Help with LG 50PA4500
  • Studentske
    • Feb 2017
    I found a TV off the side of the road and brought it into my home to see if I could repair it. When I try to turn the TV (LG 50PA4500) on a red light flashes on the control board and a clicking noise can be heard simultaneously. In roughly 6 second intervals the flashing of the light and the clicking noise reoccur. I checked to see if any of the capacitors have domed and everything in the back looks fine. I would appreciate any help troubleshooting to find the issue.
  • martino
    Not so "senior"
    • Aug 2013
    • 997
    • canada
    Re: Help with LG 50PA4500
    https://www.badcaps.net/forum/search...archid=8219359
    Proud owner of dozens of broken TV's and many,many,many boards.
    Our website and passion:http://hollenhundshepherds.com/
    • dskall
      • Oct 2016
      • 2905
      • usa
      Try this one
      https://www.badcaps.net/forum/showth...ht=LG+50PA4500
      • NConstantinou
        HP Z840 workstation power supply clicking noise
        by NConstantinou
        No power
        i have the above ps which i change the TOP258eg ic.
        Now i have power but is clicking and voltages are flutuating. I change all capacitors, i test all mosfets and all are ok.
        i am wondering what is the value of R901! I am getting 0.5Ohms. Is that correct!
        the colours look like R,R,W or silver,G Bl.
        Thanks...
        12-25-2024, 02:24 AM
      • tony359
        by tony359
        11-28-2023, 05:18 AM
      • MegaZAC
        Onkyo TX-SR805 noise in one channel
        by MegaZAC
        Surprisingly enough, this receiver doesn't have the DSP chip issue. The HDMI board does not get hot, and sound over HDMI works fine.
        Regardless of the input, the right channel has noise that is clearly noticeable even on average volume level. The only cases when there's no noise is when VCR input is selected (some tracks on the board are damaged, maybe that's why), or if HDMI input is selected but nothing plugged into it. In all other cases, even when no input is connected I still have the noise.
        There's some logic behind it. As soon as I select an input I get only left...
        04-23-2025, 10:09 PM
      • courtcircuit
        Philips HTS8000 home cinema noise problem
        by courtcircuit
        Hello
        I have since a long time a Philips HTS8010S/01 which has been old but was doing the job.
        Since a few days, it starts by making a weird "static" nois when switches on for a few seconds to a minute and then works like a charm.
        Noise loudly outputs from the 3 channels, even if no signal is sent by the controler.DVD to the subwoofer/amp unit.
        I was thinking of a soldering that was starting to be damaged and that was only doing the job after a few seconds of heating, most probbaly on the power board
        Removed each of tyhe boards
        02-08-2025, 08:22 AM
      • imran333
        Sony kdl-46w905a won’t turn on and relay clicking noise
        by imran333
        Hi I got Sony kdl-46w905a and it won't turn on and no red blinking code and all I hear when I plug it in is a clicking noise and a pause for a second then another clicking noise as if the power supply has a relay and is relay is turning off the power supply bcuz of a problem, bcuz of this I have no way to check voltages anywhere as there's no standby light but I think I get a white light for a second then goes off, I've checked for bad capacitors or shorted mosfets but haven't found a problem, and I was thinking if there's a way To bypass the protection so it stays on so I can check voltages ?...
        10-20-2019, 10:18 AM
