Samsung older LCD main board problem
  • kevinm34232
    • May 2012
    • 1884
    This is a BN94-02079G from a LN40A630M1FXZA. This board version is used in many different models in 2008 and 2009 including some plasmas, and there are like 200 different part #s for different TVs.
    It appears this board was connected to a different model but similar model for testing, and now the remote control IR and keyboard button functions of the original TV no longer work.
    I think plugging in the connector to a different IR board causes something to corrupt. Anyone have any input on this or a way to reset it without remote control function?
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: Samsung older LCD main board problem
    So what your saying is you replaced the mainboard and now remote and buttons don't work? Are your voltages changing when you press buttons?
    • kevinm34232
      • May 2012
      • 1884
      It seems to brick this function when a board is connected with a different wiring harness on the remote/IR/key button board connector .
      Not sure if I'm making it clear enough, am I?
      • kevinm34232
        • May 2012
        • 1884
        I am not connecting that connector for the buttons/IR on this test TV because of the problem it causes, it seems the wiring is different and causing the issue.
        Is this an eeprom issue?
        • CapLeaker
          Leaking Member
          • 8150
          how do you control the main board if you don't have any buttons and remote hooked up, in order to come to your conclusion?
          • dskall
            • Oct 2016
            • 2905
            • usa
            If wiring is different then I would say it's wiring issue not eeprom
            • kevinm34232
              • May 2012
              • 1884
              When connected to a different model it will work, but when it goes back into the old model it won't.
              • Andrew F. Ali
                • Jan 2014
                • 2450
                • Trinidad & Tobago
                Compare the 2 control/IR Bds and see what their differences are and then determine if re-wiring your board is an option.
                • nicholas1110
                  • Aug 2012
                  • 127
                  • usa
                  Some of the (a) series models use touch button and some use hard buttons. The layout of the main boards are different near the connector that goes to the ir board. Yes these (a) series boards all look close to the same but they are not all fully conpatiable due to the differences in inputs and trim versions. Hope this helps
                  • Andrew F. Ali
                    • Jan 2014
                    • 2450
                    • Trinidad & Tobago
                    Originally posted by nicholas1110
                    some of the (a) series models use touch button and some use hard buttons. The layout of the main boards are different near the connector that goes to the ir board. Yes these (a) series boards all look close to the same but they are not all fully conpatiable due to the differences in inputs and trim versions. Hope this helps
                    +1
                    • dskall
                      • Oct 2016
                      • 2905
                      • usa
                      If the wiring to both is the same would an eeprom reprogram work to change button styles?
                      • Andrew F. Ali
                        • Jan 2014
                        • 2450
                        • Trinidad & Tobago
                        I don't think so.
                        • kevinm34232
                          • May 2012
                          • 1884
                          The problem is after it has gone into a different TV, it does not work in the original TV anymore, it loses all button and remote control function. So no way to do a factory reset or anything that I can figure out the remote working. Is there a way to reset the eeprom manually somehow?
                          • Andrew F. Ali
                            • Jan 2014
                            • 2450
                            • Trinidad & Tobago
                            To reset the EEPROM manually here are the steps (Do this at your own risk). I have done this many times before and had success.
                            1. Identify the EEPROM IC (24CXX)
                            2. Identify the Flash memory IC (25LXX)
                            3. Identify on the EEPROM IC the SDA and VCC pins
                            4. Connect a jumper across the SDA and VCC pins
                            5. Power ON the TV and hold for 20-25 sec
                            6. Break the jumper
                            7. Power OFF the TV
                            Powering ON the TV again should show a reset EEPROM.
                            GOOD LUCK!!
                            • kevinm34232
                              • May 2012
                              • 1884
                              I've read this before somewhere for a different reason. What's the 24CXX and 25LXX, they don't seem to be on this board. (see photos)
                              • Andrew F. Ali
                                • Jan 2014
                                • 2450
                                • Trinidad & Tobago
                                24CXX is the eeprom IC number e.g. 24C64. Similarly with the 25LXX is the flash memory IC number e.g. 25L08
                                • kevinm34232
                                  • May 2012
                                  • 1884
                                  Can you ID those on this board?
                                  • Andrew F. Ali
                                    • Jan 2014
                                    • 2450
                                    • Trinidad & Tobago
                                    They would be any of those 8 pin SMD SOP 8type ICs....I can't make out the Nos. of the ICs.
                                    • vinceroger69
                                      • Mar 2012
                                      • 6714
                                      this video may help you locate the ic as your number is in the board listings
                                      https://www.youtube.com/watch?v=oC4f2Ik8rCI
                                      maybe check for shorts etc too on your ir board
                                      • CapLeaker
                                        Leaking Member
                                        • 8150
                                        nice find.
                                        • Asraf Atb
                                          by Asraf Atb
                                          01-27-2025, 05:02 PM
                                        • Dani_2024
                                          by Dani_2024
                                          10-28-2024, 05:06 PM
                                        • jb_Bak
                                          by jb_Bak
                                          CN6401
                                          Pin 01 NC
                                          Pin 02 NC
                                          Pin 03 "BL_ON": 0V
                                          Pin 04 "N/C"
                                          Pin 05 "STBY 3.3V": 3.5V
                                          Pin 06 "GND": N/C
                                          Pin 07 "AC_OFF"...
                                          09-27-2021, 04:52 PM
                                        • JDC
                                          (SOLVED) - ONN 100012588 No Power, Then Rebooting After Main Board Change
                                          by JDC
                                          ONN 100012588
                                          Issue: No Power, Then Rebooting After Main Board Change
                                          Short answer: replace main board and power board
                                          Technical answer: replace main board and Q306 & Q307 on power board.
                                          Long answer:
                                          TV wouldn't turn on. Power switch was fine which means the main board isn't processing the power on signal. Replaced main board. TV turns on now but randomly reboots. Bad main board? EEPROM? Tried to pull main board and got a shock touching the corner of the board. That's weird. C334 (450V 10uf) capacitor is still holding a high charge....
                                          07-15-2022, 07:39 AM
                                        • m1ch43lzm
                                          by m1ch43lzm
                                          05-12-2025, 08:37 PM
