17IPS11 - No Backlight
  • speedypro
    • Feb 2013
    • 561
    • United Kingdom
    I'm aware of this post but I need to understand something before I dive into the panel to change any strips. I do not have the backlight (there is display with a torch shines onto the screen). On the attached image, red/black wires, I get no voltage. If plugged out and test, no voltage. Should there be x voltage regardless if connected or not?
    Full-time computer repair tech (10am - 6pm) and full-time, (8am - 11pm), Ruby on Rails Developer
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: 17IPS11 - No Backlight
    Yes, find the sch for IPS11 (inverter power supply) led drive area and test what you get vcc out the controller to the mosfet. Also check for short circuits on the led drive area output.
    • vinceroger69
      • Mar 2012
      • 6714
      The schematic is in the other thread but added to this one for easier access
      • speedypro
        • Feb 2013
        • 561
        • United Kingdom
        Thanks.
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          Any luck ? Ive not had this issue on these Psus yet they are actually very very reliable in terms of Vestel.
          • speedypro
            • Feb 2013
            • 561
            • United Kingdom
            Yes. MP3394 needed replacing and also a led strip. TV is now working like new. Thanks.
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              Good job, usual suspects seems sometimes if an Led fails it can kill the driver Ic. Watch the lastest video on an Lg where there was a bad Led which also took the driver out as well.
              • Andrew F. Ali
                • Jan 2014
                • 2450
                • Trinidad & Tobago
                Reecey, do you have the link to view this video???
                Thanks.
                • vinceroger69
                  • Mar 2012
                  • 6714
                  i think it maybe this one ive just watched
                  https://www.youtube.com/watch?v=C567h02AqS0
                  • ReeceyBurger123
                    Never Give Up !
                    • May 2014
                    • 7325
                    • Britain
                    That is it Vince filmed that ages ago just got round to uploading
                    • Andrew F. Ali
                      • Jan 2014
                      • 2450
                      • Trinidad & Tobago
                      Thanks vince and Reecey.
                      • JoeBug
                        • Jul 2015
                        • 20
                        • Bulgaria
                        i just got Toshiba with same board, one open LED in the backlight, all LEDs are in serices. When not connected(and when connected too, due open LED, voltage rise hight ( 50v on multimeter) then start droping to 0 (cap discharge).
                        Seems planned to be so, as i can see on the Open LED Protection chart, page 5 on the datasheet.
                        Fixed the open led, everything OK now. But my point was - when backlight disconnected, no voltage at the connector (rise hight, then stop and drop to 0)
                        • triplefour
                          by triplefour
                          09-13-2023, 10:43 PM
                        • Raulnn
                          Ansonic 32HD1 Vestel 17IPS11 17mb55 no Sound, no backlight, no images
                          by Raulnn
                          Hello! I am new to electronics, and this forum is fantastic. I have the following problem, I have an Ansonic 32HD1 tv, a generic brand from Vestel, with a 17IPS11-R4 power supply and main 17mb55.
                          The tv has no backlight, but it also has no image and sound. when it turns on the standby light blinks several times, and there is a very short flash of the backlight, as if it wanted to start, but it does not start. I have measured the voltage on the red wire of the backlight, as you have seen on the forum, and in standby it has 30v, and when it turns on it goes up to 100v and slowly drops...
                          11-15-2022, 03:02 PM
                        • DanPoka
                          Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
                          by DanPoka
                          I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
                          Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
                          This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
                          02-15-2025, 05:05 AM
                        • Comp_Pro
                          No Backlight Macbook A1990 820-01041
                          by Comp_Pro
                          Hello all,
                          Am trying to figure out this backlight issue with this A1990 Macbook Pro.
                          Tests performed:
                          There is no backlight even with a good screen.
                          Backlight IC is receiving the correct support voltages.
                          Fuse F8400 ok
                          Current sense resistor R8400 ok
                          Backlight IC is receiving 3.3V on enable pin.
                          Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
                          Backlight IC receiving 5V from PP5V_G3S
                          Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
                          I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
                          05-06-2024, 10:23 PM
                        • cheebster
                          iPad Pro 12.9 5th Gen Backlight Issue
                          by cheebster
                          Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
                          Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
                          Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
                          The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
                          Anyone...
                          05-20-2025, 09:17 AM
