Element ELEFT466 has audio, NO picture OR backlight
  • Ronnustwo
    • Jan 2017
    Hi All, very new here
    I picked up a free Element TV off of CL with the very issue as stated in the title.
    Model # ELEFT466 serial # B1300228110004322
    I've swapped LED strips for backlight on my LG TV in the past successfully, thought this may be the same issue for this TV.
    BUT - there is no picture using the flashlight method.
    There appears to be no backlight as well, no dim glow, no quick flash upon start-up, nothing.
    The TV turns on (red to blue LED) and works as far as audio is concerned from HDMI1
    I haven't metered anything as of yet, just simple observation after taking off the rear cover.
    The only obvious thing is a steady hum noise coming out of the tcon, so at least I know it's getting some type of power
    There is no visible damage to any board or to the TV overall, all connections tight.
    I've read in a few of the posts on this forum that this is typically a more unpleasant experience when working on these Element TVs, so if it is recommended to give it up please do so.
    Otherwise, could anyone provide any direction as to where to begin?
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: Element ELEFT466 has audio, NO picture OR backlight
    Need some good pictures and voltage readings at power supply connector
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8326
      Check if the main board sends BLon to the PSU to turn the back lights on.
      As for no picture, you would have to probe the LVDS with an oscilloscope while turning the menu off and on all the time. If you see changes, the main board is fine and there is a problem with the Tcon. Check the fuse(s) on the Tcon.
      • triplefour
        by triplefour
        09-13-2023, 10:43 PM
      • TR103
        by TR103
        - it keeps rebooting
        01-22-2025, 04:12 PM
      • samson7point1@yahoo.com
        Help troubleshooting an audio problem with an RCA SGT-250 CED Player
        by samson7point1@yahoo.com
        The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
        The player processes the audio signal using two different reference frequencies. The "R"...
        04-30-2024, 11:22 AM
      • Mgiffune
        by Mgiffune
        06-09-2024, 10:28 AM
      • Ierwin
        by Ierwin
        05-13-2025, 03:31 PM
