodCapDude
                Hi everyone. First post on Badcaps!
                I am trying to fix a Sony 940E from 2017 that either starts normally (and works perfectly until turned off) or goes straight to the 6 blinks error code without showing anything on the screen. It is frustrating to know that it can still work perfectly but is barely usable because of the difficulty starting it up. I am willing to try to short the BL_ERR but I would like to avoid that if possible. Does anyone have a view on this? Thanks a lot....
                09-20-2025, 06:07 AM
              • AK_777
                Sony KD-65A1 Repair – 4 Red Blinks Error
                by AK_777
                Hi everyone!
                I have a Sony KD-65A1 TV with a fault – 4 red LED blinks. After disassembly and visual inspection, I found that the G76 power board and DKA board had been replaced. It is also possible that TCON was replaced, but I am not sure – there are a few marker marks that could be factory-made.
                Based on assumptions, the previous service attempted to solve the issue by replacing potentially faulty components. I decided to investigate further, found a service manual, and figured out a way to power up the power supply unit autonomously and put the OLED panel and...
                02-20-2025, 04:15 PM
              • jchon
                Sony A1e 5-blinks help
                by jchon
                Hi I'm new to trying to repair TVs, but I saw a broken OLED offered for a reasonable price and thought I'd try my hand at it.
                I found the service manual, which was critical to know where to probe.
                https://www.manualslib.com/manual/20...1e-Series.html
                With it I was able to determine that my DKA board was bad, when P_ON#1/2 gets enabled REG_12 on the DKA board collapses. I'm assuming one of the downstream regulators has a short, but I couldn't work out which rail/component and replaced the DKA board entirely.
                Unfortunately the 5-blinks...
                06-28-2023, 11:52 AM
