Eeprom dump thread!
This is a sticky topic.
+ More Options
Posts
  • lotas
    • Jan 2016
    • 4524
    • Russia
    #1561
    Re: Eeprom dump thread!
    xurplusxhop Your dump soft is live, try with the nvm cut out.
    • rddube
      Aspiring Expert
      • Jun 2013
      • 908
      Need help fixing dump for a Toshiba 32L310UL believed to be corrupt
      I would need help trying to fix this dump for a Toshiba 32L310U20 believed to be corrupt. I've searched everywhere, but could not find the firmware for this model.
      When plugged in, the TV just turns on the red light, then off, then flashes 5 times. No response to power on, just stays off. If I unplug, and plug back in, again same scenario.
      Many thanks, or if anyone has a working dump, it would be appreciated!
      • lotas
        • Jan 2016
        • 4524
        • Russia
        #1563
        Re: Need help fixing dump for a Toshiba 32L310UL believed to be corrupt
        Try
        • rddube
          Aspiring Expert
          • Jun 2013
          • 908
          Hello Lotas,
          Thank you so much, will give it a try! Why is there a jpg file attached, is it something that I need to do with?
          Again, thanks and will give you feedback quickly!
          • rddube
            Aspiring Expert
            • Jun 2013
            • 908
            Hello again,
            Using my ch341a programmer as usual, I cannot erase the chip, it is giving me an erase verification error!
            Not sure why, but does that mean that the chip might be faulty, or is there a trick to get access to it?
            The chip is a Winbond W25Q64JV (3.3V).
            I've alwayas used this programmer and it has always worked, first time this happens. When I try to erase I get an erase error, and the chip has not changed, same content!
            Any ideas?
            • lotas
              • Jan 2016
              • 4524
              • Russia
              #1566
              First try to remove the protection (status register), then try to erase it, you won’t be able to replace it with a new spi flash.
              • rddube
                Aspiring Expert
                • Jun 2013
                • 908
                Ok, so succeeded in programming the chip, and we seem to be getting closer as the TV seems to turn on normally, but no backlights and no image on the screen. I can then turn it off and turn it back on, with a solid red light, but nos backlight, no image and no sound. Tks!
                • rddube
                  Aspiring Expert
                  • Jun 2013
                  • 908
                  Woops, addendum Lotas, tv works perfectly with your fixed firmware. Yes! Had another problem in that backlight leds one of them was intermittent and was giving the false impression that the tv was not powering on. Got that led changed, and now were back to full steam ahead.
                  Thank you very much Lotas, another save from the dump!
                  • lotas
                    • Jan 2016
                    • 4524
                    • Russia
                    #1569
                    Ok!
                    • img1
                      • Aug 2015
                      • 16
                      • Earth
                      #1570
                      Hi Lotas!
                      I am searching for a dump of a(n infamous) K9GAG08U0E into my boot looping Samsung UE40D5500RWXXH. The Board ID is BN41-01660B, the NAND's position is IC1302. The original content can't be read correctly as it differs on every readout due to the failing NAND chip. I tried the usual trivias: cleaning the chip's pins with 99.99% isopropyl alcohol and a glass-fibre pen, reading with different readers and different TSOP48 sockets, lowering the read speed, changing the USB cables to shorter and more shielded, changing the USB ports, changing the USB controllers (Intel, Etron, ASMedia). I have some more ideas for heating up its package with hot air and supplying the slightly lifted Vcc from lab PSU but I don't want to spent unneccessary times with experimenting if I can get working solution from you guys.
                      Thank you!
                      Alex
                      • lotas
                        • Jan 2016
                        • 4524
                        • Russia
                        #1571
                        Originally posted by img1
                        Hi Lotas!
                        Thank you!
                        Alex
                        Hello, I have a clean, clean dump without BB and ECC, but I need to know which physical BBs are present on your NAND Flash in order to prepare a dump for your NAND (so that the data does not end up on the BB).
                        P.S. And the data will always be different when reading NAND due to ECC errors.
                        • webadv
                          • Dec 2017
                          • 11
                          • Romania
                          #1572
                          hi, i am looking for the firmware for a samsung UE55KU6079U, BN41-02528A, BN94-10832C, panel CY-GK050HGNV5H.
                          the tv works but has no colors.
