Re: Panasonic 50" VT20 arcing at edge of panel to frame
I just lifted the front bezel away from this V20 for a look. There is nothing conductive under that. Just a plastic frame with an aluminium fascia. Under there is thin non conductive tape.
Along that edge where you see arcing is a metal strip, under the metal strip against the glass is EMI shield tape / foam. Yes it is conductive and meant to be.
Now I'm just wondering if it's static discharge and that tape has broken down because if the tape is conductive and it's stuck to the metal plate why would it jump and discharge at a point further away?
Just throwing that one out there.
also be aware as you pull bits away from the frame or panel it may loose rigidity , flex and crack the panel.
Maybe keep an eye out for a 2011 model with a busted SC board and fix it. Probably easier to do that than to work out this one.
Originally posted by infrag
View Post
