Samsung PN50C450B1DXZA
  • ses4you
    • Jun 2006
    • 11
    I have a steady red light on the front of TV. Pressing the power key yields no response - no clicks from relay, no sounds of any kind. The following was measured on CN801 of the power supply.
    1. 3.34v (PS-ON)
    2. 5.16v (Styby)
    3. 0
    4. 15.27v
    5. GND
    6. GND
    7. .454V
    8. .454V
    9. GND
    10. 15.27V
    11. 15.27
    12. .454V
    I performed the Samsung's Fast Track Troubleshooting
    [SM].pdf&mfg=Samsung
    Power On Sequence
    STBY 5V (Pin 2 CN801) - Reads (5V)
    PS_ON (approx 3.3V - 0V) (Pin 1 CN80) - T reads (3.3V)
    VS_ ON (approx 0V – 3.3V) (Pin 6 CN80) reads (0v)
    VS - 213V
    VE - 76.3V (AJUSTED TO 86V)
    VS - 213V
    VSC – 187.7V
  • ses4you
    • Jun 2006
    • 11
    Re: Samsung PN50C450B1DXZA
    Is it my Logic Board or the Main Board that is cause the problem of not powering up.
    Thank you for the help
    • rccrasher65
      • Mar 2014
      • 619
      I have both of these boards for this tv set.
      • mmartell
        • Oct 2013
        • 3189
        Your results are confusing the way they're written. If you're saying PSON reads 3.3v before and after pressing the Power button then it's not changing state and your main board is at fault.
        If it's supposed to go low then you can remove pin one from the connector (main board side) and attach it to ground then plug the tv back in and see what happens.
        • ses4you
          • Jun 2006
          • 11
          Sorry about the confusion on the reading. When i plug the TV up to the power source and measure the voltage at the power supply board connector CN801, PSON reads 3.3v before and after pressing the Power button.
          Should the PSON after pressing the Power button read something less then 3.3v?
          • dick_barton
            • Aug 2015
            • 6642
            • Wales
            PS_ON normally changes state so that when, for example it may be 3V or more in standby when you press the remote to come out of standby it goes to 0V.
            On some sets this may be the other way around but it is a definite change.
            • ses4you
              • Jun 2006
              • 11
              understand, no change on the PS_ON. I ordered the main board, will let all know the out come. Thanks again
              • ses4you
                • Jun 2006
                • 11
                It's a No Go on the main board swap.
                I tried the logic board test. I disconnected the main board and jump pin 3 and 4 of that 4-pin square test connector. I then jump the PS-ON pin to ground. The TV came on with a white bright screen. So I am thinking the main board is good.
                • dskall
                  • Oct 2016
                  • 2905
                  • usa
                  Seems you have a power button problem. Does it work with remote?
                  • maxvalutech
                    • 804
                    • australia
                    Yes when you jumper ps-on to ground you are of course taking 3.3v down to 0. Trace and check all from power button to and including connector cable wires and connector soldering main board . Power board seems ok.
                    • ses4you
                      • Jun 2006
                      • 11
                      I trace and checked the wires from power button to the main board connector. I wiggled and push the wires into their connectors. The TV comes on now with the remote and TV' s power button.
                      Will look for bad soldering and let all know. Thanks
                        09-07-2024, 05:50 AM
                        09-06-2024, 11:40 PM
                        09-06-2024, 08:40 PM
                        Samsung Galaxy Book Ion NP930XCJ-K01DE Notebook Specification for Upgrade or Repair
                        This specification for the Samsung Galaxy Book Ion NP930XCJ-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP930XCJ-K01DE boardview and NP930XCJ-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                        09-06-2024, 06:20 PM
