Sanyo dp42848 - T-Con or LCD Panel Problem?
  • abbottdave
    • Apr 2016
    • 41
    I have a Sanyo DP42848 with a picture problem. With the original T-CON I get no image on the screen, and with a replacement, I get what you see in the attachments.
    I'm thinking T-CON because with the new board, I at least get something. I've checked all of the tab bonds, and nothing changes when I apply pressure.
    Is it the panel or the T-CON?
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Sanyo dp42848 - T-Con or LCD Panel Problem?
    Looks like panel/tabs to me it is common on this model.
    • CapLeaker
      Leaking Member
      • 8177
      There are 2 ribbons going from the T-con to the LCD. Disconnect one leave the other connected and retest. Then the same thing again with the other ribbon disconnected and the first one plugged in. See what happens to the screen.
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        You can download the manual from
        https://www.manualslib.com/download/...o-Dp42848.html
        • abbottdave
          • Apr 2016
          • 41
          Here's is what I have now. From the front of the TV, with the left side ZIF ribbon cable disconnected (affects right side of screen) Image4. With the right side disconnected, Image5. With both connected, Image7, but then, Image8. I've lost the image altogether.
          One thing I forgot to mention is when I had an image, the right side of the screen was really 'slow'. That is, the image would linger and fade slowly away. If you had it just showing 'no signal', the 'no signal' image would jump around the screen normally, but when it was on the right side of the screen, it would fade away really slowly. On the left side of the screen, it would blink out quickly. I know the TCON is responsible for 'timing'. Does that indicate a timing problem? Also, the main IC in the TCON is getting too hot to touch.
          • petehall347
            • Jan 2015
            • 4426
            • United Kingdom
            try freeze spray on t con chip
            • CapLeaker
              Leaking Member
              • 8177
              I am not convinced that this is a tcon problem yet. You may have a bad tab bond on the LCD itself. That also can explain the low refresh rate. Squeeze the frame firmly where the affected area is. You may have to take the TV apart and get at the individual tab bonds. Also youtube "tab bonds" etc.
              • vinceroger69
                • Mar 2012
                • 6714
                these two links may give you some idea what to check etc
                https://www.badcaps.net/forum/showthread.php?t=25371
                https://uselessforums.com/threads/ar...-issues.13670/
                • dskall
                  • Oct 2016
                  • 2905
                  • usa
                  Might try watching this. Will help to described what bad panel looks like
                  https://www.youtube.com/watch?v=IZQRVqtIfns
                  • x_orange90_x
                    TCL 50S535 bad tcon or panel issue?
                    by x_orange90_x
                    Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                    03-29-2025, 11:02 PM
                  • advant
                    by advant
                    02-03-2020, 12:25 AM
                  • perzyk23
                    Lenovo T580 - LCD Panel problem - error 0288
                    by perzyk23
                    Good morning,
                    I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise....
                    10-25-2024, 12:42 AM
                  • mmartell
                    General Questions on the Relationship Between Mainboard, TCON and Panel
                    by mmartell
                    My goal here is to be able to use boards on hand to swap into faulty sets when the faulty board is not obvious.
                    I will start by asking what is the format of the output from the mainboard and is it generic in any way or does it vary by manufacturer and/or model ?
                    And as far as I know a tcon and panel must be a matching pair because the timing of the signals and the voltages required to drive the panel are specific to the panel itself. (That may be a blanket statement that isn't true in some cases where the panel creates its own sub-voltages on its panel boards?)...
                    01-06-2024, 01:32 PM
                  • stylishconsultant
                    un60j620dafxza - Samsung No Display Problem
                    by stylishconsultant
                    Hi All,
                    Need help.
                    I have a samsung un60j620dafxza led tv. When I plug it in it has no display, no sounds, and no standby lights.
                    So I opened the tv and disconnected the power to the mainboard and the backlight powered up. This according to many people says that this is a mainboard
                    problem. I checked the voltage coming from the stb and I read 1.3 volts on pins 1,3,5 and 7 which are low volts instead of 13 volts which i think the lcd panel
                    might be drawing too much power from the power supply that it prevents the right voltage going to the mainboard....
                    09-04-2024, 03:26 AM
