Vizio E28H-C1
  • CapLeaker
    Leaking Member
    • 8214
    Re: Vizio E28H-C1
    now you have a main board problem. No PSon and BLon.
    • dick_barton
      • Aug 2015
      • 6643
      • Wales
      Re: Vizio E28H-C1
      Since you have changed the power supply, like CapLeaker I would be suspecting the main board since as he has stated you have no PS_ON or BL_ON
      • Fisher77
        • Feb 2016
        • 229
        Re: Vizio E28H-C1
        Originally posted by dskall
        Do you get anything on pson when you push power button? Backlights? Check around mainboard input connector for fuses, voltages at regulators. Brown wire fluctuates when you push power button?
        Voltage on the pson pin is .7V at all times, even when I push the button. Tried with the remote as well, no change.
        Checked fuses around the main board input, all checked good.
        Brown wire fluctuates with and without pushing the button.
        I will check the voltages at the regulators.
        • Fisher77
          • Feb 2016
          • 229
          Re: Vizio E28H-C1
          Ok I checked the voltage regulators.
          I think I may have found a problem with U703. It is a 903T63 low dropout regulator. Here is the datasheet for it:
          https://www.digchip.com/datasheets/p.../G903T63UF.php
          Ok the datasheet shows Pin1 as GND, Pin2 as Vout, and Pin3 as Vin.
          When I checked the voltage on this regulator I found the following:
          Of course 0V pin1.
          Pin3 had 5V input
          Pin 2 was fluctuating from .8V to 1.4V.
          According to the datasheet that regulator should have 3.3V typical output.
          Another thing I did was test the continuity. Of course pin 1 to ground buzzed, but pin2 to ground also buzzed. So then I checked continuity between pins 1, and 2 with a resulting buzz from the meter. Resistance between pins 1 and 2 was 1.6 ohms. From pin2 to ground was also 1.6 ohms.
          Now I assume that this would indicate that the regulator is bad. But I wanted to run it by you all first, and ask Do I need to remove it from the board confirm that it is bad? Or does this indicate that it is deffinitely shot?
          • dskall
            • Oct 2016
            • 2905
            • usa
            Re: Vizio E28H-C1
            I would remove regulator then check board for short between pin 1and 2
            • CapLeaker
              Leaking Member
              • 8214
              Re: Vizio E28H-C1
              x2
              • Fisher77
                • Feb 2016
                • 229
                Re: Vizio E28H-C1
                x2
                Yep, the board has a short between pin pads 1 and 2.
                • dskall
                  • Oct 2016
                  • 2905
                  • usa
                  #28
                  Re: Vizio E28H-C1
                  If you have external power supply you could put 3.3v with low current on pads 1 and 2. Freeze components around the regulator and see what thaws out first.
                  • Fisher77
                    • Feb 2016
                    • 229
                    Re: Vizio E28H-C1
                    Will do. Thanks
                    • CapLeaker
                      Leaking Member
                      • 8214
                      Re: Vizio E28H-C1
                      or use pure 99% alcohol.
                      • Fisher77
                        • Feb 2016
                        • 229
                        Re: Vizio E28H-C1
                        Well I used the rest of the freeze spray I had, and did not find anything. I switched to 91% IPA that I had on hand. Put drops on just about everything, and still found nothing. I then removed the cover and heatsink from the eeprom after I noticed the cover felt a little warm. I put a couple of drops of IPA on the eeprom, hooked up the 3.3 volts and it almost instantly started evaporating the IPA. I stuck the board in the freezer for a bit to get it nice and chilly, put the IPA on the eeprom again, hooked the 3.3V to it, and again it almost instantly started evaporated the IPA.
                        The eeprom is the only thing I am seeing on the board that is evaporating the IPA that fast.
                        • CapLeaker
                          Leaking Member
                          • 8214
                          Re: Vizio E28H-C1
                          Make a picture of the board first, then take that IC off and check if the short cleared. If it didn't, keep on going on anything that is on that voltage rail. It could also be a surface mount SMD cap shorted to GND.
                          • Fisher77
                            • Feb 2016
                            • 229
                            Re: Vizio E28H-C1
                            Ok I finally got back to this TV. I removed the eeprom chip as suggested by CapLeaker. The short was gone after that, so it looks like the eeprom was the cause of the short. Ordered a new board and the TV fired right up.
                            Thanks for all the help with this.
                            • x_orange90_x
                              Sony Bravia KD-50X690E blown resistor
                              by x_orange90_x
                              I just picked up this tv yesterday and the previous owner said while watching tv he heard a loud a pop and then the screen went dark. I removed the back cover and found the source rather quickly; resistor R8601. A chunk of the ceramic had blown off exposing the inner wire. Due to the damage I cannot make out the colors of a couple bands. I likewise cannot find a datasheet for the power supply. I tried pulling up pictures of the same board online but the resistors have different colored bands which I half expected as I've had this happen before.
                              The power supply is 715G8413-P01-001-0H2S...
                              07-16-2024, 06:53 AM
                            • redbaron1007
                              Arcade PSU blown resistor ID
                              by redbaron1007
                              I'm working on one of the PSU's in my backlog today that came out of an NBA Jam arcade machine a year or so ago. The PSU is a Pan Yes brand with a model number PY-TV-C. From what I remember the 12v rail wasn't outputting anything. I opened it up and was reminded that the resistor at R28 had blown it's shell off and I have no idea how to ID a replacement for it. (see pictures) The color bands that are still intact a little are brown, black, missing band/bands, and what I'm assuming is silver. When I check it with my DMM it's reading 100ohms exactly but I don't know if that's what it's supposed...
                              01-06-2023, 04:13 PM
                            • mikey5791
                              Need help to replace burned resistor in 350w atx psu
                              by mikey5791
                              Hi to all forum members,
                              Got this faulty 350 watt atx psu dirt cheap from a local online seller as i am keen to use it as a learning tool to repair faulty power supply.
                              The faulty part is quite obvious from the burn area near the 16pin KA7500 BD pwm. The fuse is still intact with good continuity.
                              Upon power on ac, there is 5vdc standby power on cathode of diode D14 and about 10vdc on cathode of diode D13.(This should be the aux power to generate the 12v and 5v rail.)
                              Initially i replace the two burned resistors near my marked red arrow to 200 ohm resistor...
                              12-26-2024, 04:55 AM
                            • labello
                              Honda XL 600 LM 1985-1989 PD04,Resistor blown up and losted
                              by labello
                              Hi guys a friend of mine give me this old counter it's for Honda XL 600 LM 1985-1989 PD04.
                              He opened it and found a resistor that was blown up. Then he lost it. I knowing it's not easy to fix it, but I just guess (maybe we can) thank you so much...
                              09-27-2023, 02:46 AM
