baird 42 no picture
  • LEEDASH
    • Dec 2012
    • 481
    • Bedfordshire
    #41
    Re: baird 42 no picture
    lets go again
    +12v both 11.95v
    sgnd three of them one is readin 0.01
    5vsb 5.01v
    stb 2.01v
    +5v 5.00v
    +5v 5.00v
    +24v +24v both 23.6v
    sgnd 0.00 and the 3rd 0.01
    • LEEDASH
      • Dec 2012
      • 481
      • Bedfordshire
      #42
      I can hear any thing connected to the hdmi
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        #43
        Have you tried to input a signal through the Scart, AV or PC inputs in the event that it's an HDMI problem?
        • LEEDASH
          • Dec 2012
          • 481
          • Bedfordshire
          #44
          I knew the hdmi worked because i had a freeview box linked up,i cant select scart av etc has having no screen not even a blue screen
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            #45
            Originally posted by LEEDASH
            Sorry bud,Im a amateur,So these have to be tested again with unit on or standby
            Because you dont do any research.
            • LEEDASH
              • Dec 2012
              • 481
              • Bedfordshire
              #46
              Excuse me,
              • LEEDASH
                • Dec 2012
                • 481
                • Bedfordshire
                #47
                On that note I'm still looking for help,
                • dskall
                  • Oct 2016
                  • 2905
                  • usa
                  #48
                  Think I might try a T-con. Got voltages, backlights
                  • LEEDASH
                    • Dec 2012
                    • 481
                    • Bedfordshire
                    #49
                    T-con holding correct voltage yes backlights all around
                    • LEEDASH
                      • Dec 2012
                      • 481
                      • Bedfordshire
                      #50
                      [/ATTACH]
                      • LEEDASH
                        • Dec 2012
                        • 481
                        • Bedfordshire
                        #51
                        Just looked at the inverter board,tested a fuse similar like on the tcon,states near the fuse 15a/65v,I got a reading at 23.5v ? when the tv is switched on the tcon highlights a blue light,then goes off after one minute is this correct ?
                        • dick_barton
                          • Aug 2015
                          • 6643
                          • Wales
                          #52
                          Those are all pictures of the inverter which you have already said is working?
                          • LEEDASH
                            • Dec 2012
                            • 481
                            • Bedfordshire
                            #53
                            does it control the backlights ?
                            • dick_barton
                              • Aug 2015
                              • 6643
                              • Wales
                              #54
                              Yes, that is the circuitry that switches on the backlights
                              • LEEDASH
                                • Dec 2012
                                • 481
                                • Bedfordshire
                                #55
                                the two ribbons i tested are connected from the psu to the board which has hdmi scart etc,the other ribbon from psu to inverter has not been checked,i dont know what voltages they are along it,does not state on the board.
                                • LEEDASH
                                  • Dec 2012
                                  • 481
                                  • Bedfordshire
                                  #56
                                  Well they do work,i just check the fuse out of curiosity.
                                  • dick_barton
                                    • Aug 2015
                                    • 6643
                                    • Wales
                                    #57
                                    You show the backlight working in one of your earlier photo's so I cannot see why they would need testing?
                                    https://www.badcaps.net/forum/attach...4&d=1487270189
                                    • LEEDASH
                                      • Dec 2012
                                      • 481
                                      • Bedfordshire
                                      #58
                                      Im just trying to find out why it not working,
                                      • vinceroger69
                                        • Mar 2012
                                        • 6714
                                        #59
                                        Hard to say if this is a lcd panel issue or a bad mainboard or tcon as backlights seem too be working fine
                                        • LEEDASH
                                          • Dec 2012
                                          • 481
                                          • Bedfordshire
                                          #60
                                          more and more sound like a panel issue,
                                          • Tr0ll
                                            by Tr0ll
                                            Original T-con:
                                            First replacement T-con:
                                            10-07-2023, 07:48 PM
                                          • JJAAMM
                                            by JJAAMM
                                            Problem
                                            07-06-2023, 06:01 AM
                                          • TR103
                                            by TR103
                                            - it keeps rebooting
                                            01-22-2025, 04:12 PM
                                          • Mgiffune
                                            by Mgiffune
                                            06-09-2024, 10:28 AM
                                          • CyberPhoenix
                                            Issue with picture quality of Sony bravia TV
                                            by CyberPhoenix
                                            Hello, Last week I bought the 50" Sony X80j tv everything was working fine, untill I plugged the tv in a ups power supply 650va the tv remote control became unresponsive and the TV became laggy after a while the picture quality isn't the same as before the tv seems less brighter and the picture is somehow blurry, people's faces don't look as natural as before, there is a mini orange-pink tint to the edge of people's faces especially in NETFLIX Dolby Vision like in One Piece ep1 Alvida skin tone, my intention was to protect the tv but something went wrong I checked the ups with a multimeter,...
                                            01-22-2024, 02:08 AM