                          I wrote the memories with the bins from the ue50ku6092u, but it doesn't display anything. how could i solve it?
                          • lotas
                            • Jan 2016
                            • 4524
                            • Russia
                            #1573
                            How can there be a TV with a “55” diagonal, and the panel costs from “50”, correct it.
                            • webadv
                              • Dec 2017
                              • 11
                              • Romania
                              #1574
                              the board is on the diagonal of 55. but in the information about it it appears that it is ue50ku6092u. I wrote the bins for this model but it doesn't display anything anymore
                              • webadv
                                • Dec 2017
                                • 11
                                • Romania
                                #1575
                                that's how I bought the TV. without the original motherboard
                                • lotas
                                  • Jan 2016
                                  • 4524
                                  • Russia
                                  #1576
                                  Return all the original dumps (if you saved them), here you just had to replace the dump (t-con) 25Q80.
                                  Or change it to your panel in service mode.
                                  • webadv
                                    • Dec 2017
                                    • 11
                                    • Romania
                                    #1577
                                    from the service menu you have nothing to do with them
                                    here are the files it works with
                                    • lotas
                                      • Jan 2016
                                      • 4524
                                      • Russia
                                      #1578
                                      These are his original dumps, if so, then return dumps 24c512 and 25Q40, and write down mine 25Q80.
                                      In service mode you can change the panel type!
                                      • webadv
                                        • Dec 2017
                                        • 11
                                        • Romania
                                        #1579
                                        I tried, but black screen
                                        • img1
                                          • Aug 2015
                                          • 16
                                          • Earth
                                          #1580
                                          Thank you Lotas, I'll upload the dump later. Is the full dump is what you need or the main is enough (without the spare part)?
                                          Is it normal in those Samsung NANDs if there are 60-90 thousands (!) of bit errors? I know it is less than 1% but it seems like fairly unstable.
                                          • (0)_(0)
                                            Looking for a HP Photosmart C4280 EEPROM dump
                                            by (0)_(0)
                                            Hello, This might be a long shot, but I'm looking for an EEPROM dump for a HP Photosmart C4280 All-in-one printer.
                                            The printer seems to be in cartridge alignment mode. Sometimes it print the alignment page and then hangs during the scanning step, sometimes it hangs during the printing process and sometimes it hangs during the boot process. If I let it idle for a while then it flashes the back-light of the top screen and there's a letter E. Bottom screen is asking me to restart it to no avail. I have to remove the power cable from the printer for a couple of minutes to make it work...
                                            02-17-2022, 09:09 PM
                                          • my2k2
                                            Harman Kardon AVR 171, Request for IC1504 (24C32) eeprom dump file
                                            by my2k2
                                            Good day to every one,
                                            I have AVR 171 the IC1504 (24C32) eeprom is corrupted not able to read.
                                            Does anybody have an eeprom dump file? I really appreciate any help.
                                            Thanks in advance.
                                            07-01-2024, 09:04 PM
                                          • Whale linguini
                                            p14s Gen 2 thunderbolt eeprom dump
                                            by Whale linguini
                                            P14s Gen 2
                                            HT4B0/HP4B0/HT5B1/HT4B2
                                            NM-D352 Rev 1.0
                                            sn PF-35P15W
                                            Requesting thunderbolt dump
                                            also attached is the tbt dump. I extracted the bin from the cap file and modified it, not sure if it's correct. also didnt work....
                                            09-03-2024, 01:56 PM
                                          • Ancient1
                                            Before I dump this Panel...
                                            by Ancient1
                                            Hi
                                            I was working all day on a 42" with no backlight = Driver is bad . LED Tester. Image exists
                                            As I was reassembling, I discovered faults on the screen ( used the LED Tester to power the strips).
                                            Right distribution board, 2 Flexs, near them:
                                            The one near the center has 1" line on screen. Pressing on the board-side or Panel side of the Flex bonding place results in some change, I sensed heating one time, but main fault line remains
                                            The other, pressing on the Panel to the Chassey and the lines disappears 99.99%
                                            I...
                                            10-23-2022, 11:07 AM
                                          • jimha
                                            LG 34UC99 EEPROM dump
                                            by jimha
                                            Hi ,
                                            I'm looking for a dump to repair my screen
                                            12-09-2024, 03:52 PM
