Eeprom dump thread!
This is a sticky topic.
12V is present. 3.3V, 1,5V, 1,8V are ok. But nothing else. Seems the T-Con is enables from mainboard because if I remove the LVDS cable no any sign of life on T-COn. The one LED isn't lit. VGH, VGL, AVDD aren't present.Comment
Samsung usually does this: if the panel is not connected (even just one cable), the feedback is disrupted and the T-CON blocks the voltage to the panel. Similarly, if there is a problem with the panel (short or low resistance on the strips along the power buses) or in the panel, the T-CON will also block the voltage to the panel.Comment
Thanks Luzmina. I have one to share also. Sony XBR-43X800E A-2165-796-A also for the 49 and 55 inch versions (XBR-49X800E / XBR-55X800E).
https://cdn.badcaps-static.com/file_...ny%20board.zip
Sinotec STL-39ME82
Main: 569ME1601AAttached FilesPremium supporters get full download access and other benefits.
Sharp LC-32HI3122E dump Panel type - LQ315T3HC4UAttached FilesPremium supporters get full download access and other benefits.
Hi everyone, I am looking for the USB recovery firmware allupgrade_72690_sos.bin for a Cultraview CV72960-D55 mainboard paired with a 43-inch Panda G430QD1DJ1-56 screen panel.
The TV is currently stuck in a boot loop.
Model: VORTEX V43RPN843FRF 43"TV;
Main Board: CV72960-D55;
Display is G430QD1DJ1-56.
Thank you.Comment
I am looking for an SPI Flash dump for a Samsung BD-D8200/ZF (Made in Romania, S/N 013068FB901601B) stuck on HELLO on the front VFD. The HDD spins, the BD drive loads/ejects discs and it responds to power/eject commands, but there is no video/audio output.
Any SPI Flash dump will do, any size, from BD-D8200 / D8500 / D8900 with any suffix /ZF, /EN etc., especially variants with DVB-T/C tuner (same main board). However, to get out of the HELLO stage, a dump from DVB-S/S2 variants will also work.
Thank you!Comment
i am new to this need a file for this bord eprom TP.MS3458.PC757 BORD #8142123342029 pannel# hv550QUB-B11
Hello, I am looking for a working EEPROM software dump (.bin file) or a USB forced-recovery firmware package for my 55" RCA television. for this rca rtu5540 main bord part #8142123342029 pannel# hv550QUB-B11 tv serial# a1702199580000138 can you get one for me thanks kurtComment
hey did you find anything? bc im looking for the same thingi am new to this need a file for this bord eprom TP.MS3458.PC757 BORD #8142123342029 pannel# hv550QUB-B11
by bhangal.05Hello everyone,
I am looking for a verified EEPROM .bin dump for a Canon LBP 2900B printer.
Device: Canon Laser Shot LBP 2900 / 2900B Logic Board / Formatter Part Number: RM1-3078 EEPROM Chip: (Look at the 8-pin chip on your board and type its number here, e.g., 24C64, 93C46, or W25Q32)
The Issue: Replaced the formatter board because the original was not recognized by USB. The new board takes print commands and the mechanics/lasers spin up normally, but it outputs a completely blank page. I strongly suspect the firmware inside the BIOS/EEPROM on this replacement...08-29-2026, 04:19 AM -
by holidayyyI am in desperate need of an EEPROM dump for a Sony Trinitron KV-9AD1 (Japanese model) or its North American equivalent, the KV-8AD10.
micom - Mitsubishi M50439-715SP
jungle - Sanyo LA7655N
eeprom - OKI MSM16911RS
If anyone happens to have this specific dump file or owns one of these models and is able to perform a dump for me, it would be a huge help.
I've been searching for this for a long time, so any leads or assistance would be greatly appreciated. Thank you so much in advance!01-03-2026, 06:08 PM -
by GjjgfjHi everyone,
I'm re-celling a Dell Latitude 505 battery (C1295 / NF398 - 11.1V, 4700mAh) and accidentally corrupted the EEPROM. I used the wrong I2C settings on my programmer instead of Microwire, overwriting my factory code with garbage.
I need a working donor .bin dump.
Board Specs:- PCB: Sony 1-684-189-41
- MCU: M37516 (Mask: G02)
- EEPROM: 93C56
Channel: BIOS Requests ONLY!
07-16-2026, 03:25 AM -
by ElectricManHello everyone,
I am working on an older Insignia NS-32E400NA14 LCD TV.
The Problem: The TV will not turn on and only displays a solid red standby light.
Troubleshooting done: I have successfully narrowed the issue down to a corrupted SPI flash chip. To test this, I swapped in a flash chip from a different, similar donor board. With that donor chip, the TV successfully powers on! However, because the donor chip came from a board configured for a different screen size and display interface, the resolution and display mapping are completely scrambled.
...09-04-2026, 06:41 PM -
Good day to all, I have a big problem. I can't find the eeprom dump for the Eizo CS2740 monitor. The device doesn't turn on, the indicator just lights up. It responded to connecting to the PC once. The update process started with the standard program and then disconnected from the computer. The computer doesn't detect it anymore. If anyone has an eeprom dump, please share.
07-26-2025, 03:24 PM -
- Loading...
